Old 03-08-2010, 06:34 AM   #406
Trader Rating: 38 (100%+)
Originally Posted by chubbspeterson View Post
This was the setup for me, car was so fast, and had plenty of rip out of the corners. Also still had a little cog in the motor and "felt" like an old brushed motor to drive. It also had little to no fade over the 6 min mark, I fact I ran some pratice runs in the 7-8 minute mark before the car would fall off pace.
Was the cog mainly when starting from a stopped position? Mine seemed to stutter sometimes at the start. It's not a huge deal but noticeable.
or8ital is offline   Reply With Quote
Old 03-08-2010, 07:03 AM   #407
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
tim, i think he's talking about the drag off power (almost like brushed motors used to be). i ran the x12 (17.5) and if geared > ~6.5 it really had some off power drag (which can be good/bad depending on your preferences). the motor ran awesome all weekend, but seemed to get to 215* even when geared down. with that said, i too duplicated mike's 5.7 fdr and the car was a missile. i really like these motors so far...
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 03-08-2010, 07:06 AM   #408
Gotcha. Yeah I really love the feel of the x-12 motors.
Old 03-08-2010, 10:20 AM   #409
chubbspeterson's Avatar
cog, was off power, not a studder, just because the LRP magnets are so strong, it's like dragbrake, so it was perfect for light lifts to set the car into turns. Like lifting in the straight to setup to enter the sweeper, and then lifting again to finish the sweeper and 180 into the infield. Just a super stout motor. And no gtliches with the LRP motor and ESC also, what a great combo!
Mike Demone
7-Eleven, National Accounts Manager
Ridgemont, CA, 90026
"I vowed to never let this happen.."
chubbspeterson is offline   Reply With Quote
Old 03-08-2010, 11:54 AM   #410
Hey,
We seem to have the same problem as you. Do you find that sometimes it cuts out and wont even go? However when we get the SXX to go its fast
Does anyone know how to stop this? Any help would be appreciated.
Thanks alot Ben
youngben is offline   Reply With Quote
Old 03-08-2010, 12:14 PM   #411
Originally Posted by youngben View Post
Hey,
Thanks alot Ben
It has always started for me but sometimes there is a slight hesitation. Almost like it starts to go forward, then spins backwards for a moment then forward again. Kind of reminds me of what the tekin sensorless speed control use to do but this is not as bad. Once it gets going then all is good. It works normally most of the time, this happens just occasionally. This is with the MKII firmware.
Old 03-08-2010, 02:28 PM   #412
BLUE 2's Avatar
Trader Rating: 23 (100%+)
Talking
Originally Posted by StevenOlsen View Post
how is the speed compared with the other cars om the track both on the stregth and infield. and what is your settings on the ESC the gearing and temp sound like to be the perfekt combi for me, but try 7 in FDR, remember its not about the stregth speed if you lose to muck power infield
Hi
I run profiles 3-6-3 or 4-0 & 86/26 gearing on my Cyclone TC & the LRP internal temp check is 1 flash for Sxx Stockspec ESC & 5 for X12 motor , this is without a fan .
Cars Offroad : TLR 22B - TLR 22B 2.0 - TLR 22T - TLR 22SCT - TLR TEN-SCTE 2.0
Cars Onroad : HB Cyclone TC - TRF 416X - Tamiya TA05 - Serpent s411 eryx 2.0
BLUE 2 is offline   Reply With Quote
Old 03-10-2010, 09:25 AM   #413
syndr0me's Avatar
Trader Rating: 32 (100%+)
Anybody like to share ballpark settings for DUO-based 17.5 and 13.5 motors? How about SP 3.0?
syndr0me is offline   Reply With Quote
Old 03-10-2010, 01:46 PM   #414
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default 10.5 settings
Hi all..Wanting to know if any one can post a start setting for 10.5 nemissi/duo 2using the SXX stock speck..
Large fast track....
Please..as I dont want to blow motors/esc..
Using the SPX stock spec...FDR of 8.1 with duo 2 10.5..Xray-T3...
FDR of 8.4 nemisis 10.5..
Mike
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 03-10-2010, 05:54 PM   #415
hacker's Avatar
Trader Rating: 141 (100%+)
8 fdr is too high for spx I would imagine, thats in the region of tekin 203.
I would go 1 fdr higher to start with the sxx ss, but why dont you do all the testing and get back to us
hacker is offline   Reply With Quote
Old 03-10-2010, 10:52 PM   #416
JSmall's Avatar
Default Small issue
I installed my new SXX SS in my RT5 & SC and I'm having a small issue. Both of them are cogging/hesitating once or twice during a 6 minute run. It's like the brakes are being applied for a split second on power or off power. I called AE and they said I could send them back if I feel it is necessary. I love these things so far so I'm not wanting to send them back at this point. What I'm wondering is could my motors be the cause of the cog/hesitation?
SC - 24/78, 3*4*4*3, Orion V3 17.5 w/ two marks of timing
RT5 - 24/76, 3*3*4*3, Orion V3 17.5 w/ neutral timing
Small clay indoor offroad track. I've tried different timing marks on the motors and new sensor wires. I think I'm very conservative the "feel" and "boost" so I'm not sure if that could be the issue. Do you guys think I should send them back or try different motors to see if I can find one that works? I have a big race on the 20th so I would hate to not get them back in time.
Thanks for any help.
Jaromy Smallwood
Kyosho America l Peak l AKA l Portland RC Raceway
JSmall is offline   Reply With Quote
Old 03-11-2010, 01:51 AM   #417
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
Originally Posted by JSmall View Post
I installed my new SXX SS in my RT5 & SC and I'm having a small issue. Both of them are cogging/hesitating once or twice during a 6 minute run. It's like the brakes are being applied for a split second on power or off power. I've tried different timing marks on the motors and new sensor wires. Thanks for any help.
same problem here!! throughout a 5 min run the motor suddenly breaks for a split second twice or three times. also some times when i try to accelerate out of corners it takes a split second before the esc applies the command to the motor. very strange.
we tried different motors (x11 and speedpassion 13.5T v3) with more or less conservative settings 3-4-8-0 (speedpassion) and 3-4-6-0 (x11). gearing was in the 5.5 range and motors both came off after 5 min with approx. 60 degC. other equipment was:
sanwa m11 x
SXX SS
Speedpassion 13.5T v3
LRP x11 13.5T SS
LRP 5300 40C lipo competition line
i have tried to reach lrp about this problem, but no real answer to the problem yet. i hope reto can shine some light on these troubles since i am clearly not the only one having this issues.
at last weekend's ETS race in warsaw there were many people experiencing the same stuff.
vitomon is offline   Reply With Quote
Old 03-11-2010, 04:27 AM   #418
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
sanwa m11 x
SXX SS
LRP x11 13.5T SS
may i know what batch is your esc??
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-11-2010, 04:32 AM   #419
my SXX SS i think was from the first batch. however, i already sent it back to LRP before the first usage to get the mentioned MKII software installed from LRP. so in short, problems occured even with the new MKII software installed.
Old 03-11-2010, 04:58 AM   #420
Robert_K's Avatar
Deleted on request.....
Best Regards
Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
LRP Vector X12 StockSpec and SXX stockspec mac853 Electric On-Road 224 03-27-2010 02:54 PM
