Old 01-08-2010, 12:15 PM   #1
jdearhart's Avatar
Trader Rating: 15 (100%+)
Default Lipo charger thoughts
Looking for another charger to go along with my GFX, and wondered what everyone's thoughts are. I had a LRP Pulsar 3 and sold it, been thinking about another one or the ThunderPower 610c. Any others?
jdearhart is offline   Reply With Quote
Old 01-08-2010, 12:31 PM   #2
i brought the Hyperion EOS0615i duo3
and i am loving it, it has two outputs, and can charge with 15 amps each..
it has balancer and everything you need and can also discharge at 10 amps, thats nice, because lipo's are best stored at around 60% capacity.. (has programs for that too ofc)
you can have realy complicated stats on you laptop via USB..
only downside is that it does require you to have a powersupply with you. but i think its worth it..
it can also be programmed to take care of "long leads" to your batteri so the resistance gets higher and it "false" peeks, not charging to full 4.2 volt per cell.. and you can firmware update it..
btw did i say its 2 x 15 amps charge..
pawmadsen is offline   Reply With Quote
Old 01-08-2010, 08:02 PM   #3
I've got a GFX and have also been thinking about getting a smaller charger. It would be cool to charge two packs at once. How much $ is the Hyperion?
outlandr91 is offline   Reply With Quote
Old 01-08-2010, 08:30 PM   #4
syndr0me's Avatar
Trader Rating: 32 (100%+)
http://www.teamepiconline.com/shop/i...em=SK-B6MOC100
Look around, you can probably find them for $150 elsewhere. Charge/balance 4 packs at once if you want, though it's limited to 5A per charger. Nearly half the price of the Hyperion.
syndr0me is offline   Reply With Quote
Old 01-08-2010, 08:51 PM   #5
trerc's Avatar
Trader Rating: 89 (100%+)
I don't think you can go wrong with either the DuraTrax ICE, CheckPoint 1030, or anything Hyperion.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 01-08-2010, 08:54 PM   #6
Thumbs up
LOVE MY SUPERBRAIN 989
jmrbsn is offline   Reply With Quote
Old 01-08-2010, 09:01 PM   #7
SS LS1's Avatar
Trader Rating: 23 (100%+)
I highly recommend the ThunderPower 610c charger, I have two and love the size and built in balancer. I have noticed that they charge faster than my Orion Lipo charger, the Onyx 230 and the Duratrax Ice chargers. It will hold your charging amperage setting longer before throttling back the charge current when switching to constant voltage charge mode. I have seen this cut 10+ minutes off of the time to charge my 5000 mah packs compared to these other chargers.
SS LS1 is offline   Reply With Quote
Old 01-09-2010, 02:14 AM   #8
the hyperion is 268$ at rc mushroom
Old 01-09-2010, 05:54 AM   #9
Bought one of this. Capable to charge up to 10A while the balanced ports are all in built.
Checked the individual cells' voltage after balance charging and they are accurate to 2 decimal points.
http://www.rc-fans88.com/details.asp?prodid=1487
Cheers!!
K.I.S.S.
Keep It Simple Stupid
kerk is offline   Reply With Quote
Old 01-09-2010, 06:19 AM   #10
Mugen10's Avatar
Send a message via Yahoo to Mugen10 Send a message via Skype™ to Mugen10
I have the Orion race spec charger. It is small and has a nice bling effect in your pit area. http://www.horizonhobby.com/Products...rodID=ORI30127
Central Kentucky Racing
Xray T4
Mugen10 is offline   Reply With Quote
Old 01-09-2010, 09:09 AM   #11
simplechamp's Avatar
Trader Rating: 73 (100%+)
Cheers!!
I can also vouch for the iCharger 106B+. Great charger, capable of plenty of power, and accurate balancer. Can also connect to computer via USB and graph the charge/discharge to monitor you cells. A-main hobbies now carries these chargers under their Pro-Tek line, along with a few other iCharger models.
simplechamp is offline   Reply With Quote
Best AC/DC LiPo charger under $200 Armaan Electric Off-Road 33 08-10-2009 12:04 AM
