Car still glitches!!! HELP >
Old 03-16-2004, 10:59 PM
  #61
DOMOisCOOL's Avatar
Got wire management?
DOMOisCOOL is offline
Old 03-16-2004, 11:04 PM
  #62
MugenMTX3Kid's Avatar
For me,
Time & Patience
is important for wiring management... which i dont have
MugenMTX3Kid is offline
Old 03-16-2004, 11:11 PM
  #63
DOMOisCOOL's Avatar
You also don't have a body
Old 03-16-2004, 11:25 PM
  #64
argh... more money...
Old 03-16-2004, 11:30 PM
  #65
DOMOisCOOL's Avatar
And you're gonna race?
Old 03-17-2004, 11:58 AM
  #66
John Fontaine's Avatar
Originally posted by AzNDRAGster
That novac diode is over priced IMO. Just run 2 diodes.
Over priced? It's only 7 dollars . Two 6 amps diodes is 12 amps, this is 25, more than quadrupled .
John Fontaine is offline
Old 03-17-2004, 08:59 PM
  #67
Techart27's Avatar
Originally posted by MugenMTX3Kid
For me,
Time & Patience
I'll wire it for you if u pay me- Guarentee it will be neat-
Techart27 is offline
Old 03-17-2004, 09:01 PM
  #68
My car looks like this right now...
Old 03-17-2004, 09:09 PM
  #69
Techart27's Avatar
ill help u on friday or on the weekend
Old 03-17-2004, 09:30 PM
  #70
DOMOisCOOL's Avatar
Shorten your battery wires
Old 03-17-2004, 09:49 PM
  #71
Techart27's Avatar
Old 03-17-2004, 10:18 PM
  #72
Dump the GT7. Don't know why..I like Novaks..I think there were a bunch of problematic GT7's out there...saw 6 of them last year at my track with the same problem. Of course, that's assuming you are not sloppy with the rest of the wiring. All cars that I saw with the GT7 problems switched out their esc's to cyclones or LRP's and the problem stopped completely.
Motor capacitors- make sure you have 3 caps, not 2. One each from + and - sides to the can and one more between the + and - sides.
Diode-- a bad diode will cause glitching every time. Make sure you use a new diode. They're cheap and plentiful.
Wire soldering- make sure you are not running leads all around your antenna and make sure no exposed ends are near the chassis parts. Insulate all solder joints.
Receiver- Always use multiple layers of servo tape under the receiver - and mount as close as possible to the antenna tube. insulate the antenna wire from the receiver to the tube.
Motor condition- worn brushes/comm will cause major glitching.
If you keep the GT7, try changing the program to alter the operating frequency.
Good Luck!
MikeBajorek is offline
Old 03-17-2004, 10:20 PM
  #73
Oh yeah, one more thing-- some motors come with capacitors built into the hoods. If you remove the hoods at all, make sure you don't lose those extremely small caps.
Old 03-17-2004, 10:28 PM
  #74
DOMOisCOOL's Avatar
Nicely said. Although I am a fan of the GT7
Tommy, use the preset program for stock mode, which is mode 4.
Old 03-17-2004, 10:33 PM
  #75
oh dang, forgot to change, its still on Smooth Modified.
