Old 09-12-2010, 06:29 PM   #31
venom54's Avatar
Default MORE RESULTS
Well another Sundays racing has passed and the more we run the XPS the more we discover!
Over a six minute race on a tight circuit with limited long big straits with more testing every day the better the results we get.
This time around the results are : One of my better runs.......I'm too ashamed to show the crappy ones . Driver needs coffee!
Renato 20 laps, 6m 6.002s, 18.238 best avg, 17.343 best single, 0.76 cons, Personal Best 3rd.
The result is still only good for a B main finish as having to get to drive against others using ESC's with Turbo and Punch equipped is a challenge but rewarding. The track layout is shown below for reference.
Getting better results with better driving and better setups on the ESC. Which are as listed below.
Car : Serpent S400, dialed. Honestly it was! Driver needs to get his act together!
ESC : XPS Sport, super smooth.
Motor : Tekin 17.5 with timing wound up to 24 DEG
ESC settings :
1-1
2-1
3-3
4-1
5-6
6-4
7-2
8-9
9-9
10-3
11-45
FDR used on this track 7.39 with Mazda 6 body. Temp after last run 75 DEG. ESC and motor were both running fans. Air temp 17 DEG. Surface 24 DEG. Batteries used with similar feel and available power Bionic 4000 40C and YUNTONG 5000 40C. Capacity accepted on recharge after runs 50% of original capacity.
Next new update will be hopefully a run using the TEAM POWERS motors.
Until then.
Cheers
Ren
Play hard but be nice to your parents!
VBC RACING|ASSOCIATED|XRAY|TEAM POWERS|THUNDER TIGER|HOBBYWING|HPI|WTF FANS|ORION AND MORE IN STORE.
145 COMO PARADE EAST 3195 PARKDALE VICTORIA AUSTRALIA.
www.rabhobbies.com.au
venom54 is offline   Reply With Quote
Old 10-08-2010, 05:47 AM   #32
venom54's Avatar
Default XPS SPORT
Well it had to happen.....finally a 21 lap heat.
Details tomorrow.
Cheers
Ren
Old 10-08-2010, 06:08 AM   #33
Marston model car club are holding the very first Team Powers GP. All information is availiable at our club website Marstonmcc co.uk
Cocoon is offline   Reply With Quote
Old 10-12-2010, 07:54 PM   #34
venom54's Avatar
Details tomorrow.
Cheers
Ren
Car : Serpent S400, dialed. Honestly it was! Driver needs to get his act together! He did this time.
Motor : Team Powers 17.5 with timing wound up to +2 DEG
Date 26/09/10
5th 5 Renato Benci
21 * 6m17.669s 17.899 12.898 1.44 Personal Best 5th
ESC settings :
1-1
2-1
3-3
4-1
5-6
6-4
7-2
8-9
9-9
10-3
11-45
FDR used on this track 5.5 with Mazda 6 Louise RC body. Air temp 20 DEG. Surface 28 DEG. Batteries used with similar feel and available power Bionic 4000 40C and YUNTONG 5000 40C. Capacity accepted on recharge after runs 50% of original capacity.
Running the same setups as above with a TEAM POWERS 17.5 and a FDR of 5.5. Temping motor was showing 64 Deg with goods infield speed and a well setup chassis allowed good constant laps to clock the 21 lap pace with the XPS and Powers 17.5.
Cheers
Ren
Old 11-12-2010, 05:11 AM   #35
schmutz's Avatar
Send a message via ICQ to schmutz
Hey Everbody,
TEAM-POWERS XPS EL Bruhsless Speedo is now avaiable.
Item no. TP-XPS/EL
Features:
* Support with all kinds of sensored/sensorless brushless motors in RC model 1/10th, 1/12th Car & Truck
* Support Running Mode: Forward with brake, Forward/Reverse, Forward/Reverse with Brake
* Manual/Factory running profile setting. For factory running profile, it includes 9 level for modify race and 4 levels LCTS (linear control timing system) for race competitions
* Use the pocket-size program card to program the controller settings
* Multiple protection functions: Low voltage cut-off protection, Over heat protection, Throttle signal loss protection
* Extra smaller size aluminum casing for cooling
* Extra battery output adaptor connecting to the motor cooling fan
Specs:
Continuous current: 35A
Burst Current (10sec): 160A
Battery Input: 4,8 - 7,4 V
BEC Output: Linear 6V/2A
Weight (not included wiring & fan): 40g
Dimension(L x W x H) mm
(Include the fan assembly to the ESC): ~32 x 30 x 28
Motorlimit: Over 9,5 Turns
News and more Informations about the XPS Pro Speedo soon
Marcel Schmutzler
Raceport / TEAM-POWERS / T.O.P. Racing
http://www.youtube.com/user/Raceport
www.raceport.net
schmutz is offline   Reply With Quote
Old 01-24-2011, 01:18 PM   #36
Conrad's Avatar
^^ I've got one of them, it isn't fitted yet but it's a nice little speedo, machined alu case, even the switch is in a machined alu case. There is even a spare fan connector built in to the esc Testing will commence soon.
