Old 12-31-2009, 01:20 PM   #1
Default New to R/C Hobby, which one do you recommend me?
Hi guys nice forum, I would like to hear your opinions about this two Ready To Race packages:
- Tamiya Lamborghini Countach LP500S
- HPI Sprint 2 RTR Sport RC Car w/Toureza Body
Thanks, and if you have some other model that you would recommend me, that would be appreciated too.
enb141 is offline   Reply With Quote
Old 12-31-2009, 01:50 PM   #2
Super Moderator
charlie_b's Avatar
Send a message via AIM to charlie_b Send a message via MSN to charlie_b Send a message via Yahoo to charlie_b
Both good kits to start with. I recommend getting the kit that has spare parts at the hobbyshop you plan on shopping in.
''Many of life's failures are people who did not realize how close they were to success when they gave up.''-- Thomas Alva Edison
CAL RACEWAY:CAL RACEWAY
GT10 SERIES:GT10 SERIES
CFX Paintworks:="https://www.facebook.com/CFXPaintworks?fref=ts
TEAM ASSOCIATED|REEDY|HITEC|PARMA|PROTEKRC|SWEEP|IWATA| RPM|AMAIN|CREATEX/WICKED/AUTOAIR PAINTS|CFX|CAL RACEWAY
charlie_b is offline   Reply With Quote
Old 12-31-2009, 03:17 PM   #3
Raman's Avatar
Trader Rating: 56 (100%+)
I am a big Tamiya fan.., however between the 2, I would recommend the HPI. The Countach comes with the TT01 chassis which has a lot of plastic parts.
Instead, I would recommend these Tamiya kits which are nearly the same price as the HPI and are a much design and value in comparison to the TT01 chassis.
TA05 IFS $199 has lay down shocks, belt driven
http://www3.towerhobbies.com/cgi-bin...?&I=LXTRN2&P=7
TA05 $179 has traditional stand up shocks, belt driven
http://www3.towerhobbies.com/cgi-bin...?&I=LXKSG0&P=7
TB03 $204 shaft driven
http://www3.towerhobbies.com/cgi-bin...?&I=LXWCP0&P=7
Later if you like you can buy the Countach body and fit it to these cars.
While I do think it is important to support the local hobby stores, I find that they rarely carry the kits and parts I need. So if they do not carry your parts, don't fret, just order them online from Tower Hobbies, AMAINHobbies etc.
Also feel free to use this forum, majority of us are here to help.. and if someone gives you slack for asking what they perceive as a silly question. don't let it bother you! Just ignore them.
Welcome to the Hobby and Happy New Year!
Raman is offline   Reply With Quote
Old 12-31-2009, 04:13 PM   #4
Thanks for those links, I actually live outside the US so to me my only store is internet, now back to topic, could you tell me the differences between those TA05, TA05 IFS, TB03?
One more question, do you know if I can use the lamborghini countach/ferrary with the HPI body?
Old 12-31-2009, 05:36 PM   #5
From memory, the Tamiya countach isnt a standard size body, the rear wheels need a large offset (they stick out further than normal)
TT01- shaft drive, VERY BASIC, low spec, reliable, almost unbreakable-DOESNT COME WITH BEARINGS, basic parts needed have to be bought separately as hopups (bearings, metal centre shaft). Overpriced
TB03- a more modern version of the TT01, not sure if it comes with bearings
TA05, the best of the Tamiyas(except for the very expensive carbon racing kits). Belt drive. Needs a clean track as belt & gears are exposed. Good enough for racing at a club level. very good for drifting.
TT01D & TB03d both come with bearings and are better than the standard version.
TT01E is much improved over the standard TT01, still needs bearings.Still rather basic.
1101 is offline   Reply With Quote
Old 12-31-2009, 06:02 PM   #6
cherry2blost's Avatar
Hi Matey, take a look at the Hot Bodies cyclone-S or the Kyosho TF-5 RTR as they can be had VERY cheaply these days and are both competitive OUT OF THE BOX. But have huge amounts of hop ups for when you are ready to make some improvements to your ride.
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 12-31-2009, 07:43 PM   #7
Raman's Avatar
The countach body requires a shorter wheel base. On the Tamiya kits this is done by flipping the arms over, or using shims behind the arms to push them forward. I don't believe the HPI sprint has adjustable wheelbase.
TA05 is belt driven just like the HPI Sprint that you originally listed. It comes in 3 variations. The original is the TA05 which has stand up shocks. The newer version is the TA05 IFS which has inboard front shocks (hence IFS) I recommend the original TA05 because its easier to set up the shocks. There only advantage to these shocks is that in enables you to use more slope nosed bodies. Then there is the TA04 Version. 2.. it has some advanced suspension may overwhelm you.
