Old 05-21-2010, 12:25 PM   #841
Capt'N_Slow's Avatar
no offense taken. My opinion is simply based on the attached published information by LRP.
You are correct it does adjust the throttle map or trigger but it also alters the behavior of the current limiter which affects the punch from the motor. It would be interesting to know what the (secret) factors are?
„Feel“: the „Feel“ adjustment allows you to set the feel of the speed-control to your likes, it‘s a combination of current limiter, throttle map and other (secret) factors which the software alters depending on the status of the car (start, acceleration, full speed). Higher profiles result in more aggressive throttle response, so normally for applications on slippery surfaces lower „Feel“ settings are strongly recommended which give you best car control.
Using these settings on high grip indoor carpet.
Micah
Capt'N_Slow is offline   Reply With Quote
Old 05-21-2010, 12:26 PM   #842
syndr0me's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Capt'N_Slow View Post
Originally Posted by captain stacker View Post
Captain fight!
syndr0me is offline   Reply With Quote
Old 05-21-2010, 12:40 PM   #843
Trader Rating: 45 (100%+)
What is the latest version software for the LRP SXX Stockspec? Have all the issues been worked out with the latest version of software? And does it work fine with LRP X-12 motors? Thanks!
Apex is offline   Reply With Quote
Old 05-23-2010, 03:49 PM   #844
pmc
Originally Posted by pmc View Post
Hello
anyone have tried the SXX SS with the new GM pro motors like 10,5T or 13,5T.??
wish is the performance of the speedo with this motors??
best regards:
Pedro Silva
Hello
anyone run in the configuration above???
i want to buy this speedo but i am afraid they not function with this motors.
thanks in advance
Best regards:
Pedro Silva
pmc is offline   Reply With Quote
Old 05-24-2010, 07:03 AM   #845
altreyx's Avatar
Hello
thanks in advance
Best regards:
Pedro Silva
You have a pm
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 05-24-2010, 09:10 PM   #846
syndr0me's Avatar
Spent about 12 hours at the track today, and did a lot of testing with my mk3. Not sure if this will help anybody, but here's what I came up with. It's very fast.
Rubber tire touring car. Carpet track around 96x42'. SPv3 (BOSS) 17.5. FDR 6.6. 0-6-9-2. It's got rip everywhere, stays strong for 6 minutes, and comes off around 150ish with a 25mm fan blowing on it. It's faster than my Tekin+DUO1.
Old 05-25-2010, 07:19 AM   #847
jonest's Avatar
Wonder has any1 tried the esc with a 5.5t or 6.5t motor?
And what's the setting?
jonest is offline   Reply With Quote
Old 05-25-2010, 07:32 PM   #848
Trader Rating: 10 (92%+)
I'm thinking a 5.5 geared with a higher fdr with some boost would be easier and maybe faster to drive than a 4.0 or 4.5.
just an assumption anyway.
captain stacker is offline   Reply With Quote
Old 05-25-2010, 07:53 PM   #849
jonest's Avatar
I'm thinking the same thing.... just worried it might fry the esc...
Old 05-25-2010, 09:31 PM   #850
Akudou's Avatar
Sorry havent been around for sumtimes esp Femca. The orion 11.5T sensor motor cant seem to be able to cope with the mk3. i use to advance the timing on the motor by 2 lines on the mk2 and it was fast on an fdr of 6.3.. on a long straight i manage to overtake a car on 5.5T motor running on TC spec. With the mk3 i have yet to try advance the timing and see how it goes from there and see if any cogging arises from it. Any suggestions?
Akudou is offline   Reply With Quote
Old 05-25-2010, 11:37 PM   #851
dameetz's Avatar
Akudou, last femca race, some of the racers had a good result using mk3 and orion (default timing), they said they were using feel 5 and boost 5. Any higher than than it will cog. Not so sure about their FDRs though. Maybe you can try it this weekend.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 05-26-2010, 01:35 PM   #852
Johnny Wishbone's Avatar
Hey Adam I gave your setup a try, and it was better.........but I still get a small cog on exit of corner with a Nemesis -10 timing. I adjusted gearing a little for my track, which didn't make much difference and after the 6 minute run it was around 120-130. The cogging after the run was much worse than at the start of the race.......starting to think it may be some form of component drift when the sc starts to come up to operating temp.
Sure would be nice if some of those more knowledgable LRP people would get on here and give some form of update or known issues, or even just a " we're working on the trouble".
Old 05-28-2010, 01:26 AM   #853
Trader Rating: 55 (100%+)
I was planning on getting one of these but after reading that they still have a problem with cogging I'm going to have to pass for now. I don't think I want to gamble on being one of the lucky ones who doesn't have a cogging issue.
It would be nice if LRP would step up to the plate and say if they are trying to solve this.
G the Menace is offline   Reply With Quote
Old 05-28-2010, 05:16 AM   #854
Stonzy's Avatar
Send a message via ICQ to Stonzy Send a message via Yahoo to Stonzy
I have the Mk3 version with red dot on box.
When i was testing in the car park i found i had a lot of cogging issues when i mashed the throttle. I had it geared fairly high and with boost on around 7. Slipper was fairly tight with little slip.
Tested it with stock boost 3 and still the same.
Loosened the slipper a bit and it was better.
Changed down 8 teeth on the pinion with stock boost (3) and no cogging. Slipper adjusted to slip for the 1st 5 feet.
Adjusted the boost to 10 and still no cogging.
I think if the combination of having your slipper tight without any slip at all, high gearing and mashing the throttle then i think you will have problems.
Personally i'm very disappointed with the LRP SXX SS with the cogging issues it has.
My other branded esc's have no issues at all with any gear ratios.
Hope this helps some people out who have them or were thinking about buying one.
Team Manager "Fantom Racing".
Proudly Sponsored by Fantom Racing, “More Power To The People”.
T4.1, T4, B4.1, TRF501X, Dyna Storm, Hornet, Top Force, XXX-SCT, Slash 2wd,
Multiple National Champion and State Champion from 2003 - Current
Stonzy is offline   Reply With Quote
Old 05-28-2010, 03:19 PM   #855
Stonzy,
Have you tried a different brand of sensor cable?
It seems a few are reporting that changing the sensor cable is fixing the cogging issues.
My replacement SXX SS just came back from AE a few days ago and I've got it hooked up to an X12 13.5 but with a Novak sensor cable and I can hit full throttle from a standing start without any cogging.
This is on boost setting of 6 and feel of 3.
Could be worth a try?
Lycan is offline   Reply With Quote
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
LRP Vector X12 StockSpec and SXX stockspec mac853 Electric On-Road 224 03-27-2010 02:54 PM
