Old 01-06-2010, 01:12 PM   #1
Chickentrader's Avatar
Default Which motor is practical to sue in Pan Cars?
What is the the fastest motor that is practical to use in electric pan cars? There is a discussion about this in my club, and some say that 5 turn brushless is being used without problems; while others think that 13.5 turn is probably as fast as the car can handle and still be drivable. What is the consensus about this; can anyone help?
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 01-06-2010, 01:18 PM   #2
oeoeo327's Avatar
Trader Rating: 74 (100%+)
That would depend on the track size, surface, and configuration, along with how much voltage you'll be using. On the larger tracks in Europe, 1/10th scale 9.5T 2S cars are common (I believe they call this configuration the Pro 10 class).
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 01-06-2010, 01:24 PM   #3
MikeXray's Avatar
Trader Rating: 73 (100%+)
how many chickens can I get for the right answer?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-06-2010, 01:35 PM   #4
Default pan car
Guys have run 3.5 brushless in 2 cell lipo=open mod
very few can drive them but it is a treat to watch the very best do it.
wrench is offline   Reply With Quote
Old 01-06-2010, 02:15 PM   #5
SammyZ's Avatar
Trader Rating: 138 (100%+)
none
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 01-06-2010, 02:58 PM   #6
2wdrive's Avatar
the cars can handle as low as 2.5t but the problem is that you can't get the rollout to work and you will dump in less then 5 minutes.
Over here the pro10 modified usually drive with 7t delta's, 4.0-5.0t star or mamba max 7700 but even with a 7t delta or 4.0t star some drivers dump in less then 5 minutes. This is on big 1/8 gastracks.
They use nitro high downforce bodies like the porsche 962 and lola's to get the power to the ground.
In the pro10 10.5t which we have here in the netherlands as a stock class many use the medium downforce bodies like the nissan p35 or peugeot 905 to get more speed and less strain or heat on the motor. In germany they use 9.5t in stock. Speeds with a stock 10.5t on a track with 330ft straight will get as high as 55mph.
For indoors we use the 200mm pancars with 13.5t and 2s. This is fast enough for indoor use. In germany and swiss they also use the 200mm pancars outdoor with the 13.5t in it's own 200mm class.
Hope it helps you out
2wdrive is offline   Reply With Quote
Old 01-06-2010, 04:14 PM   #7
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
Check Stranahan's threads. He's gone into a LOT of depth about the motors, speed controls, gearing, downforce, etc.
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 01-06-2010, 08:51 PM   #8
Our club in Victoria, Canada, regularly runs Pro10 (2S 10.5BL) cars on a prepped parking lot. For racing its one of our closest racing since it can be difficult to get the power down to the ground. They are also a touch faster then the 1/10 nitro cars too.
Shawn.
Shawn68z is offline   Reply With Quote
Old 01-06-2010, 09:17 PM   #9
Originally Posted by Chickentrader View Post
What is the the fastest engine that is practical to use in electric pan cars?
Just for the record..... engines are powered by fuel, motors are powered by electrical current.
John Warner is offline   Reply With Quote
Old 01-07-2010, 04:34 AM   #10
As many as you want, just tell me, and don't forget to send the address so I can tell them where to fly to. But first before I tell them; what is the right answer?
Kindest regards,
Lars.
