Old 03-27-2002, 06:50 PM   #481
STLNLST's Avatar
Trader Rating: 21 (100%+)
No matter what the Integy cells say.....I have been able to keep up with the factory guys from every major battery label. I'm sure that there is a performance advantage somewhere but so far I haven't needed the better batteries. If Danny picks up another Speedworld racer (hint hint) then I'll have a better sponsor.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 03-27-2002, 07:02 PM   #482
Send a message via AIM to Ovalman19
I wasn't implying that they are inferior cells or anything, but a real 1.18 cell at 20amps, would more than likely be the same as the integy 1.23 or 1.22 cells. That is all, their numbers can't really be compared to any other in the industry.
Ovalman19 is offline   Reply With Quote
Old 03-28-2002, 05:12 AM   #483
Default Traying
I read that traying will decrease runtime but increase voltage. What specifically is "traying"? Discharging to 0 volts or to some cut off? I'm thinking of getting an Orion Active Discharge tray, I think it discharges to 0.5V. Is this good, or should the cut off be higher/lower? I'm not really looking to increase voltage, I just want the best maintenance for my packs. So I just want something to 'equalize' the cells rather than just discharge them as a pack. Thanks.
Potato is offline   Reply With Quote
Old 03-29-2002, 01:48 PM   #484
sosidge's Avatar
Just want to say I picked up 2 sets of the SMC HV's, and they are absolutely fantastic.
Even with a stock, my car had phenomenal punch, especially compared to my old 3000H's (funny how you don't realise just how tired a component is becoming until you replace it)
Did a cycle on my pro-trak before hand, and they showed good numbers - over 3000 capacity, and voltage around 7.1 for the whole pack (compared to around 2650 and 6.7 on the old cells) - but the on-track difference was even bigger.
Old 03-30-2002, 01:00 AM   #485
rto997's Avatar
HEHEhe!! Here we go with the INTEGY is FOOLING YOU Schutzpa again............
Some people never stop trying to put others down..... why is that you suppose????? HHHHHHMMMMMMMMM!!!!!!!!!!!!!
rto997 is offline   Reply With Quote
Old 03-30-2002, 01:25 AM   #486
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
What is wrong with pointing out how Integy traps the results through a shorter discharge cutoff time, hence a higher average voltage rating. That is one of the reasons why you cannot compare one company's matching procedure to another.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 03-30-2002, 08:45 AM   #487
rcruv's Avatar
Default Re: Traying
It's been answered many times here.
Danny here suggested
After the race discharge the cell down to .9 V. 5.4V for 6cells.
Then tray them for half an hour to an hour.
Then Keep them until the race.
Or for 2 and half hour to cool down before recharge.
Go check this site for about 3000HV.
www.smc-racing.com
Hope this helps.
rcruv is offline   Reply With Quote
Old 03-30-2002, 08:59 PM   #488
rcruv, the part I'm not clear about is when they say tray. Does this mean put it on a tray that maintains the pack at 0.9V per cell? I can't find any tray that cuts off at 0.9V, do you know of one? The only ones I've seen discarge to 0V or 0.5V.
Old 03-31-2002, 01:42 AM   #489
rcruv's Avatar
Integy sadle auto cut discharger has 0.9V cut off.
CE T30 or T35 has that too but too expensive I think.
Or you can buy a voltmeter.
Hope this helps.
Old 03-31-2002, 01:56 AM   #490
Send a message via AIM to ZER01
Integy does use 300sec. cutoffs. That's REAL bad for detecting "weak" cells! With 300sec. cutoffs, numbers look better and you could have 1 or more weak cells without knowing it(unless you got a turbomatcher4).
RCCadet, is Lightspeed still in business? If so, who or where do I need to contact to get some of their laydown brushes?
See ya in Jackson-that is if your going.
ZER01 is offline   Reply With Quote
Old 03-31-2002, 03:41 AM   #491
Lightspeed info :: 817-483-5772
I use Lightspeed motors, brushes, and batteries.
I may make that race in Jackson. Right now I am focusing on The Rutherford grand opening.
V-Dezign 4.0
Old 03-31-2002, 06:32 AM   #492
What is the highest A a Protrak can discharge a pack?
Some people say that a Protrak heats up too much when it discharges a pack and that a T35 dissipates heat more efficiently, is this true?
rcethilon is offline   Reply With Quote
Old 03-31-2002, 06:49 AM   #493
jericsm's Avatar
one fine day, after i have cleaned my work table, arranged my pinions in order, filed my labels, and finding nothing to do, i thought of recycling/rematching my 3000 cells. i had about five packs, thirty in all....
used a T35 for the cycling duties.... single cell discharge at 30A.... guess what happened? the wire melted the POS plastic covering (why didn't they make it silicon wire?) and the connectors (the astroflight ones....)
not really efficient.....
jericsm is offline   Reply With Quote
Old 03-31-2002, 08:02 AM   #494
Dear All,
Anybody knows the best way to store your 3000 HV cells after a race?
1. Discharge it to 0.9 V per cell (i.e. 5.4 Volt in total), and store it?
OR
2. Discharge it, the recharge till 40% filled and store it?
I have read in some manufacturers websites and it seems there are two different school of thoughts, as I stated above.
Your advice are very much appreciated.
Regards,
Keyence is offline   Reply With Quote
Old 03-31-2002, 08:10 AM   #495
I choose to discharge mine to 5.40V's a pack and that's it(no trays) untill next race day(2 weeks). If we get rained out, I'll put 30% charge back into them. I do the same for my SMH's unless we get rained out, if we get rained out I'll put about 50% charge into them and store them untill the next race day.
sanyo 3000HV ruftnik Rookie Zone 2 11-09-2003 06:05 PM
New Sanyo 3000HV PMR packs rayhuang R/C Items: For Sale/Trade 0 02-25-2003 11:18 AM
Sanyo 3000HV lilshortyc3 Electric On-Road 4 12-20-2002 02:34 PM
1 New Integy Sanyo 3000HV hohen711 R/C Items: For Sale/Trade 1 09-11-2002 01:31 PM
