LRP SXX StockSpec ESC
#166
#167
what motor best suits this animal?
i need a new 13.5 motor for next weekend
cheers
cheers
#168
Do these speed controls have boost and turbo like the tekin?
#169
Hi,
I need advice before I return my SXX StockSpec back to LRP for repair
Just purchased and installed my StockSpec with a X12 13.5. When bench testing with no pinion connected, seems like the motor has interference and 'splutters' through the rev range to full power. Tried a SP 13.5 V3 motor and the same happened. Sorry to say, but reconnected by existing ESC and the motor ripped !
I've heard of the issues with the 1st batch (which seems I may have ) but I've also heard that this may be the normal charactoristics of the StockSpec when running the motor with no load.
If anyone has had the same experience or can shine any light on what the exact production issue is on the first batch released, then it will help me understand if my ESC is faulty or just how it is ?
Cheers,
Jason
Cheers,
Jason
#170
Send motor and speedo for repair.
#171
Hi,
Cheers,
Jason
Cheers,
Jason
#172
anyone running theres and actually getting it to work yet?
what sort of gearing/ modes have you found that work ?
cheers
cheers
#173
I've got about 8 packs through mine with zero issues, I guess I got lucky (had to happen sooner or later)?
Here are two posts dealing with 17.5 and 13.5 settings.
As a side note, I notice if I do a "white trash tire wipe" (I.e. hold the car on the carpet and pull the trigger) it will stop after a few seconds almost as if there are some "don't be stupid" fail-safes built in.... I wonder if some of the bench free-wheeling is triggering these as well? Or perhaps I have just discovered another defect?
And just for the record, my gear is; Airtronics FHSS-3 receiver with an Airtronics 94746M Digital servo, and X-12 motor (I know some Tekin guys are having fits with certain gear combinations).
Mike Slaughter
#174
in 13.5 world gt i ran 33/88 with a 2.08 tire . Settings were feel 10 boost 7 , I ran the x12 13,5 with 4 dot timing.
Hope this helps
in 10.5 i ran 32/88 with a 1.70 tire settings where feel 7 boost 6 and i ran the x12 10.5 motor with 4 dot timing.
Hope this helps
#175
So there is boost and turbo with these? But no needed laptop or something to program it?
#176
It is called feel and Boost. The feel is the initial throttle and has a value of 1-10 and the boost is the timing advance. It also go's from 1-10 . I personally like between 6 and 8 for the boost and 7 -10 for the feel. I am still learning gearing and stuff . It is all push button like the other LRP speedcontrols.
Mike
Mike
#177
Mike
Mike
any word on when the new batch of SXX Stock Specs are gonna released?
- Chris
#179
will this speedo be lrp's answer to the tekin rs pro?
