Old 08-11-2002, 06:51 AM   #691
Joel Lagace's Avatar
i just use the voltage values like 0.07v instead of the mv stuff it confuses things. T35s use voltage values with decimal points. its the pitbull and millenium using the mv values that are confusing some i think
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 08-11-2002, 03:23 PM   #692
blueboy's Avatar
OK to clear things up I am using a Millenium to charge the packs, with the Voltage Threshhold set at 4mv per cell, 24mv per pack.
They still come off the charger too hot to hold in my hand for more than a second.
blueboy is offline   Reply With Quote
Old 08-11-2002, 08:12 PM   #693
F&K
F&K's Avatar
Hi Guys,
Is it any way that I can stop my Novak Millenium charger from having false charge on my HV battery?
F&K is offline   Reply With Quote
Old 08-11-2002, 09:38 PM   #694
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
The Pitbull also uses a decimal value, just like the T-35, but it shows it to 3 decimal points, where as the T-35 only shows it to two decimal points.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 08-12-2002, 02:03 AM   #695
Erik R.'s Avatar
Do you guys use a tray to discharge the HV's? If so do you use it before a charge or when?
Erik R. is offline   Reply With Quote
Old 08-12-2002, 05:29 AM   #696
Rowdy's Avatar
I used a friends brand new pack of fantom HV's and my t35 to charge them at a club meet last weekend. I charged them at 10 amps .09 peak detect and they were simply unbelievable. We also had two new packs of UMH but in my opinion the HV's were far superior. I'm now sure I will be getting the HV's after comparing them against the UMH on the track. However I did find one thing rather surprising, at the end of the charging the HV's they only seemed to be mildly warm to touch, nowhere near as warm as I would have thought. Should the pack be hot to hold in your hand after charging at those sort of numbers.
Rowdy is offline   Reply With Quote
Old 08-12-2002, 06:11 AM   #697
sosidge's Avatar
Assuming the cells are cool before you put them on charge, sounds like something is wrong somehwere along the line for that to happen, although I couldn't put my finger on what.
Old 08-12-2002, 01:07 PM   #698
Company Representative
Danny/SMC's Avatar
Grizzbob: UMH act just like SMH's in fact I think they are the same cell with new shrink.
Rowdy: I would go with the new GP3300 it will run as good as an HV but has more capacity and it's cheaper.
To All: On a 6 cell pack I reccomend 70 to 90 mv or .07 to .09 volts. The pack will peak in the 140-150 farenheit range.
F&K: Use a 70 to 90 mv peak detect for the entire pack. You can also charge the pack for 200 seconds or so and then discharge it and then start the charge. This should fix the false peaking.
Erik R.: If you usa tary afte the cell has been discharged and it's still hot this will keep the voltage up but will drop the runtime. If you use a tray when the pack is cool and then start charging it right after it was on the tray this will be better for the runtime. If you use no tray this will keep max runtime but it
Danny/SMC is offline   Reply With Quote
Old 08-12-2002, 02:49 PM   #699
Fred Hubbard's Avatar
Danny is there a formula or a "rule of thumb" to use when increasing the charge amperage on the HV cell. Example being if a person wanted to test the affects of using different charge rates, then how would he/she know what delta peak setting to use. Thanks...
Fred Hubbard
Fred Hubbard is offline   Reply With Quote
Old 08-13-2002, 12:51 AM   #700
Rowdy's Avatar
Danny - how long until you get in the new GP3300 cells. Do you have any cell numbers for them you could post ie runtime, voltage, IR's.
Old 08-13-2002, 12:54 AM   #701
Rowdy's Avatar
How long does it useally take before new cells are approved for racing.
Old 08-13-2002, 08:07 AM   #702
shrekair's Avatar
Trader Rating: 9 (91%+)
ustc approved the 3300 cell for their up coming series
shrekair is offline   Reply With Quote
Old 08-13-2002, 08:58 AM   #703
Danny/SMC's Avatar
fhubbard: When using 10 amps or more I would use .07 or 70 mv. For 8 or 9 amps .09 or 90 mv will work fine.
Rowdy: We already did a small batch of GP3300 and were waiting on a new batch. Out of the first batch runtime was 400 - 430 with 1.13 - 1.15 voltage @ 30 amps. Actual IR of 2.8 - 3.3
I heard that NORRCA will approve them on 1st of Sept. Not sure about ROAR.
Old 08-13-2002, 05:43 PM   #704
Rowdy's Avatar
Anyone know the formula for working out the mA HR of a pack at the end of a charge on the t35?
Old 08-13-2002, 09:47 PM   #705
Send a message via Yahoo to Doug Gaut
Danny, what distributer has your GP3300s on hand right now? They will be great in the dominator for dirtoval!!
Doug Gaut is offline   Reply With Quote
sanyo 3000HV ruftnik Rookie Zone 2 11-09-2003 06:05 PM
New Sanyo 3000HV PMR packs rayhuang R/C Items: For Sale/Trade 0 02-25-2003 11:18 AM
Sanyo 3000HV lilshortyc3 Electric On-Road 4 12-20-2002 02:34 PM
1 New Integy Sanyo 3000HV hohen711 R/C Items: For Sale/Trade 1 09-11-2002 01:31 PM
