Old 01-29-2010, 03:16 PM   #136
Originally Posted by Chris Furman View Post
Anyone running X12 motors?
Most running Lrp stockspecs are running x12's
TEAM ASSOCIATED==REEDY==LRP==FACTORY TEAM==COMPETITION ELECTRONICS==JACO RACING TIRES==SPEKTRUM==DYNAMITE== PROTOFORM==KIMBROUGH==REILLY PAINT WORKS==Sxt
walterhenderson is offline   Reply With Quote
Old 01-29-2010, 03:27 PM   #137
Trader Rating: 114 (100%+)
Got my StockSpec... Rick and Burito.. Please check your PM and reply.
Thanks.
Chris Furman is offline   Reply With Quote
Old 01-30-2010, 07:06 AM   #138
Stein Tumert's Avatar
SXX SS number 1 & 2 after three rounds of qualifyings at the ETS
http://www.myrcm.ch/de/ets/29012010_...ock/index.html
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 01-30-2010, 07:49 AM   #139
bigz's Avatar
Originally Posted by burito View Post
@Robert: yes, there will be a Nosram version as well (Pearl SpecRacing #90910). Should be available end of February.
@Stein: first lot went to USA (for Snowbirds) and now backorders will be fulfilled, but it may take several weeks until they're available worldwide unfortunately!
@krat: when using a fan, and you stay with boost profiles 0-2, the motor limit is identical as SXX TC. So it's ok to use 3.5t with 5-cells, as I don't think this is what you plan to use with LiPo's...
need the nosram version.
Hot Bodies - Nosram - Tekin - Speed Passion - Futaba - Sorex - RIDE
bigz is offline   Reply With Quote
Old 01-30-2010, 08:14 AM   #140
bigz's Avatar
Burito - great news! Can't wait to see them in the USA! There are Tekins here everywhere!
yep, those tekins are killing us here in the pi.
Old 01-30-2010, 12:34 PM   #141
Originally Posted by masterhit View Post
Now where's the animated smileys that say; "This thread is worthless without FDRs, roll-outs, and speedo settings"?
Anyways, if available Rick it would be greatly appreciated if you could get some of the above information from the team for the Stock Spec and X-12 (13.5) motors.
Thanks,
Mike Slaughter
7 feel
4 punch
6.35 ratio
Old 01-30-2010, 01:29 PM   #142
this X12 motor is a different beast.
X12 17.5 starting point would be great also.
Old 01-30-2010, 03:52 PM   #143
masterhit's Avatar
Trader Rating: 15 (100%+)
Originally Posted by walterhenderson View Post
7 feel
4 punch
6.35 ratio
Thanks Walt! I appreciate it.
Mike Slaughter
masterhit is online now   Reply With Quote
Old 01-30-2010, 04:00 PM   #144
masterhit's Avatar
This is what I ended up with today..... I was only able to get 4 runs on it today, but better than nothing 'eh?
Feel 5
boost 6
5.85 FDR
4 dot timing....
Not saying it is the end all, but it was wicked fast, 180s with 1 30mm fan, 95'ish straight fast layout.
Your milage may vary....
Mike Slaughter
Old 01-30-2010, 04:07 PM   #145
Feel 5
boost 6
5.85 FDR
4 dot timing....
Mike Slaughter
Wow... that is a LOT of timing... 4 dots is close to 50 isn't it? I believe 1 dot is 28-32 degrees.
Old 01-30-2010, 04:11 PM   #146
masterhit's Avatar
4 dot is -10 on the motor from whatever mystery number 2 dot is.....
EAs' take on it is that 4 dot is 28-32 (as you noted), which would put 2 dot at 38-42, and 1 dot at 43-47ish.
Mike Slaughter
Old 01-30-2010, 04:15 PM   #147
4 dot is -10 on the motor.
Mike Slaughter
I heard on the forum here that 4 dot is in fact -10.. but the 4 dot timing actually was 28-32 degrees of REAL timing.
Burito, Rick - anyone can confirm?
Old 01-31-2010, 02:03 AM   #148
For my fellow Europeans, looks like the first batches hit the Ebay stores in Germany for 219 Euros.
US price that I've found so far is 240 $ = 175 Euros
But it looks like the US stores are already waiting on the 2nd batch since
the 1st batch went to the pre-orders.
Buying as I type
stical is offline   Reply With Quote
Old 02-01-2010, 11:39 AM   #149
JayL's Avatar
Originally Posted by Apex View Post
Does LRP even sponsor stock on-road racers in the U.S.? I don't know of any at my local track. It's probably a good thing they aren't seeing how ROAR is making the stock class a true stock class.
Most Associated drivers are LRP
JayL is offline   Reply With Quote
Old 02-01-2010, 12:09 PM   #150
Trader Rating: 38 (100%+)
I don't think Associated sponsors any stock drivers though.
or8ital is offline   Reply With Quote
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
LRP Vector X12 StockSpec and SXX stockspec mac853 Electric On-Road 224 03-27-2010 02:54 PM
