Old 03-24-2010, 08:18 PM   #526
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
i got my sxx ss for sale $190 shipped i havent had the cogging but maybe its bond to do it somtime i have everything for it ive used it 2 battery packs .. i just need money for school :/
Roberto Falcon is offline   Reply With Quote
Old 03-25-2010, 10:23 AM   #527
Received my SXX SS today really hoping that it is a mk3, just need to wire it up will be testing saturday and sunday.
youngben is offline   Reply With Quote
Old 03-25-2010, 06:28 PM   #528
Maybell's Avatar
I recommend starting with 4feel and 4boost...good luck!
Sean Maybell - Team Associated Region 11 Administrator
AE - Reedy - LRP - Hobby Velocity - XP Digital - JConcepts
Maybell is offline   Reply With Quote
Old 03-25-2010, 06:47 PM   #529
Airflow's Avatar
Which is more durable and has less problems?
The old SPX Stock Spec or the SXX Stock Spec?
I have a Novak Havok with 10.5T motor....
How much percentage in power increase can I expect if use
the SPX and/or the SXX with its Advance Timing feature?
20%? 40%? 10%?
Thanks in advance.
Airflow is offline   Reply With Quote
Old 03-26-2010, 03:06 AM   #530
altreyx's Avatar
20%? 40%? 10%?
Thanks in advance.
Before the MK3 version SXX SS had some trouble, now seems in LRP have solved the issue. So if the last version is really working without doubts the SXX SS is much better than the "old" Spx
About the timing features i can't answer, i have only to say that the SXX SS is running our stock class ( in Italy the stock class is with 10,5 motors) like "rockets", at the corner exit with good batteries (40/50C) the car is impressive.
With the SPX was really different also using good batteries but the improve using the SXX SS is huge, but depends also how you drive.
Hoping this can help you.
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 03-26-2010, 06:10 AM   #531
i have my sxx ss for sale its pretty much brand new $190 shipped.. pm me
Old 03-26-2010, 07:07 AM   #532
20%? 40%? 10%?
Thanks in advance.
SPX is more durable and problem free. SXX SS is about 20% to 40% faster in pure speed than SPX. In my opinion, unless your track is super big with very high grip, and your car's setup is good enough to handle the extra power, SXX SS may not improve your laptime over SPX.
andrew188 is offline   Reply With Quote
Old 03-26-2010, 10:24 AM   #533
Thanks Alot how much different do you gear the car compaired to the SPX
Thanks Ben
Old 03-26-2010, 11:18 AM   #534
Maybell's Avatar
Thanks Ben
That depends on motor and pitch but start with gearing down a little...2 or 3 teeth and keep close tabs on the temps.
Old 03-26-2010, 01:52 PM   #535
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default MK3 upgrade
Hi all..
Heres a reply from Associated USA..
"Ok you do not have the version 3 software. Thatís because we havenít sold any yet with the version 3. You can send it in here and we will update it for you and send it back to you".
Im sending back for the upgrade,, havnt used it as i dont want to ruin it or a motor..
Mike
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 03-26-2010, 08:14 PM   #536
Akudou's Avatar
Tried the SXX stock spec ss and i was quite impressed it with. Torquewas great and responsive enough that even my local track straight line of 60feet seems not enough for it. The response is very good. Am running on 11.5t orion vortex pro stock motor running 7.9 fdr on a 45C lipo 2s. Temperature after 5 minutes run was +60deg C.Its still on default profile. Anyone can help me improve on better profile or setting? This is my first lrp...
Akudou is offline   Reply With Quote
Old 03-27-2010, 03:17 AM   #537
V12
V12's Avatar
what settings are default settings?
V12 is offline   Reply With Quote
Old 03-28-2010, 03:37 PM   #538
Regional Moderator
mr4-malta's Avatar
Is LRP still producing the SXX ss? If not, when will it be back in production?
mr4-malta is offline   Reply With Quote
Old 03-29-2010, 12:32 AM   #539
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Angry Not Happy
Has LRP fixed the problem yet ?, I have one to send back and I know there is another 5 in Brisbane alone that have to go back as well, can someone from LRP or Associated post a reply.
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 03-29-2010, 01:05 AM   #540
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
hi
i am not a lrp employee, but i can say this. i sent in my SXX SS and got it back in time for some testing over the weekend. all i can say is WOW they really sorted out the troubles. speedo now worked like a charm. it had super feeling to it and the speed was just insane. i did have some trůubles in the first run (cogging) but this was due to a bad sensor wire which i changed for the rest of the day and it worked flawlessly. fyi my settings:
motor 13.5T speedpassion v3
SXX SS
feel 2
boost 9
fdr: 1:5,5
temperature after 7 min: 65įC
finally LRP got it together.
vitomon is offline   Reply With Quote
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
LRP Vector X12 StockSpec and SXX stockspec mac853 Electric On-Road 224 03-27-2010 02:54 PM
