Old 02-11-2010, 10:19 AM   #226
ByteStream's Avatar
Originally Posted by EAMotorsports View Post
Drew Ellis ran them at the birds in all his cars and was fast. Joe Trandell ran them in his cars and he almost won 12th 17.5 (probably most competitive class there) and Chicky was fast with his in all classes as well. I think the main reason you didnt hear a lot about them is quite a few people bought them and were waiting to put them in and heard of a few guys having stuttering problems and returned them to the shop. Those that did run them really liked them. I also ran one in my TC and tested in my 12th scale as well. It was too late in the week to run it in my 12th scale the whole time as I didnt have time to figure the gearing out. But in TC it had the best throttle response and feel of all the speedo's I tried (Tekin, AE, LRP).
EA
For your 1/12 scale testing, did you run without a booster/rx pack? If you did, wondering what your thought and if you noticed any issues without the booster/rx pack.
ByteStream is offline   Reply With Quote
Old 02-11-2010, 10:22 AM   #227
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Yes I ran with no booster or receiver pack and I know Drew Ellis ran this way in 10.5 all weekend as well with no issues.
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 02-11-2010, 12:14 PM   #228
Stein Tumert's Avatar
Originally Posted by Apex View Post
For mod sedan 2s lipo, is it best to run the SXX TC Spec or will the SXX Stock Spec be fine?
For mod you should use the SXX TC Spec
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 02-11-2010, 12:17 PM   #229
Originally Posted by mrrcguy View Post
Thanks. Now though, the question is what can we expect in terms of added performance. I find it frustrating that I have found no mention of this new ESC being able to perform on par with its competitors. Have there been no successful tests? I have been loyal to LRP for a very long time and want to continue this, but I hate to be let down again as I was with my two SPX's. Come someone give us some real world info on the performance gains if any.
The SXX SS has won the last two big races in Europe (DHI cup and last ETS round)...
Stein Tumert
Old 02-11-2010, 12:28 PM   #230
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
what is the motor limit on the SXX Stock Spec? is it the same as the SPX??
Old 02-11-2010, 12:39 PM   #231
chicky03's Avatar
Send a message via AIM to chicky03
Originally Posted by or8ital View Post
Didn't they place well at Snowbirds? Several podium finishes?
Stock 12th
2nd
WGT
1,2,5,6,9
Rubber 13.5
2,6
10.5 12th
1,3,4,8,9,10
mod rubber
2nd
Pretty much all the speedos that were at the race we in the A main. There were some for sale at the hobbyshop but I don't know how many of them actually ran the speedo at the event.
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 02-11-2010, 12:42 PM   #232
go to www.lrp.cc and you can find the spec there (look in the 2010 catalog they have online)
Stein Tumert
Old 02-11-2010, 04:43 PM   #233
mutley001's Avatar
Originally Posted by mutley001 View Post
Hi Guys
I'm in need of a starting point with regard to profiles and gearing for 10.5running rubber TC indoors on carpet approx 80' straight. - I'm hopefully picking up my ss at a club meeting tonight!
Paul
Well got hold of the SS and ran it tonight:-
As suggested I kept the factory settings for "Feel" and "Boost" at 3 and the car was like a rocket but boy does the motor get hot (118*C!!!!) I didn't want to risk increasing the profiles.
In an effort to reduce the temps I reduced the timing on the motor to -10* (4 dot insert) and geared it at 8.01 FDR on a track that flows well and has a 80foot straight (Maritme Raceway in Chatham Kent - Don't know if you know it at all) but this only took the temps back to 109*C
The ESC performed flawlessly but i was just concerned about the motor temps and if there was maybe a better setup to try? Should I alter the gearing even further, maybe try closer to 9.0 FDR? (I was running 6.9 with the SXX TC Spec ESC and this motor with temps at 79*C in the same car).
What are your thoughts guys? - I can't be the only one running the SXX SS with 10.5 X12 in TC any one else had any experiences yet?
Thanks for the PM Alex but that sounds a bit scary running those profiles considering the temps I was getting at 3!
Cheers
Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 02-11-2010, 06:00 PM   #234
AE-Reedy
Cheers
Paul
When we were testing we also saw the high motor temps. Installed a fan and the motor dropped 50F. I was very surprised that it made that big a change. I think that with the way the SCs and motors are running now it will be a necessity to have a fan on the motor.
The 0000 dot timing is needed when using the SXXSS and I think you are fairly close on gearing. Gearing down will not drop the motor temps much if at all. Once we started running the fan we actually were able to start gearing up and the motor still only ran 165F. We wired the fan directly to the main battery not through the rx, more voltage= more airflow.
Sean Cochran is offline   Reply With Quote
Old 02-11-2010, 06:16 PM   #235
hacker's Avatar
Trader Rating: 141 (100%+)
50f drop is huge just by installing a fan.
ive been playing around with fan setups lately, 2x 25mm, 1x 40mm hard wired directly to batt and best I got was around 10f drop.
what sort of fan are you using?
hacker is offline   Reply With Quote
Old 02-11-2010, 07:07 PM   #236
M-Technic's Avatar
Trader Rating: 15 (100%+)
Where do you guys place the fans? Behind the motor, blowing towards it?
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 02-11-2010, 07:12 PM   #237
Hi Guys...I have a MK1 from GS Hobbies(snowbirds?)Yes it does stutter at times.As I bought it from the US(I am in Australia) do I send it to the US distributor or Germany?
As for perfomance...I run 17.5 rubber on Tarmac...with the SPX I was running 48.69 rollout...I went down to 36.1(7 teeth on 48 pitch)I am still testing but with feel and boost at10!! it was as quick as another guy with a tekin but looked smoother.I run an LRP heatsink fan on the motor and it temped at a max of 60 degrees.will let you know after futher testing and a race or 2.
Barger is offline   Reply With Quote
Old 02-11-2010, 07:16 PM   #238
Trader Rating: 38 (100%+)
I use this fan (below) mounted behind the motor blowing at it. I've never gotten a 50 degree drop. I can get 40 with it plugged directly to the battery. Through the receiver it drops it about 30-35 degrees.
http://www3.towerhobbies.com/cgi-bin...&I=LXUDN1&P=FR
or8ital is offline   Reply With Quote
Old 02-11-2010, 07:40 PM   #239
Trader Rating: 16 (100%+)
Can the tc spec or stock spec run sensorless motor?
ronaldo-1234 is offline   Reply With Quote
Old 02-11-2010, 08:04 PM   #240
Scott B's Avatar
Trader Rating: 43 (100%+)
Nope!!!
Does anyone know when we can expect the next batch in the US??
Thanks,
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
LRP Vector X12 StockSpec and SXX stockspec mac853 Electric On-Road 224 03-27-2010 02:54 PM