Swith Racing [www.swithracing.co.uk]
Conrad is offline   Reply With Quote
Old 05-22-2011, 09:21 PM   #37
iPearl's Avatar
Trader Rating: 96 (100%+)
Send a message via AIM to iPearl Send a message via MSN to iPearl
The ESC Totally exposed Naked and NUDE !!!
Sorry Steve -_- I couldn't help it xD (Best regards from Houston)
But no worry Its 100% Functional after Reassemble !!!
And no I will not send it in for Warranty ROFL, Love this lil bugger too much at the moment, bc it works so well.
The ESC is very smooth !!! I was able to make as Punchy as Tekin or super smooth as a Speed Passion (RS and 2.1GT which i own)
Heat wise the case will tell you know its true internal Temps since it directly transfers them outwards, making the ESC being able to withstand hotter temps than other plastic case ones. And the fan will be able to cool the ESC better. Especially how its build.
The Field Programmer is definitely Higher Quality It Even Beeps at you, once you set your settings. The handheld programmer is better than than Speed Passions latest Field Programmer(Which is complete Useless in quality, they should have stayed with GT2.0 style programmer and USB adaptor). Feels very SOlid and compact and doesnt fall apart like SP newest.
What i am wondering is if this esc is able to access the ramping and turbo just like the RS compared to the RS Pro in teh future. Which would be awesome. And maybe Firmware updates with a USB programmer that be awesome also.
But then I understand that this unit suppose to be for Sport level.
Cant wait to get my hands on the Pro version !!!
We are still finalizing testing of the team powers motors LOL
Then more insight on this ESC, But so far I am Loving it for its price and Quality.
So Far Optimizing it for a small tight track, it can keep up with Speed Passions RS And any other ESC out there as long its not turboed. And again I do hope in the future the Sport being able to do turbo also. Like the RS in the Tekin like being able to utilize turbo also but you just cant go as low in turns as with out turbo.
Design Of Things !!!
iPearl is offline   Reply With Quote
Old 05-22-2011, 10:11 PM   #38
vr6cj's Avatar
Trader Rating: 124 (100%+)
So, who sells these in states? Is pro out yet? Only saw the el and sport on there websight.
vr6cj is offline   Reply With Quote
Old 05-22-2011, 11:41 PM   #39
soon. Getting the motor roar approved. New ESC coming out end of this year, with more features (boost, turbo etc etc)
cheapskate.brok is offline   Reply With Quote
Old 05-23-2011, 12:12 AM   #40
iPearl's Avatar
The Pro will be out later this year.
I think they trying to get the software right to comply to Roar Rules.
At the moment only EL and Sport are available.
But even the sport is well worth it !. This case is like solid Metal its awesome !
Old 05-23-2011, 03:05 AM   #41
iPearl's Avatar
Originally Posted by engine.tech View Post
it is good if anyone can share more about the setting about TP motor with TP XPS Sport!
Below are images of the Plutonium Motor V1 17.5t
I am actively Running and testing a Plutonium 17.5t 12.5mm Rotor V2 Sensor.
With my Team Powers ESC Sport. And i definitely love the power output and smoothness. If you get a low turn motor the stock rotor is Fine but if you want to run stock with a 13.5-17.5 i advice 12.5mm rotor. I have never used Higher turns beyond that so i can not comments on 18.t and up. From what i seen other people say the fast 6.t etc etc run fine as is.
http://img.photobucket.com/albums/v2...C/DSC04857.jpg
http://img.photobucket.com/albums/v2...C/DSC04864.jpg
http://img.photobucket.com/albums/v2...C/DSC04865.jpg
Old 05-23-2011, 10:49 AM   #42
All Team Powers motors, both the Spurt version and the Plutonium versions are currently ROAR approved with the exception of the Spurt 21.5, Plutonium 10.5, 13.5 & 21.5. These will be ROAR approved this year. As for the Pro version speed control, we are hoping to get the first units for testing by the end of June.
Any questions or orders for any of the Team Powers products in the USA, please contact [email protected]
Crashby is offline   Reply With Quote
Old 05-23-2011, 11:15 AM   #43
thanks man for clarifying! Is there a ROAR list with the Plutonium in it? thanks again!
Old 05-23-2011, 10:36 PM   #44
Here is the link to the ROAR approved brushless motor website. You can download into an excel file that you can sort if you like.
http://www.roarracing.org/?page_id=251
Old 05-20-2012, 02:45 PM   #45
Trader Rating: 17 (100%+)
I ave the pro version and using it in my Durango des 210 2wd buggy. Any advise on where good plcto strt with all h settings? I'm running mod reddy 9.5 motor.
meddman is offline   Reply With Quote
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Hobbywing ESC's Drift_Buggy Radio and Electronics 827 03-30-2016 11:43 PM
ESC's Motors, Xray T2 008-009 parts Yokomo_Ant3 Australia For Sale/Trade 12 05-17-2009 12:58 AM
Best sensorless ESC mac853 Electric On-Road 30 04-24-2009 11:21 AM
