Recomended Power Supply >
Old 03-12-2004, 10:34 PM
Default Recomended Power Supply
Im looking into a new power supply. Just wondering what kinds of power supplys you all would recomend. I just need to run my LRP Pulsar Competition and my soldering iron.
pro4x is offline
Old 03-12-2004, 10:39 PM
Default Re: Recomended Power Supply
1st of all I have never heard of a soldering iron uses a Power supply. If so Anything Above 10-13 Amps Will be fine wehn using only that one Charger. Most power supply are normally the same IMO.
True R/C Racing is offline
Old 03-12-2004, 11:39 PM
Trader Rating: 16 (100%+)
Look at the Radio Shack 25 amp power supply on their website. It has a nice shape to it and is only $99. Your LRP charger can sit right on top of it.
If you want to dress it up...Competition Electronics is coming out with a 25 amp power supply in about 3 weeks...It appears to be the same configuration as the Radio Shack unit; except, the prototype picture had really nice electrical connections.
Still Bill is offline
Old 03-12-2004, 11:45 PM
rccarracer's Avatar
Default Re: Re: Recomended Power Supply
There are 12volt ones on the market....
rccarracer is offline
Old 03-12-2004, 11:46 PM
rccarracer's Avatar
Generally, 7amps+ is enough if your just running a charger, but if you want to run a soldering iron at the same time, first check the required amps for the iron and go from there....
Old 03-13-2004, 07:46 AM
Default Re: Re: Re: Recomended Power Supply
oh ok Man Thanks, Didn't Know that. Sorry
Old 03-13-2004, 11:57 AM
popsracer's Avatar
pro4x;
Check out the 'Rivergate' power supplies. They make them in 5 amp steps with the 30 amp being the most popular and are bulletproof.
If you buy one now, you will be able to pass on to your Grand kids when THEY start racing.
popsracer is offline
Old 03-13-2004, 12:04 PM
Brian Miskolczi's Avatar
Trader Rating: 160 (100%+)
Just get a N power by novak, you can power two lrp comp. off of it, so why cant you use an iron also. Works for me, i got mine for 75 bucks..
Brian Miskolczi is offline
Old 03-13-2004, 12:23 PM
Tek Nickal's Avatar
Its very compact also . . . .
Tek Nickal is offline
Old 03-13-2004, 01:11 PM
Super Moderator
Marcos.J's Avatar
Trader Rating: 235 (100%+)
Default Re: Re: Re: Re: Recomended Power Supply
i guess sometimes having the most post doesnt make you the smartest one on r/c stuff! just kidding Ariel see you at fullthrottell!!
Marcos.J is offline
Old 03-13-2004, 09:10 PM
F1Junkie's Avatar
Hi
Does anyone else know anything about the CE power supply?
Any pics, maybe from a big race event?
Dave
F1Junkie is offline
Old 03-13-2004, 09:47 PM
Go on ebay and get a 12volt 13amp supply for $17.99. Small and compact. Adjustable voltage. I have three of them and also the lrp pulsar competion charger. A deal you wont find anywhere else. You can also use a powersupply from an old computer you might have to just load the 5volt side enough that your voltage on the 12volt side gets up to about 13.8 volts. I tried it as a project and it works great also.---Just some suggestions.--Dave--oh yeah the ebay sellers name is ramboy I think or ramboy.com
ddesens is offline
Old 03-13-2004, 09:50 PM
Originally posted by F1Junkie
Hi
Dave
http://www.rctech.net/forum/attachme...&postid=729365
Here is the front picture.
Go to Page 25 on the Pro Match Batteries string in Electric On-Road to read the messages and to see front and rear pictures of the new CE power supply.