The good news is that later if you choose to you can upgrade to the IFS and Version 2. TA05 kits come with ball bearings
TB03 is a shaft driven car, very similar to the TT01 which comes in the countach kit. It also comes with ball bearings and has the inboard front shocks.
Hotbodies Cyclone - Hotbodies is the higher end line of HPI. Its very similar to a TA05. The Cyclone S comes without a body for $159 by the time you add a body you are at a TA05 again.
Kyosho - TF5 is a shaft driven car like the TB03 and TT01. I own Kyosho nitro cars and their quality is great.. parts are tricky to come by at times..
My advice to you is to pick something between HPI Sprint, Hot Bodies Cyclone or Tamiya TA05. They're very similar and belt driven, which makes them very smooth to drive. After each run a little compressed air and its clean.
Now if you are looking to drive on dirt occasionally then I suggest going with a TB03
Old 12-31-2009, 08:56 PM   #8
V_28's Avatar
Yeah, I agree with this post. I've got both cars and although they don't compare to my higher end kits, they both are very decent and with some upgrades, can be competitive. I lean towards the TF5 more due to the parts being stronger than the Cyclone S, plus the upgrades are easy to purchase and relatively cheap. Anywayz, both are decent.
V_28 is offline   Reply With Quote
Old 12-31-2009, 09:09 PM   #9
TwoTone's Avatar
First piece of advice if you're new and planning on racing- go to the local track and see what everyone is running. Pick something they are running so you can get set up help.
If you get something no one runs- you're on your own for set up.
TwoTone is offline   Reply With Quote
Old 01-01-2010, 11:41 AM   #10
thanks guys for your posts, well actually I don't think I'm going to use my car to compete, most likely I'm gonna use it for fun so I don't care about speed and stufs like that.
Now another question for how long and which battery pack do you recommend me for this cars?
Old 01-01-2010, 10:02 PM   #11
ozvena's Avatar
Cyclone S kit comes with a body and is cheaper than mentioned here.
Two issues with it, some gearing ration can be tricky to achieve and battery space limits to thiner packs.
ozvena is offline   Reply With Quote
Old 01-02-2010, 05:00 PM   #12
Sorry for hijacking but I have a question to ask. I never tried an electric car before, only nitro, what specific features should I look for when choosing a new electric car?
http://www.rc-spirit.com/rc_basics.html
Beginner's guide to RC.
alg7_munif is offline   Reply With Quote
Old 01-02-2010, 09:01 PM   #13
ozvena's Avatar
- price
- will it fit my battery I intend to use?
- will it fit the motor I intend to use (will gears mash for the motor)?
- parts availability
Pick one, have fun!
Old 01-03-2010, 07:51 AM   #14
Not to be a stickler, but the TB03 is an updated version of the TB02. The TB02 was released around the same time as the original TA05, and shared all the same suspension/steering parts. The only differences centered around the fact that the TB is shaft drive, while the TA is belt drive. Both TA and TB platforms are fairly high-end, with many adjustments available, ball bearings standard, aluminum driveshaft standard on the TB, etc.
The TT01 is a completely different car, and while it is a shaft driven tub chassis car like the TB series, it is an entry level car, which usually (except for the "D" model) comes without bearings, comes with a plastic driveshaft, etc.
JasonRP is offline   Reply With Quote
Old 01-03-2010, 08:40 AM   #15
Considering that you are using the car for fun the TA05 would be the better choice as it has very good parts support anywhere and is generally reliable.
If you do intend to race the cyclone S is a great starting point with a better config for the track out of the box.
For power you will be able to purchase a brushless combo online somewhere that will do the job fine. Make sure the ESC has a lipo cut built in. A 10.5t motor is a great balance between sense and speed for unprepared surfaces like carparks and similar. You will get decent runtime and speed and won't destroy the cars drivetrain at warp 10 like a 4.5t motor would. Get a couple of decent capacity lipos and a compatable charger and you are set.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Hi all ! i'm new to R/C racing Andys Singapore R/C Racers 38 09-04-2009 07:38 AM
New to hobby, suggest starter kit The_Raptor Electric On-Road 18 06-06-2006 10:35 AM
What do you wish you would have known? Daddy2mnb Rookie Zone 13 04-16-2006 07:50 PM
New To R/C...Bad choices? zracer196 Electric On-Road 51 03-17-2004 12:48 PM
