Old 10-22-2001, 07:31 PM   #76
HarshGuy's Avatar
I've only run them twice a day ...and yes 2nd time is the MONSTER run.
HarshGuy is offline   Reply With Quote
Old 10-22-2001, 08:06 PM   #77
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
There are ROAR legal already.
This is not a new cell, just an improved cell. Still a RC3000 Sanyo. ROAR regulates the cell by size and capacity, not by the quality of voltage output.
The black Panasonics were also not submitte for approval for the same reason.
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 10-22-2001, 09:35 PM   #78
Company Representative
Danny/SMC's Avatar
Sorry guys if I didn't get to answer all your questions. What I have learnt and reccomend for the RC3000HV is posted on our website.
If something isn't clear or you have other battery questions please ask again. I will have more time to answer on Tuesday.
Danny/SMC is offline   Reply With Quote
Old 10-22-2001, 10:19 PM   #79
HarshGuy's Avatar
SirSpeedy is that for sure?
Danny /SMC whould you use the same charge/threshold numebrs for SMH's as HV's? And is cycling HV's once a month considered excessive cycling?
Old 10-23-2001, 08:07 AM   #80
Danny/SMC's Avatar
HarshGUY: No I wouldn't use the same peak detect for the SMH's. A .05 seems to give good results with the SMH's.
Cycling once a month is fine. Remember only to use a 1 peak charge. The runtime will be lower by 3-5 seconds but I believe this is better for the pack.
Old 10-23-2001, 09:03 AM   #81
GKC
GKC's Avatar
Send a message via ICQ to GKC
How about the cycling done during matching? Will that hurt the cell?
GKC is offline   Reply With Quote
Old 10-23-2001, 09:11 AM   #82
Regional Moderator
Darkseid's Avatar
Sirspeedy: good point about the Legality. The SMH were legal when they came out, so it shouldn't be any different with the HV's.
TLR 22...Tamiya F104...
Old 10-23-2001, 09:12 AM   #83
Danny/SMC's Avatar
GKC: No the cycling during matching will not hurt the cells if you setup your equipment correctly.
You can cycle these packs without any problems it's just that in my initial tests I was cycling the same pack 2 times a day everyday and it did show some signs that of wear but I was also using a 2 peak charge. I have tried the same test with a one peka charge and it's better. The RC3000H would lose voltage if you didn't cycle them often. This new cell doesn't have this problem so there is no need to cycle them often.
Old 10-23-2001, 09:32 AM   #84
stefan's Avatar
Send a message via AIM to stefan
Danny,
got a question for you.
I'm running SMH batteries.
I have not raced them for the last 4 weeks, but cycled them every week.
Now, since I read that you shold keep the cells as cool as possible during cycling, I got me two PC fans and built me a little stand where I put the packs in for cycling.
The first cycles afterI got the fans made me almost go nuts.
My ususal numbers are ~420s/ 6.95V @ 25 amps.
With the fans, the numbers were 395s/ 6.70 @ 25 amp
I thought all my packs went south.
After removed the fans, my numbers went back to normal.
So, does heat hurt batteries or is it necessary to get performance?
Thx
stefan is offline   Reply With Quote
Old 10-23-2001, 09:43 AM   #85
HarshGuy's Avatar
I almost forgot till I saw stefans reference to packs going south, I do have 1 SMH pack that is dead, one cell is completely dead no voltage at all ...where can I get individual cells? Or can I maybe send the other good 5 cells to you Danny and you can match up another cell to it? This is a Trinity SMH matched pack.
Old 10-23-2001, 10:52 AM   #86
Danny/SMC's Avatar
Stefan: I never said to use a fan on cells while charging. This will not get the cells to charge correctly and as you can see it affected your numbers.
Heat is alright as long as you don't overcharge the pack it's o.k..
Harshguy: Sorry I can't help you with your SMH's were out of them and don't plan on getting anymore since the new RC3000HV is doing real well. Plus I would bet that your other 5 cells are all over the place and not well matched anymore.
Old 10-23-2001, 04:40 PM   #87
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Can you use these cells 3-4 four times a day as with the SMH's?
Speedo is offline   Reply With Quote
Old 10-23-2001, 04:46 PM   #88
Danny/SMC's Avatar
Our tests conclude that they can be run atleast 2 times a day. I have never tried 3 or 4 times. If SMH's can I think this cell could also.
Old 10-23-2001, 04:51 PM   #89
Moderator
Speedo's Avatar
Darren shank is sponsored by Fantom, so you guys too I guess...ANd he was running his SMH's up to 4-5 times a day. I need some new batteries, and the appeal of the SMH's is that you can run them alot...Would be nice if you can with these too.
Old 10-23-2001, 07:15 PM   #90
In my experience, you can run them very often.
You do need to let them cool down all the way. This takes at least two hours. Even though they feel cool to the touch, the core of the cell could still be very warm.
Tim Davis
sanyo 3000HV ruftnik Rookie Zone 2 11-09-2003 06:05 PM
New Sanyo 3000HV PMR packs rayhuang R/C Items: For Sale/Trade 0 02-25-2003 11:18 AM
Sanyo 3000HV lilshortyc3 Electric On-Road 4 12-20-2002 02:34 PM
1 New Integy Sanyo 3000HV hohen711 R/C Items: For Sale/Trade 1 09-11-2002 01:31 PM
