Old 02-13-2010, 10:17 AM   #256
burito's Avatar
All combos will have MkII, but the combo's won't be released for a while now since there is a long backorder of speedos which will be shipped first. Combo's to follow after, this could mean end of February!
Reto Koenig
burito is offline   Reply With Quote
Old 02-13-2010, 10:23 AM   #257
mac853's Avatar
Thumbs up
OK, thanks!
mac853 is offline   Reply With Quote
Old 02-13-2010, 10:49 AM   #258
jdm19turn's Avatar
The "MkII" speedos are on the way to USA since yesterday, they will arrive there soon. This is actually the first regular production shipment as only a few dozens were sent for Snowbirds anyway, so if you have a speedo on backorder somewhere now there is an almost 100% chance that you'll get "MkII".
Thanks burito looking forward to getting one when they arrive soon
mi4 ,mi5
jdm19turn is offline   Reply With Quote
Old 02-13-2010, 12:10 PM   #259
jonest's Avatar
I do hope some of them would land Asia!!!
jonest is offline   Reply With Quote
Old 02-15-2010, 08:35 AM   #260
jrxs-r's Avatar
Got me arse handed over to me over the weekend by Tekin guys... Need the LRP SXX SS ASAP....
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 02-16-2010, 02:18 AM   #261
alecladanga's Avatar
+1
alecladanga is offline   Reply With Quote
Old 02-16-2010, 04:22 AM   #262
Blueman Austria's Avatar
Hy There!
I have an SYY SP from the first batch, and it works well.
Now i switched over from an X11 Stock spec 13,5 to an SP V3 13,5 motor, and as i tested the motor attached in the car but without the pinion on, i noticed that if i hit the throttle half the way and hold it in that position, the rpm of the motor is not flat. it sounds like an old brushed motor with an issue on the armature or the brushess. Also if i turn it to the maximum, there where no change.
The settings on the motor where feel 5, and boost also 5.
As i turned of the boost completly, it was as you expect it. a normal flatline rpm sound.
Is this the adaptive inteligent LRP Software wich detect that the motor have no mass to move? or is it an issue of my speedo?
Can anyone of the SXX SP owners test it?
THX Rainer
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 02-16-2010, 05:17 AM   #263
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
rcmodel have it in stock
usd240
Give the best while u can !
kschu is offline   Reply With Quote
Old 02-16-2010, 05:32 AM   #264
Trader Rating: 10 (92%+)
not anymore
captain stacker is offline   Reply With Quote
Old 02-16-2010, 08:45 AM   #265
StevenOlsen's Avatar
Default suggested gear ratio
hi just tested my new SXX stock spec and its a rocked comparred with the SPX I inproved 2/10 after just 6 batteries and was 1/10 faster then anybody other on the track that day
but im sure that there is more in the regulator. i have it in profile 3,10,10,0 with my SP v3 17.5 and lipo and the power is insane halfway done the stragth the RPM explodes.
but the motor is hot 60* celsius / 140* fahrenheit. after 6 min racing. i have gear the motor down from 5.25 til 6.16. not sure if i should turn down the regulator and gear higher can anybody help
can't find the gearing guide for the SXX SS. that would help alot.
steven
Steven Olsen
CAR: Awsomatix A700L.
Nosram 7000 Batteries.
Nosram Comet HD ESC.
Nosram Pure 2 evolution Motor.
StevenOlsen is offline   Reply With Quote
Old 02-16-2010, 09:33 AM   #266
Send a message via MSN to Bro0100
Default Temperature
steven
Hello Steven,
think 60 is not hot at all! i would sign for a motor that stays 60
70-80 degrees Celcius is normal!
90-100 Celcius is to much..depending on which motor you use.
Kind regards, Vincent
Bro0100 is offline   Reply With Quote
Old 02-16-2010, 10:37 AM   #267
+1 60 is cold just below sweet spot imo
Burney is offline   Reply With Quote
Old 02-16-2010, 12:04 PM   #268
for my the motor is hot is was only about 40* celcius with the SPX
Steven Olsen
Old 02-16-2010, 12:14 PM   #269
That's cold very cold.
You can easily let it go up to the 80*.
You will see that you will go also faster. The motor runs better on a higher temp.
Keep 80* as the max.
I always try to run around the 70 to 75*.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 02-16-2010, 12:24 PM   #270
mac853's Avatar
Questions??
If is necessary using cooling fan in this SXX stock spec esc if running with 13.5 motor?
Best regards
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
LRP Vector X12 StockSpec and SXX stockspec mac853 Electric On-Road 224 03-27-2010 02:54 PM
