Old 07-31-2010, 07:31 AM   #976
Akudou's Avatar
From my experience, there is no difference as i am using it on orion 11.5T. The mkII did cog on it but not as bad as the MKIII
Originally Posted by alejandrospeed View Post
Hi people,
I have one question:
What is the difference between the sofware MkII and MKIII?
Akudou is offline   Reply With Quote
Old 07-31-2010, 07:48 AM   #977
ok thank you,
A question add, the engine does not warm up you excessively in quando you happen from the program I number three of advance?
I take this configuration 0-3-3-0 with the sxx/ss and one x12 10.5 and extract the engine on approximately 90 degrees.
And the tekin more go than sxx/ss and warm up less
alejandrospeed is offline   Reply With Quote
Old 08-01-2010, 02:06 AM   #978
IgorR's Avatar
Default Max motor with SXX Stock Spec and lipo 1S
Hello,
What is the biggest motor a SXX Stock Spec can support with lipo 1S?
IgorR is offline   Reply With Quote
Old 08-10-2010, 01:48 AM   #979
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
Default sxx ss with x11 13.5T
hi guys,
any of tried the sxx ss mk3 with a x11 13.5T motor (TC; 2s lipo 50C is used)?? i am still looking to find the sweet spot for this motor as i have to use it in our racing series. the track is rather open with a 80m straight and some long and fast corners. only small technical infield. any suggestions to FDR on the x11??
vitomon is offline   Reply With Quote
Old 08-10-2010, 02:36 AM   #980
H I
H I's Avatar
Trader Rating: 18 (100%+)
Originally Posted by IgorR View Post
Hello,
I've run 4.5, and I know friend run 4.0 with out any problem.
But I found it can be faster using 5.5 with boost setting 4-5 than 4.5 with no boost.
H I is offline   Reply With Quote
Old 08-10-2010, 03:21 AM   #981
On top of that I have seen the abuse of BADMAN, who continues to chuck way more power at his 12th than anyone can handle in the spirit of a massive grin! He has run some serious settings on his SXX SS with no problems at all (short of dumping in under 6 mins). I say it would be very very hard to kill the ESC.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 08-12-2010, 11:46 AM   #982
Johnny Wishbone's Avatar
Anyone seen any software downloads, or interface information on the V2 yet??
Old 08-12-2010, 11:53 AM   #983
sham55's Avatar
Default hello ...
hy all just stopping buy anyone of you using a 9.5 lrp motor and a lrp sxx ss ?
just needed help with the gear ratio on what is good to used iv tried many gearing ratio but still cannot find any good ones ... im using xray t2 with a fdr x1.7 could anyone mind shareing their gear ratio that can hold the sxx ss .. thanks .
sham55 is offline   Reply With Quote
Old 08-14-2010, 09:09 AM   #984
Jim_1987's Avatar
Is there a new version of the SXX stock spec coming out? Most model shops have the V3 on offer at the moment. I'm waiting for LRP to replace my speedo, just wondering if they will replace it for the new one.
Jim_1987 is offline   Reply With Quote
Old 08-14-2010, 09:39 AM   #985
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Yes, the Version 2's are soon to arrve
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 08-15-2010, 01:48 AM   #986
altreyx's Avatar
Version 2 is only SXX and SXX TC not SXX Stock Spec. But i think will be possible update the SXX SS like the version 2 trough the sensor port. At the LRP master people had the update from MKI/II to III in that way. And for what i know the MKIII is the last release.
Regards
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 08-15-2010, 02:45 AM   #987
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default Keep going back to the SXX SS
Hi all..
After much time chatting to ALL the Tekin gods...
Tried ALL the latest settings recommended by Tekin gurus..
The SXX SS leaves the tekin..smooth power, cant kill it (typical lrp), and it has the BEST brakes all round....
The tekin is fast,,but like riding a bucking horse, and no high speed brakes..
Didnt change anything, just the esc,,put in settings I know work.
3, 3 ,9, 0...and no problems came from 7 to 3rd..
Motor 55deg c....10.5 fdr 6.9...duo 1 "0" timming..Large out door gas track
Seem's the "0" timed motors are the go with these timed speedies....
Love it....
Mike
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 08-15-2010, 05:27 PM   #988
Trader Rating: 38 (100%+)
or8ital is offline   Reply With Quote
Old 08-16-2010, 10:25 AM   #989
Jim_1987's Avatar
Regards
Excellent, that's what i was hoping for.
Old 08-18-2010, 12:52 AM   #990
sham55's Avatar
Default ...
Regards
yea i wish it update like that so we no need to buy new esc again huhuhu ....
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
LRP Vector X12 StockSpec and SXX stockspec mac853 Electric On-Road 224 03-27-2010 02:54 PM
