Old 02-07-2010, 12:31 PM   #196
Three's Avatar
Superior Hobbies (dot com) has some SXX Stock Specs.
Electric good..........
Three is offline   Reply With Quote
Old 02-08-2010, 06:25 AM   #197
hacker's Avatar
Trader Rating: 141 (100%+)
so how is the sxx stockspec any better than the sxx?
both have 10 step timing profiles?
is profile 7 on the sxx the same as profile 7 on the stockspec?
hacker is offline   Reply With Quote
Old 02-08-2010, 07:39 AM   #198
Stein Tumert's Avatar
No...go to www.lrp.cc and check out the spec.
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 02-08-2010, 07:52 AM   #199
Trader Rating: 38 (100%+)
What settings are being used with this speedo and the x12 17.5? thanks.
or8ital is offline   Reply With Quote
Old 02-08-2010, 08:09 AM   #200
chicky03's Avatar
Send a message via AIM to chicky03
4 dot timing on the motor, speedo settings 2,6,5,0. 5.50 final. May need to up up or down on the final depending on the track.
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 02-08-2010, 08:11 AM   #201
Thanks Chicky! Should have mine mid-week. Can't wait to try it out.
Old 02-08-2010, 08:27 AM   #202
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Wow have to retard the timing with this speedo too?
Rod
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 02-08-2010, 08:55 AM   #203
Trader Rating: 114 (100%+)
Rod
4 dot is -10 ... But it is actually 28-32 degrees of actual motor timing. Equivalent to Novaks 0 setting which is actually 30 degrees.
Chris Furman is offline   Reply With Quote
Old 02-08-2010, 11:20 AM   #204
jonest's Avatar
Hi Reto,
Just watched LRP Toyfair video and the "TOUCH" is definitely a cool charger to look forward. The most interesting feature on this charger is the ability to check our brushless motor RPM, and I do hope it could show us more info.
Thanks.
jonest is offline   Reply With Quote
Old 02-09-2010, 03:28 PM   #205
Me_MrTyson's Avatar
Send a message via MSN to Me_MrTyson Send a message via Skype™ to Me_MrTyson
Has anyone had time to sweet spot setup LRP ss with 10.5, running both Novak Ballistic and LRP x12
My LRP don't arrive till the end of the week and don't really fancy blowing it up at the first outing
Alex
Team losi racing // v-dezign // black diamond
Me_MrTyson is offline   Reply With Quote
Old 02-10-2010, 02:20 AM   #206
Me_MrTyson's Avatar
Another question,
Just been reading the manual and the following information popped up.
Manual says:
Rec. Motor Limit with 5 cells over 4.0T
Rec. Motor Limit with 6 cells over 4.5T
My question is what is the limit for 2s lipo and 1s lipo???
Alex
Old 02-10-2010, 03:12 AM   #207
Alex
Most of us just run one motor at a time per the rules!
Old 02-10-2010, 04:41 AM   #208
CraigM's Avatar
Trader Rating: 34 (100%+)
that's awesome
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 02-10-2010, 05:41 AM   #209
Another question,
Manual says:
Alex
It would be safe to assume that for 1s, nothing greater than 4T. 2s lipo is just like 6 cells. And if you are going to be running a motor that hot you shouldn't be running this speedo anyways. Are you trying to launch your car to the moon??
Old 02-10-2010, 07:36 AM   #210
chicky03's Avatar
Alex
I am not sure about the novak motor but you can probably start the same place as the X12.
For 1/12 1S X12 10.5, 4dot timing, speedo 0,7,6,0 33/88 43mm tire.
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
LRP Vector X12 StockSpec and SXX stockspec mac853 Electric On-Road 224 03-27-2010 02:54 PM
