Old 04-07-2010, 02:04 AM   #586
Originally Posted by colt1402 View Post
I really need to know the current default setting. My local track race used 11.5 stock motor. It is consider smooth med side track, not tecnical track. Someone used it as stock default setting on 11.5 and it turn out great therefore i need to know it & from there i've a base setting to play around.
I think 0-3/4-5-0 is a good point to start. From there on you can see how the car,speedo and motor feel.
Rick Thomson is offline   Reply With Quote
Old 04-07-2010, 04:36 AM   #587
hacker's Avatar
Trader Rating: 141 (100%+)
RTFM
hacker is offline   Reply With Quote
Old 04-07-2010, 06:36 AM   #588
colt1402's Avatar
Trader Rating: 90 (100%+)
Originally Posted by hacker View Post
RTFM
*************************Addicted To RC*************************
colt1402 is offline   Reply With Quote
Old 04-07-2010, 06:52 AM   #589
Three's Avatar
Read the F***ing Manual
Electric good..........
Three is offline   Reply With Quote
Old 04-07-2010, 07:06 AM   #590
colt1402's Avatar
Ops!!!! WTH!!
Just saw it! Thanks Mr Three...!
Old 04-07-2010, 09:46 AM   #591
Three's Avatar
Life is good. Enjoy the SXX StockSpec.
Old 04-13-2010, 03:21 AM   #592
colt1402's Avatar
It been so quiet recently in this thread. Don't tell me that everyone switching to Tekin RS?!?
I have couple of questions on this SXX SS esc. Seeking for experts here to help & advise.
Let say if i am running 11.5 orion pro stock motor. Am i suppose to start with MAX out the boost & run the HIGHEST FDR and adjust the temp from there?
OR run the minimum boost & lowest FDR to start out with? The instruction never really give hint anything about very first start set up...
Old 04-13-2010, 03:48 AM   #593
Trader Rating: 10 (92%+)
whatever setting you start out at, remember to temp it every minute!
I started out on boost 6 with a fdr the same as the tekin 203. Then instead of playing with fdr's, I just upped the boost one step at a time until I got to boost 10. I feel if you dont plan on ending up on boost 9 or 10, you are loosing the benefits of this speed control and its purpose.
for a 11.5 I would start at 8fdr with mid boost and just go up from there!
hope that helps a little!
captain stacker is offline   Reply With Quote
Old 04-13-2010, 05:03 AM   #594
colt1402's Avatar
You make a very good point there!! Let say if boost 10, with FDR higher. We can have lots of acceleration as well as top speed with high boost?! Pls correct me if i am wrong.
Anyone else?
Old 04-13-2010, 05:32 AM   #595
Anyone else?
thats seems to be the case with the tekin 203, most people going up another 2fdr's with the newer generation esc's. Maybe the same techniques of gearing are used with the sxx ss as well. And so far they seem to be working
Old 04-14-2010, 12:56 PM   #596
Hi Guys, I have a GTB Novak ESC, will it make a big improvement if I switch
to the SXX SS, since the GTB doesnt have timing? I'm running a 10.5t motor.
Thank you
Kevin
kev74 is offline   Reply With Quote
Old 04-14-2010, 03:13 PM   #597
Has anyone tested Trinity/Epic Duo2 and Nemesis with SXX SS? I would like is faster.
andrew188 is offline   Reply With Quote
Old 04-14-2010, 03:17 PM   #598
Thank you
Kevin
Yes it will make a very big difference when switching to the SXX SS.
Old 04-14-2010, 03:19 PM   #599
DirtDrop's Avatar
Thank you
Kevin
Yes it will. i just went from a gtb to a SXX SS and ive noticed it felt smoother all the way around. it is worth upgrading to
DirtDrop is offline   Reply With Quote
Old 04-14-2010, 03:54 PM   #600
Thanks for your reply guys
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
LRP Vector X12 StockSpec and SXX stockspec mac853 Electric On-Road 224 03-27-2010 02:54 PM
