Old 04-19-2002, 04:04 AM   #511
I am thinking of buying some 3000s cheap from a sponsored guy. They are not the new HVs, but they are in the old sanyo heatshrink and have voltages of around 1.150 @ 30amps.
Does anyone know what the difference between these cells and the new green ones is?
Cheers
Indy is offline   Reply With Quote
Old 04-19-2002, 05:37 AM   #512
stefan's Avatar
Send a message via AIM to stefan
Default Indy,
DON'T!!!
The old Sanyos as well as the blue Panasonics were crap.
Stick with either HV or SMH
stefan is offline   Reply With Quote
Old 04-19-2002, 11:46 AM   #513
Talking cells
these cell are the best and they should be used its great we have them ,more power!!!then will all be rollin'
FactoryteamTc3 is offline   Reply With Quote
Old 04-19-2002, 11:48 AM   #514
Lightbulb servos
Hey chris what servo should i run outdoors im not sure yet w/b asap im racing my tc3 this weekend hope you can keep up also!!!just kiddind also is mike webb going to be there?
Old 04-19-2002, 07:21 PM   #515
Damon_KJ7E's Avatar
I have gracefully retracted my previously inflammatory post.
Damon_KJ7E is offline   Reply With Quote
Old 04-24-2002, 12:57 AM   #516
Send a message via ICQ to melvin
Default Pls advise
fellow racers,
Pls advise. Do you:
1. Sand your batteries/battery bars before soldering?
2. Do you tin both side of your battery bars before soldering?
Also, how do you use the liquid flux? Do you dip your solder in it or do you apply on top the battery bars first?
What is the best method to solder your batt without hurting them?
Thank you
Regards,
mel
melvin is offline   Reply With Quote
Old 04-24-2002, 02:49 AM   #517
rccarracer's Avatar
Originally posted by JohnA
Hi
I'm just about to invest in some 3000HV's, I was looking at SMC's but can't find any in the country so I think I'm going to go with some Fantom Team cells. Anyone got any views on them, or anyone know where I can get SMC's in Australia. The land where the Chrome stock is the latest stock motor!!
Cheers
See the trick to getting new stuff here in Australia is ordering from the US. I got my HV's sometime at the end of last year from Stormer Hobbies. They are SMC's and are awesome.
But here in Australia SMC don't have a distributor. It's my understanding they don't have one outside of the US. But that might of changed since this was last discussed in January.
rccarracer is offline   Reply With Quote
Old 04-24-2002, 05:05 AM   #518
sosidge's Avatar
melvin - my method is to lightly sand/clean the batteries, but I leave the bars (I've spent all that money on a silver coating I might as well leave it there!).
I then tin both the batteries and the bars, befor assembling them into the jig, feeding a little more solder in to leave a nice "wet" looking joint.
The best way to aviod damaging the batteries is to not heat them up too much - use a powerful iron (60-100W), and try to keep it on the surface of the cells for as little time as possible.
The problem with the little irons is that they will heat up the whole cell before the surface gets to the melting point.
I don't use seperate flux myself, just yer average multicore stuff.
Old 04-24-2002, 06:18 PM   #519
Super Moderator
Grizzbob's Avatar
Correct, though I personally don't bother to tin the bars, that can wait till you're assembling the pack. But I do tin the ends of each cell, & then I put a bit of solder through the bars as I'm heating them all up in the battery jig, & just let the solder flow through the holes in the bar......
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 04-24-2002, 08:59 PM   #520
Pyramid's Avatar
Guys, do not sand the batteries. Use "Autosol", that how we called in here-Indonesia, to clean both end. It will make your soldering job easly and its coating will automatically suck up that solder.
Pyramid is offline   Reply With Quote
Old 04-27-2002, 09:59 AM   #521
hey, i have a question for you guys, sorry i dont have time to read the thread right now have to go to work, i assembled a pack of some smc hv cells 4 or 5 days ago and i wont be using them for the first time for another 3 weeks or so, so my question is how should i store them until then, like 15 minutes at 4 amps or somthing like that? thanks
Jarrod Langlois is offline   Reply With Quote
Old 04-27-2002, 11:34 AM   #522
Super Moderator
Grizzbob's Avatar
Well, if you haven't used them yet then don't worry about it, they can sit as they do on the shelf for several weeks(if not months). I wouldn't worry about it until you've run the packs a few times & may have to store them for awhile after that.....
Bob Seay
Go Pokes!!!
Old 04-27-2002, 06:53 PM   #523
ok thanks i had forgot all about them and was wondering if i was supposed to half charge them for storage or somthing.
Old 04-28-2002, 12:39 PM   #524
Company Representative
Danny/SMC's Avatar
spaz456: I have packs that we raced at the Snowbirds in Febuary that I cycled last week and the numbers were fine so the HV's do have a good shelf life.
Danny/SMC is offline   Reply With Quote
Old 04-29-2002, 04:26 AM   #525
corally's Avatar
Default hv cell
Hi
i have buy a 3000 sanyo NORMAL but the label declare
1.154 volt and 399 sec @ 30A.....
The cell is marked HR this us the sigle of 3000HV ?
Thank
corally is offline   Reply With Quote
sanyo 3000HV ruftnik Rookie Zone 2 11-09-2003 06:05 PM
New Sanyo 3000HV PMR packs rayhuang R/C Items: For Sale/Trade 0 02-25-2003 11:18 AM
Sanyo 3000HV lilshortyc3 Electric On-Road 4 12-20-2002 02:34 PM
1 New Integy Sanyo 3000HV hohen711 R/C Items: For Sale/Trade 1 09-11-2002 01:31 PM
