Old 01-02-2010, 11:29 PM   #1
RussB's Avatar
Send a message via MSN to RussB
Default LRP SPX trouble...
Please help me diagnose what is wrong with my LRP SPX.
The motor would turn with no load on it when the trigger is pulled, i.e. wheels off or wheels on but car on a stand.
When on the ground, the car needed a push start and was very slow.
Is this overheated, blown, or something else?
RussB is offline   Reply With Quote
Old 01-02-2010, 11:36 PM   #2
Trader Rating: 88 (100%+)
Default Cable
Is the sensor wire okay? I had some similar issues a while back and some of the wires going into the plugs of the sensor wire had snapped off. Just a guess though I could be way off.
tcdrvr2 is offline   Reply With Quote
Old 01-02-2010, 11:38 PM   #3
RussB's Avatar
that was one of the theories... i tested a different motor and it did the same thing. unless there's an internal connection problem.
Old 01-02-2010, 11:39 PM   #4
whoopass's Avatar
sounds like a classic case of 'cogging'. like before check the sensor wire on the motor/esc. but first to rule out the ESC, swap the motor and sensor wire.
whoopass is offline   Reply With Quote
Old 01-02-2010, 11:40 PM   #5
But did you swap the cable? Mine was at the end of the cable itself, hard to see because there's not a lot of play due to all the other wires.
Old 01-02-2010, 11:43 PM   #6
Toh WL's Avatar
See the manual, there are steps to reset the config on the ESC. Try that with motor & sensor cable. See if it works.. If not you have to sent in to LHS for warr claim if within 120days.
Toh WL is offline   Reply With Quote
Old 01-02-2010, 11:47 PM   #7
Toh WL's Avatar
One thing I forgot, the throttle trim on your Tx. If it set on reverse. Surely you experience extremely very slow forward push. Make sure set to neutral.
Old 01-02-2010, 11:52 PM   #8
STLNLST's Avatar
Trader Rating: 21 (100%+)
Looks like you're not racing tomorrow
STLNLST is offline   Reply With Quote
Old 01-02-2010, 11:54 PM   #9
RussB's Avatar
e-mail me punkass... [email protected]
i'm trying TO race tomorrow. these problems happened at the SWR cup back in May.
lrp spx stock spec chuckharrisjr Electric On-Road 1131 02-22-2017 11:58 PM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Ask Frank Root.....AE, Reedy, LRP, JC Frank Root Electric Off-Road 568 02-14-2010 01:24 AM
LRP SPX, no 25years warranty anymore? Tpg racer Electric On-Road 17 02-28-2009 09:24 PM
