Old 07-21-2002, 11:58 AM   #661
I have a Tekin 112A charger with H27 software, so according to the manufacturer I could charge ni-mh cells with it. Has anyone tried how well it works?
Eetu is offline   Reply With Quote
Old 07-21-2002, 12:32 PM   #662
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Tekin's website finally bit the dust about a month ago.
-Troy
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 07-21-2002, 03:54 PM   #663
Super Moderator
Grizzbob's Avatar
Eetu, I've used my 112a(with the same h27 firmware as yours) on my 3000HV's, & it seemed to work just fine. However, I still prefer to use my Millenium for them(because of the greater adjustability of the voltage threshold), & mostly use the 112a for the 2400 NiCd's I use in my stock TC.....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 07-22-2002, 06:12 AM   #664
Thanks for the info,Grizzbob
Old 07-22-2002, 11:18 AM   #665
RCTech Member #2
TSR6's Avatar
What do you guys think about HV v.s. UMH?
I haven't heard too many people talking much about the UMH performance, and i may be looking at getting a couple new battery packs in a couple weeks, i just don't know which cells.
-Troy
Troy
RCTech Member #2
Old 07-22-2002, 12:00 PM   #666
superk's Avatar
Guys! Will dead short my old 3000H will bring back some power and life?
I see on the Trinity web site that..the new 3300 is out! any one have a change to try it yet? Hm....do we need to change to a new topic to 3300HV cell?? LOL..
superk is offline   Reply With Quote
Old 07-22-2002, 04:48 PM   #667
wacky's Avatar
Just bought orion matched packs HV batteries. Some suggest to charge it first using a low ampere settings and discharge and some says charge it fully using amp rating of 6A.
Need your advise.
Tenks ......
wacky is offline   Reply With Quote
Old 07-22-2002, 09:16 PM   #668
RCTech Member #2
TSR6's Avatar
I've never charged my HV's under 5 amps.
I generally charge them at 6amps.
-Troy
Troy
RCTech Member #2
Old 07-23-2002, 04:59 AM   #669
Regional Moderator
Addict sa RC's Avatar
wacky, they're matched packs which means that they've been cycled already. Charge them at the same amps that they were charged during matching.
Addict sa RC is offline   Reply With Quote
Old 07-23-2002, 05:35 AM   #670
sosidge's Avatar
superk - don't deadshort the packs
Old 08-07-2002, 01:41 AM   #671
Rowdy's Avatar
does the voltage enhancment process wear off the HV cells after about 20 or so cycles, ie do they need to be mantainence zapped periodicly to keep the voltage high. What have others found is the expected life of the cells if treated hard, like 8amp charge and 30amp discharge.
Rowdy is offline   Reply With Quote
Old 08-07-2002, 05:01 AM   #672
sosidge's Avatar
I've had my HV's about six months, being used hard (2-3 cycles per meeting, 6A charge, racing at least once a week, running mod on a twisty track with a punchy thumb, not letting them get as cool as I really should before recharging (oops)), and they're still great, with the numbers virtually the same as when they were new.
Old 08-07-2002, 10:30 AM   #673
shrekair's Avatar
Trader Rating: 9 (91%+)
TSR6 - the UMH cells have more punch and power over the voltage curve. the hv's are good early but drop off a lot more then the UMH will. u can turnlaps as fast at the end of the race w/ UMH as when u started where as the hv can drop upto .2 seconds per lap (approx)
shrekair is offline   Reply With Quote
Old 08-07-2002, 11:15 AM   #674
anyone heard anything on gp3300 cells yet? how much longer run time are they expecting? is the voltage comparable to umh?
racerfreedxxxs is offline   Reply With Quote
Old 08-07-2002, 11:25 AM   #675
Company Representative
Danny/SMC's Avatar
shrekair: What your reporting is strange because we have seen the exact opposite when we tested Sanyo's against Panasonics.
The Sanyo cell does need to be charged with a higher peak detect. If you use a low peak detect the cells will be 10-15 deg. farenheit cooler than a Panasonic cell. We have found that higher charge rates will result in more power with the HV's.
Danny/SMC is offline   Reply With Quote
sanyo 3000HV ruftnik Rookie Zone 2 11-09-2003 06:05 PM
New Sanyo 3000HV PMR packs rayhuang R/C Items: For Sale/Trade 0 02-25-2003 11:18 AM
Sanyo 3000HV lilshortyc3 Electric On-Road 4 12-20-2002 02:34 PM
1 New Integy Sanyo 3000HV hohen711 R/C Items: For Sale/Trade 1 09-11-2002 01:31 PM
