Old 04-26-2010, 02:40 PM   #706
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default higher fdr
Originally Posted by Joep View Post
We tested between 5.7 and 4.9. But at 4.9 it became to hot and not enough punch and 5.7 not enough top speed. And fading was a problem at lower FDR (so below 5).
Try a higher FDR....Seems your on a largish track..same as ours...I found that using a higher FDR, lets the motor rev, runs cooler and no cogging..
I run between 9 and 10 FDR in 10.5...
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 04-26-2010, 02:51 PM   #707
chicky03's Avatar
Send a message via AIM to chicky03
Originally Posted by CB-OnRoad View Post
A few racers and myself are having issues with our SXX stock spec. We are using it in World GT, 1 cell with 13.5. We have made several attempts to change the profile and boost but were still not getting the "punch" in the corner and getting up to speed until half way down the straight away. We tried gearing as well. Any help would be appreciated. THX
More than likely the boost is too high or you are over geared. What motor are you using?
I know at the carpet nats guys using the duo motor were running 12th scales
boost 9 middle hole timing with 35/76 grearing with 1.68 tires 2.42 roll out. I'd go down a few teeth from there with wgt.
For the X12 motors I ran 43/80 boost 8 4 dot if I remember correctly.
this is with MK3, MK1 or 2 will be different settings.
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 04-26-2010, 04:53 PM   #708
Trader Rating: 114 (100%+)
oh man this Mk3 is awesome! Only took 3 of them though! LOL... AE did take good care of me on my first 2 though, so no complaints.
Ran x12 17.5 at 5.7FDR... 2 fans on motor by RW Workx, max temp 158F
5 feel and 7 boost. The thing was a rocket! and it only faded a tad bit at the last 2-3 laps.
I believe they also got better performance out of the Mk3, adjusted the profiles a bit, because with Mk1 and Mk2, the motor would overheat. The brakes are also excellent.
No.. now... I didn't have time to play with the x12 17.5FDR, has anyone else? 5.7 seemed good, but there is "always" room for improvement!
Chris Furman is offline   Reply With Quote
Old 04-26-2010, 05:48 PM   #709
jdm19turn's Avatar
What size track is this fdr based on
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 04-26-2010, 05:57 PM   #710
100 x 36.. full straight and 12 turns in road course.
Old 04-26-2010, 06:37 PM   #711
tha Beast's Avatar
Trader Rating: 100 (99%+)
Default ESC???
hi guys i need your opinions...first of all i dont really like Tekin products but the RS pro with all that "BOOST" BS seems to be the way to go, anyway im debating on what ESC to purchase i will be racing a stock 13.5 on a LARGE asphalt track so im debating against the Speed Passion Pro Stock the LRP SXX stock spec or the tekin(only cause im just getting smoked but the guys running them) so please gimmie your opinions id really appreciate it
tha Beast is offline   Reply With Quote
Old 04-27-2010, 04:28 AM   #712
Don't forget to add the Mamba Max Pro. I'm as fast as anyone on the straight with a 13.5, be it Tekin, GM or LRP SXX stock. I'm also gearing further and further down because has too much punch!
The thing about the Tekin, GM and Mamba, is that they're all updatable and eventually all will have that extra full throttle feature. Even the Ezrun esc is very fast! If you dont want to mess around with settings on a laptop, then the SXX stock is the one to have, as it leaves you with more time to setup the chassis.
maxg123456 is offline   Reply With Quote
Old 04-27-2010, 10:17 PM   #713
tha Beast's Avatar
does LRP provide software upgrades at all??? or would i have to drop another 200+ for a "new" speedo with different(better) software??
Old 04-28-2010, 04:47 AM   #714
dameetz's Avatar
As far as I know....No
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 04-28-2010, 06:50 AM   #715
tha Beast's Avatar
Old 04-28-2010, 08:24 AM   #716
chicky03's Avatar
Good things come to those who are patient
Old 04-28-2010, 01:47 PM   #717
Chicky, you say the V2 and V3 settings are different.
In 1/12 I am running X12 10.5, 4dot, V2 on 0,7,6,0 and 50mpr
If I went to a V3 what should I change?
reynard55 is offline   Reply With Quote
Old 04-28-2010, 02:18 PM   #718
syndr0me's Avatar
Trader Rating: 32 (100%+)
A new challenger has arrived!
Seriously, though, if this ESC gains firmware updates, that would restore some much-needed parity to this newly changed game.
syndr0me is offline   Reply With Quote
Old 04-28-2010, 02:20 PM   #719
syndr0me's Avatar
Has anybody come up with new settings for rubber sedan with mk3 for the different popular motors? Thinking 17.5 with x12, DUO & SP 3.0.
Old 04-28-2010, 04:03 PM   #720
chicky03's Avatar
They are slightly different. You will have to go up on the profile more than likely but I would start with what you have and go step by step.
Paul
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
LRP Vector X12 StockSpec and SXX stockspec mac853 Electric On-Road 224 03-27-2010 02:54 PM
