Old 10-06-2010, 03:38 AM   #1081
Glorykid's Avatar
Originally Posted by S.A.W View Post
Hi,
Tried these setting tonight indoors,
X12 13.5t motor (-10deg)
FDR: 6.56
Feel: 4
Boost: 6
I put the feel upto 6 as I wanted a more punch. Speedo shut down twice as motor hit 120deg
so I then geared up to 7.47 was alot better but motor temp was still in the 80's with a fan. I then tried gearing up more to 8.02 had a bit better punch in field but motor temp was still in the 80's
what should I do now, gear up even more or get a better fan with heatsink and then try more punch ?
Thanks.
Hmmm temps in the 80's are fine. Heatsink and fan would help and maybe allow to run more boost or punch.
Nemo Racing~Agama~Bullitt~Beta~Piranha~Racer
Glorykid is offline   Reply With Quote
Old 10-06-2010, 06:20 AM   #1082
That was with a fan running from a spare rx channel not direct from the battery which would cool it more. I'd rather run with out a fan most of the good drivers at my local indoor don't run a fan. How can I get the temps down without a fan, gear even lower, less boost ?
I'm going to try boost on #3 and gear it for a lower temp then try adding more boost.
Thanks.
S.A.W is offline   Reply With Quote
Old 10-06-2010, 10:00 PM   #1083
new to electric
how hot should the esc be running?
im reading the manual and all it has is the temp chart (1flash, 2 flash, 3flash 10 flash shutdown, etc)
how many flash is ideal to be running at?
i know the motor shouldnt be at 160-175f
any damage if running the motor or esc temp lower
ALSO, i dont understand the manual temp.
it says 'count the number of flashes.The higher the number, the hotter'
then the chart shows
1 - 45c
2 - 40c
3 - 35c..
the temp getting lower as the flash increase,
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 10-06-2010, 11:26 PM   #1084
Johnny Wishbone's Avatar
Just wondering if anyone that had the V2 upgrade done to their SXXSS from the MK3 version has had a chance to run it with some of the problematic motors of the past. The 17.5 Orions and the Duo1's and 2's had cogging issues........is this fixed now. (Syndrome have you done any testing ???)
Old 10-07-2010, 01:28 AM   #1085
Any releas date for the sxx ss v2? (new Stock esc?)
How is the mk3 in performance? Or is speed Passion gt2.1 whit New software better?
Zooberg is offline   Reply With Quote
Old 10-07-2010, 06:26 PM   #1086
AE-Reedy
Originally Posted by LiL_JaSoN View Post
new to electric
1 - 45c
2 - 40c
3 - 35c..
1. Depends on the motor you are running and how hot it is where you are running. Normal temps for SCs are 120-150F externally. SCs tend to get hotter inside and do not always transfer that heat out. That is why the flashing light system is more accurate.
2. There is no ideal temp you just do not want it to overheat. Most normal operation you should only see 1-2 flashes.
3. What the manual is refering to is how many degrees away from thermal shutdown you are. Example 2 flashes means you are 40C away from shutdown. This would mean that the speed control reached 60C during operation. 100C is the shutdown point, I believe.
Sean Cochran is offline   Reply With Quote
Old 10-07-2010, 10:49 PM   #1087
Any One ? Best Lrp sxx ss mk3 or speedpassion gt2.1 pro stock
Old 10-08-2010, 12:12 AM   #1088
Questions?? this may sound dumb
can having a good esc dramatically effect the performance and longevity of a car?? im running some very old hardware on my rs4 and thinking of getting a new esc... is it worth spending $200+ on a esc to get better performance? im mainly looking for throttle control and longer running time.
DEIGIMA is offline   Reply With Quote
Old 10-08-2010, 05:35 AM   #1089
very helpful so 1-2flash is ideal on the SC?
Old 10-08-2010, 12:57 PM   #1090
Mr. MR4's Avatar
Default Maximum Temperature for X12 Motors
Tested out my X12 13.5 motor today and maximum temperature on motor after run was 215 Deg F without fans.
Is this ok ?
Xray T4'16 HobbyWing Xerun 120A V3.1
Xray X1'16 HobbyWing Justock
Yokomo R12C3 HobbyWing Xerun V3.1
Mr. MR4 is offline   Reply With Quote
Old 10-08-2010, 02:22 PM   #1091
AE-Reedy
Is this ok ?
TOO HOT!
Put a fan on it and it might be ok.
Old 10-08-2010, 02:25 PM   #1092
masterhit's Avatar
Trader Rating: 15 (100%+)
Did anyone ever figure out good set-ups/roll-out for X-12 17.5 & 13.5 with either a MK I or MK II for 1/12th?
Thanks,
Mike Slaughter
Last edited by masterhit; 10-08-2010 at 09:56 PM. Reason: forgot to add for which scale/class
masterhit is offline   Reply With Quote
Old 10-08-2010, 02:28 PM   #1093
AE-Reedy
Originally Posted by masterhit View Post
Did anyone ever figure out good set-ups/roll-out for X-12 17.5 & 13.5 with either a MK I or MK II?
Thanks,
Mike Slaughter
Nobody should have a mkI unit anymore, and there probably aren't many still using mkII either.
Old 10-08-2010, 02:42 PM   #1094
masterhit's Avatar
I still have a MK I and two MK IIs. They have performed flawlessly in TC (and caused me to tear hair out in 1/12th) so I kept them.
I would even take a set-up for a MK III and go from there (even if it ended with me buying a MK III)....
Mike Slaughter
Old 10-08-2010, 08:48 PM   #1095
andrew-01's Avatar
Trader Rating: 22 (100%+)
Thanks,
Mike Slaughter
x2
In my case though its for 17.5 carpet with track dimensions of about 90' x 45'.
ANDRXW.com
andrew-01 is offline   Reply With Quote
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
LRP Vector X12 StockSpec and SXX stockspec mac853 Electric On-Road 224 03-27-2010 02:54 PM
