Sanyo 3000HV cells!
Old 03-20-2002, 08:04 AM
  #451
mike_Webb's Avatar
Danny-
When Christopher says he beat the hell out of them he really means it. I beat him in a race and he pulled his pack out of his car and started puching the pack saying some very bad stuff. He needs all the help you can give him.
Mike Webb
mike_Webb is offline
Old 03-20-2002, 08:34 AM
  #452
Company Representative
Danny/SMC's Avatar
Christopher: Yes we can rematch your cells. Just make sure they are free of solder and the surface is flat. Remove the single cell shrink but you can leave the stickers on because there easy to peel off when the cell is hot.
We charge 1 dollar per cell plus enough for return freight. You can include a check to my name Danny Sullivan.
It normally takes a week to turn them around.
SMC
600 Shenandoah Avenue
Elkton, VA 22827
Danny/SMC is offline
Old 03-20-2002, 09:24 AM
  #453
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Thanks Danny.
Do you also do a maintenace zapp on the cells? And what is the easiest way to remove the solder... I'd like to get them good and clean...
Mike,
Actually, I forgot to put my battery strap on and was dragging my battery around the track. Though this slowed me down somewhat, I think I still beat you... Could be wrong... the big "30" is comming up soon and my memory isn't what it used to be...
ChristopherKee is offline
Old 03-20-2002, 10:25 AM
  #454
Danny/SMC's Avatar
The cells will be rezapped and matched. I use a Dremel sanding drum and pass over the ends slowly and as straight as possible.
Old 03-21-2002, 01:56 PM
  #455
mike_Webb's Avatar
Danny-
What are these new Ultra Metal Panasonic Cells that Trinity is talking about?
Mike Webb
Old 03-22-2002, 08:01 AM
  #456
Danny/SMC's Avatar
It's Panasonics newest NiMH cell. As soon as I get some to test I will let people know what they are about.
Old 03-22-2002, 11:45 AM
  #457
Mike... Your gonna need more then this to keep up with me
ChristopherKee
Old 03-22-2002, 12:09 PM
  #458
mike_Webb's Avatar
HA HA....
It is not going to be the batteries that make me faster then you... it is my new sweet Core Stock Motor . Sweet Numbers
Mike Webb
Old 03-22-2002, 05:05 PM
  #459
i hope this new cells from panasonic would be cheaper like the hv's
maski is offline
Old 03-22-2002, 06:34 PM
  #460
Moderator
Speedo's Avatar
Geez batteries are moving fast these days!
That has to be about the ugliest cell I have ever seen!
Speedo
Speedo is offline
Old 03-22-2002, 07:49 PM
  #461
AO
AO's Avatar
The HV are giving me more confidence when i race. Do not know why???? Ha Ha.... But i can sleep early for Hv as charging at 5 to 6 amp but smh i can only charged at 4 amps.
AO is offline
Old 03-22-2002, 08:08 PM
  #462
rcruv's Avatar
Originally posted by mike_Webb
HA HA....
Mike Webb
Could you be kind to put on dyno print out number here or email me?
I want to compare it with my p2k2 pro.
Thanks.
That ultra metal looks ugly but who cares if they bring me lots of wins.
rcruv is offline
Old 03-22-2002, 09:42 PM
  #463
DHMOTORSPORTS's Avatar
Trader Rating: 19 (100%+)
Has anyone cycled there HV's to check the numbers? I cycled mine and to a BIG surprise did I find some difference. On the label the say [email protected] Acording to my charger @20 they read1.11. I know my NiCads read higher @20 than then my HV's do and my stock metals arent to impressive according the what the labels read vs NiCads..
DHMOTORSPORTS is offline
Old 03-22-2002, 10:27 PM
  #464
My lowest HV packs are [email protected] Those numbers were taken with 6.0A charge 12mV cutoff per cell. My high cells are around [email protected]
How are you taking care or these cells, and what charger are you using?
ChristopherKee
Old 03-23-2002, 07:23 AM
  #465
Moderator
Speedo's Avatar
I cycled mine, 6.5 Amp charge, .05 threshhold...At 30 amps I got 1.14, the label reads 1.148 So they're still pretty good.
Josh
Speedo is offline
