Old 05-01-2010, 09:22 AM   #736
mac853's Avatar
Originally Posted by TRF4evr View Post
it seems that there are some good feed backs on the mk3 upgrade on the esc and also some negative and dissapointed racers who have put in there hard earned money in purchasing the lrp sxx ss with cogging n other issues....
my question is where/who/which hobby shop would you buy from and have no worries of getting a good mk3 version or getting a dud one?
in the states/asia
In fact i bought in Stormer.
mac853 is offline   Reply With Quote
Old 05-01-2010, 10:42 AM   #737
Trader Rating: 217 (100%+)
It doesn't matter where you buy it from cause no one knows if there is a dud in the bunch or not. Luck of the draw you might say. It's all a gamble. Just like buying used.
Andy Koback is offline   Reply With Quote
Old 05-01-2010, 06:31 PM   #738
I've heard a whisper of the upgrade to mk3 being able to be done in Australia, anyone else heard anything more definite? If not who do I deal with, I bought mine from amainhobbies.
Cheers.
Tasmik is offline   Reply With Quote
Old 05-02-2010, 01:42 AM   #739
I bought mine from Tower 6 weeks ago to go into my 1/12th but all the other guys at my club got the Tekin so the SPX just didnt cut it. It was a mk2 so I sent it back to AE in the states and 2 weeks later it arrived back, which was just last tuesday. Thats pretty quick seen as I live in New Zealand and it generally takes 7-10 days for anything from the USA or Hong Kong to get here. Ran it at interclub today, all i can say is dam it was fast Once setup right it was more than capable to beat the Tekins. I ran a X-12 13.5 4dot on a mediun sized track with fairly technical infield. Started at 6.8fdr 3.5.6.1. It was ok. Went to 7.5fdr and it just came to life but motor was still coming off a little hot. Finished at 8.19fdr 3.6.7.1 and all I can say is Yeah baby. Was told by one of the top drivers at the track we were visiting that mine had the most rip on the infield by far and had my driving been a bit better(only the third time on this track)I would have been right up there. LRP has made a great product as per usual but minor things like sensor leads, dirty motors and worn motor bearings and incorrect esc settings are more than likely the cause of most issues with the version 3 escs.
Bumpy is offline   Reply With Quote
Old 05-02-2010, 01:44 AM   #740
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
hi guys
letting use know that i have been running mk3 software and still cogging at low speeds very disappointed in lrp
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 05-02-2010, 09:10 AM   #741
jrxs-r's Avatar
Just to let everyone know... my Mk2 has been mint so far... only cogged on my once over the last weekend of racing.
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 05-02-2010, 09:47 AM   #742
sham55's Avatar
Default hello
hy everyone im new user in this mk3 lrp stuff, im using a orion 11.5t motor it seems it just unstable with the orion stock 11.5 motor it heat fast within 30s n its hot does any body knoes whats the problem, my fdr is 8.57 feel 3 boost 6, mine shareing or give me advise on that pls thanks
sham55 is offline   Reply With Quote
Old 05-02-2010, 09:51 AM   #743
sham55's Avatar
Default :d
Originally Posted by P.I.M.P View Post
hi guys
i have the same problem to bro but now its ok u just try to change the sensor cable first, i tried it about 4 to 5 sensor cable n now its ok ..
Old 05-03-2010, 01:49 AM   #744
Try dropping down a few pinions. Sounds like youre overgeared. I am now running 8.19 fdr with 13.5 and its awesome
Old 05-03-2010, 04:56 AM   #745
Hi, with SP 11.5T and MK3, I ran FDR around 5.0 on big outdoor track with Boost setting 7, Is your track very small?
Sometimes, the motor can overheat if the FDR is too high (pinion too small).
andrew188 is offline   Reply With Quote
Old 05-03-2010, 01:50 PM   #746
sham55's Avatar
Default thanks for shareing ...
yea its not realy big track tho ... but will try some of your tip ill update it later on again thanks .. the temp here is about 34 / 38 degree c
Old 05-03-2010, 01:53 PM   #747
sham55's Avatar
Default thanks ...
im running on a t2 8.57 is overgear ? so u suggest me to drop down my pinions or spur gear ? ill try it again thanks for shareing
Old 05-03-2010, 02:55 PM   #748
If your track is small, try somewhere around 6.0. At a semi technical track around the size of RCS, I would probably run somewhere around 5.3 to 5.7 with boost 6 or 7. I have never run on tracks much smaller than the size of RCS, but 8+ FDR for 11.5T seems too high, the motor would be spinning at too high RPM, and the feeling may be weird and you would get too much natural drag brake effect.
Anyway, when you test a new ratio or setting, be sure to temp your motor every 2-3 laps to make sure you won't burn anything
Old 05-03-2010, 11:26 PM   #749
sham55's Avatar
Default thanks for advise :)
bro isnt if i drop down the fdr it becomes more hotter i ment overgear ?
Old 05-04-2010, 12:11 AM   #750
Trader Rating: 10 (92%+)
you will find that motors can get hot if overgeared OR undergeared. There is a sweet spot for each motor/esc and it could vary from as big as 3fdr's. Ive geared my 17.5 as low as 4.5 and all the way up to 8. I would start by boost 5 and gear a 17.5 around 5, 10.5 around 7, and see how the temps are. If low, than boost up until your happy with the speed and temps. Then play with the gearing to fine tune.
captain stacker is offline   Reply With Quote
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
LRP Vector X12 StockSpec and SXX stockspec mac853 Electric On-Road 224 03-27-2010 02:54 PM
