Old 03-15-2010, 05:57 AM   #466
Trader Rating: 38 (100%+)
Originally Posted by chicky03 View Post
Sometimes taking out the sensor piece and cleaning it helps. Maybe try that. I was suprised how much tire dust was in my motor.
I'll give it a shot and see how it does. I had just taken it apart and cleaned it but I don't know if I paid any special attention to the sensor area. BTW, I tried your settings and the motor temps were much better.
or8ital is offline   Reply With Quote
Old 03-15-2010, 10:42 AM   #467
Jason Turner's Avatar
Trader Rating: 64 (100%+)
I have auto brake problems also with SPX or sxx I can usually use setting 3 or 4 on SXX SS I have to use setting 5 or 6 for same result.
I have a DX3R and the sub trim will give you some drag brake from the transmitter not sure what it would be on the helious though.
Originally Posted by Cristian Silva View Post
Hey guys, got a few question in regarding the auto brake profiles.
How much extra heat does this add to the motor after a run on a high setting?
Does anybody use this setting.
I only ask because previously running the SPX in 10.5 TC the car for some reason unknown had drag brake effect in off throttle, the spx auto brake setting I used was on 0 I noticed this effect when I increased the brake punch on my Helios EX-10, now when I converted over to the sxx ss that drag brake effect is gone, this is using the same motor and transmitter settings..everything as before, now with the sxx it feel like the car just keeps rolling past certain apex's, kinda liked the driving style of how I had the drag brake as before...
Has this happened to anyone, or how could I get back this drag brake effect without using the autobrake setting??
Jason Turner is offline   Reply With Quote
Old 03-15-2010, 11:21 AM   #468
syndr0me's Avatar
Trader Rating: 32 (100%+)
I'm not in love with the idea of blaming the sensors in the motors when all the other advanced timing ESC's don't seem to have the same problem.
Do Hall sensors come in different qualities? Is it possible some motor manufacturers use less expensive (and accurate/sensitive) sensors that are more problematic than others?
syndr0me is offline   Reply With Quote
Old 03-15-2010, 12:33 PM   #469
Jochim_18's Avatar
What is the actual degree of timing on the LRP X.12 13.5 motor?
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 03-15-2010, 02:08 PM   #470
Dusttt's Avatar
Trader Rating: 123 (100%+)
Selling my sxxtc cheap
new in factory sealed box $185 shipped US only
Dusttt is offline   Reply With Quote
Old 03-16-2010, 10:18 AM   #471
mac853's Avatar
Could somebody tell me when those MK3 version will start release in the market, please?
Will be those coming soon combos will come already with latest version?
Best regards
mac853 is offline   Reply With Quote
Old 03-16-2010, 11:14 AM   #472
JayL's Avatar
um, the tekin guys have been having this issue since v203 with certaiN brand of motor...
JayL is offline   Reply With Quote
Old 03-16-2010, 11:18 AM   #473
No it's not the same problem.
Most of the problems are because of to much timing.
The motors have a high standard timing and to much timing added will give problems.
This is not a timing issue with the SXX ss
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 03-16-2010, 12:27 PM   #474
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
Best regards
as of my knowledge all speedos that are shipped from now on will already have mk3 installed. if you happen to get an "older" version you can easily check on the power-up how many beeps you hear. if its 3 its ok. otherwise i am afraid you have to send it in to get it updated.
@tekins: i am quit positiv that with the tekins it is too much timing on the motors. but my tekin had other issues too (no brakes, power fades in the middle of the run etc), so i am guessing with the new speedos things are brought closer to the limits of the motors and problems arise. sadly.
vitomon is offline   Reply With Quote
Old 03-16-2010, 12:33 PM   #475
power fade is to much timing or over geared.
All setup issues.
With the new speedo's it's good to now what the motor can handle, the timing on the motor and the gearing to use.
Keep the timing under the 65 in total.
It can go higher but as you are to long above the 60 to 65 timing, you get power fading and a hotter motor.
So when you have a motor with a high timing on it, set it lower or don't set the timing in the speedo to high.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-16-2010, 12:52 PM   #476
JayL's Avatar
are you saying the tekin issue is too much timing? because that is one of the problems but inaccurate sensors is the biggest problem and reason not to run a certain motor. some of those same motors with the same timing happen to work fine, it is the sensor accuracy pure and simple
Old 03-16-2010, 12:58 PM   #477
Whit the Novak it was the steering servo that gave problems.
Also when they set a higher Boost with the Novak and the LRP motor, this gave problems.
I didn't hear of sensor problems.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
Old 03-16-2010, 01:09 PM   #478
syndr0me's Avatar
So there's a Mk3 now?
Old 03-16-2010, 01:21 PM   #479
rc pete's Avatar
Guys, in case you don't check the TC5 thread, I had great success with the SXX SS last weekend. Here's the race report:
http://www.redrc.net/2010/03/tozser-...ouring-champs/
My setup was:
LRP x12 13.5, 4-dot, 0-6-3-0, 7.45 FDR, 150 deg
LRP x12 17.5, 4-dot, 0-6-3-0, 6.00 FDR, 137 deg
This was with the new LRP fan assembly, which brings down the heat a lot.
I could have pushed it a little more to boost 4 and stayed within operating temps, but it was plenty fast at 3.
Most of the A-Main in both classes were some of the fastest Tekin guys in Western Canada, who have been tuning them all season, and my SXX SS was pulling most of them in both 13.5 and 17.5
Going from the SPX to this speedo, my 17.5 is now about as fast as my 13.5 was, and 13.5 is about a 7.5 or 8.5
Team Associated - Reedy - Pro-Line - RC Depot - OS Engines - 110% Racing - LD Graphics
rc pete is offline   Reply With Quote
Old 03-16-2010, 08:46 PM   #480
Trader Rating: 35 (100%+)
Josh Keller is offline   Reply With Quote
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
LRP Vector X12 StockSpec and SXX stockspec mac853 Electric On-Road 224 03-27-2010 02:54 PM
