Old 01-13-2010, 03:33 PM   #76
Originally Posted by stonedgti View Post
Any reason why AE BD won't get EFRA approval?
There only would be one as it higher's the Voltage of the lipo. It isn't doing that so I don't see why the speedo would be illegal.
All other things it may do but this is the only thing a speedo may not do.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 01-13-2010, 05:27 PM   #77
Originally Posted by Chris-s View Post
Preferably in red.
hell no Blue is better
Burney is offline   Reply With Quote
Old 01-13-2010, 06:24 PM   #78
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Can this speedo be used with a mod motor on 1s lipo? I would be using a 4.0 in my 12th scale.. Reason i ask is that ive seen someone use an SPX for the same thing..I sometimes race it with a 10.5 and it is very slow with my SXX, for mod its great....Just wondering if the speedy can handle it?
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 01-13-2010, 08:30 PM   #79
gashuffer's Avatar
Trader Rating: 48 (100%+)
Yes it can handle 1 cell without a rx pack.
Taken from Nexus.
SXX Stock-Spec Brushless Speed Control features:
- Dual ADPC Max Software. Independent adjustment of "Feel" and "Boost" for maximum flexibility and high power.
- Twin BEC. Constant 6V/3A output with 3.0V to 7.4V batteries. No need for receiver battery for 1S LiPo or 4-cell NiMH Batteries.
- Revolutionary Internal Temp Check System 3. Allows you to read the maximum internal temperature for both the speed control and motor.
- AutoCell System 2 (3.0V to 7.4V input voltage). Fully adjustable cut-off system for all types of cells.
- Extra Small Size. 30 x 34 x 21mm for easy installation in most vehicles.
- C3 Technology. Revolutionary Copper Core Cooling technology for lowest-running temperature.
T-Sal
gashuffer is offline   Reply With Quote
Old 01-14-2010, 02:17 AM   #80
Taken from Nexus.
But you should keep in mind, that although the Stock speedo's can be used with a 4.0 motor, you should put the power program down a notch. Same as it was with the SPX. When you race a mod motor on a high power program you'll simply burn up your electrics.. And I guess you don't want to do that
Rick Thomson is offline   Reply With Quote
Old 01-14-2010, 02:52 AM   #81
Cool thanks for that, Yea ill turn the speedy settings down. There already down on the SXX so ill just do the same if i end up getting this speedo.
Antoni Caretti
Old 01-16-2010, 03:06 AM   #82
Originally Posted by Burney View Post
ok whats the uk rumored arrival then ?????
+1
_____________________
"To finish first, first i must finish!"
www.mkrctc.org.uk
www.akularacing.co.uk
Toblerone is offline   Reply With Quote
Old 01-16-2010, 08:09 PM   #83
Trader Rating: 114 (100%+)
Rick - Will we still have the limitation of which profiles we can run with the X-12 motors like we do with the SPX? Or will LRP have profiles built for the X-12 Stock motors for us to use?
oh.. and the blue... it is so much better...
Chris Furman is offline   Reply With Quote
Old 01-17-2010, 02:37 AM   #84
[QUOTE=Chris Furman;6862851]Rick - Will we still have the limitation of which profiles we can run with the X-12 motors like we do with the SPX? Or will LRP have profiles built for the X-12 Stock motors for us to use?
The SXX St. Spec is made to be optimized with the current range of LRP motors, so both the normal X12 as the new Octawind will work perfectly with the new speedo's.
You shouldn't forget that the SXX Stock Spec. is not just a software upgrade to the SPX, but that it's an updated version of the SXX specifically designed for stock.
Last edited by Rick Thomson; 01-17-2010 at 02:41 AM. Reason: Deleted the photos from the quote.
Old 01-17-2010, 08:17 AM   #85
Do anyone know when it will be in the shops?
dartvidar is offline   Reply With Quote
Old 01-17-2010, 10:50 AM   #86
Stephtruc's Avatar
That's THE question !!!!
Stephtruc is offline   Reply With Quote
Old 01-17-2010, 12:51 PM   #87
That's a surprise I guess At least, I haven't heard any official announcements about the release date. But it can be that much longer, since LRP often releases their products in time for the new summer season.
Old 01-17-2010, 12:59 PM   #88
I have to add, that Associated has announced that it will be available in jan 2010 in the US. So most likely it will be the same for the other continents.
Old 01-17-2010, 01:11 PM   #89
Stein Tumert's Avatar
My source in Germany said mid Jan a month ago, now he says around beginning of Feb.
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 01-17-2010, 09:00 PM   #90
Interesting.. Speedtechrc.com just posted an exact arrival date of 1/28.
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
LRP Vector X12 StockSpec and SXX stockspec mac853 Electric On-Road 224 03-27-2010 02:54 PM
