Old 05-10-2010, 02:45 AM   #796
Damon's Avatar
Originally Posted by Akudou View Post
Guess there is still no answer to the cogging problem on MK3 utilising the Orion 11.5T pro stock motor.
Yesterday I used the Lipotech XR 10.5 with SXX-SS Mk3 and I had the same cogging problem. I tried different sensors cables, and with Novak cable the cogging disappeared!!!!!
I tried again the other cables (Speed Passion and LRP) and cogging returned.....................
How can cables be so different?
Awesomatix A800
Awesomatix A800X
Damon is offline   Reply With Quote
Old 05-10-2010, 02:52 AM   #797
Akudou's Avatar
Too bad you are not joining. I will still try to solve the issue of the mk3 and worst comes to worst i have to end up using the Tekin while the Xe will be my backup.
Originally Posted by jonest View Post
Andrew,
I won't be running @ FEMCA this weekend as I'll be visiting the "Land of the rising Sun"!.... have fun.... on the XERUN, that's really sounds interesting...
Akudou is offline   Reply With Quote
Old 05-10-2010, 03:39 AM   #798
jonest's Avatar
Good luck
jonest is offline   Reply With Quote
Old 05-10-2010, 01:08 PM   #799
Akudou's Avatar
Thanks Jonest, am still deciding which esc to use now. Even my chassis isnt prepared yet cos have choices of mk3, rs pro and xerun v2 to choose from. Enjoy your trip to the land of the rising sun...
Good luck
Old 05-10-2010, 01:39 PM   #800
jonest's Avatar
I've tried the MK3 with team powers 11.5t just now... wasn't that fast till i changed it to X12 10.5t..... well I could keep 5.5t at bay... But I still have to work out the gearing... any1 has sugg?
Old 05-11-2010, 07:25 AM   #801
Are u using the new Team Power 11.5t motor or the old ? what are the gearing u using for the team power motor ? i'm using 7.32fnr.. It was fast..
ckloo is offline   Reply With Quote
Old 05-11-2010, 08:26 AM   #802
jonest's Avatar
It was the new one was playing the gearing from 7.33 - 6.4. Motor timing: 0
Old 05-11-2010, 08:35 AM   #803
Send a message via Skype™ to JordanC
It was quickest at around 8.8 with the X12 10.5 Try the feel on 4 and boost on6 or 7.
JordanC is offline   Reply With Quote
Old 05-11-2010, 09:45 AM   #804
jonest's Avatar
Thanks. I'll try it tomorrow.
Old 05-11-2010, 09:47 AM   #805
jonest's Avatar
Andrew,
Just a sideline, is the RCS track ready? If it is, mind share some photos?
Kok kun kap.
Old 05-11-2010, 04:17 PM   #806
pmc
Hello
anyone have tried the SXX SS with the new GM pro motors like 10,5T or 13,5T.??
wish is the performance of the speedo with this motors??
best regards:
Pedro Silva
pmc is offline   Reply With Quote
Old 05-11-2010, 10:21 PM   #807
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
what are the dimensions and type of surface of the track you ran those settings? which motor timing and what was the environment temperature and motor temperature after run?
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 05-11-2010, 10:37 PM   #808
Akudou's Avatar
Seems like our stock class 11.5t orion motor is not compatible with mk3. All 7 units in my country cogs on it unless we advance the motor timing which is not allowed for stock class. So everyone else is going for hobbywing Xerun Firmware 422 while im still thinkin which esc i am goin to use. might try the mk3 when the handout motor is handed out for control practise.
Old 05-12-2010, 01:20 AM   #809
It's a small to medium size track on asphalt. I am using 2 dot timing (0 Deg) and the ambient temperature is around 20 deg C at the moment. The motor usually comes off the track at around 80 deg C.
Old 05-12-2010, 06:18 AM   #810
Damon's Avatar
try the Novak shielded sensor harness, with it cogging disappear
Awesomatix A800
Awesomatix A800X
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
LRP Vector X12 StockSpec and SXX stockspec mac853 Electric On-Road 224 03-27-2010 02:54 PM
