Old 01-27-2002, 07:07 PM   #331
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I had a problem with my HV's false peaking over the weekend. Just keep an eye on your charger and you should be able to prevent this. I peaked ( and falsely ) my packs twice, but never looked at the readout on my PitBull, needless to say, I dumped...
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 01-27-2002, 10:54 PM   #332
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
Troy, were they new packs or did you leave them for a long time after traying them? I'm no battery wizard, but I know ALL of my NiMHs are bad about false peaking for the first 3 cycles when new, then maybe just once after being discharged for too long. One other thing, if you increase the charge amps from what you normally use, sometimes it will trigger a false peak the first or second time.
BigDogRacing is offline   Reply With Quote
Old 01-27-2002, 11:13 PM   #333
rccarracer's Avatar
How do you tell if your cells false peak? Sorry for my stupidity, but I've never had this explained.
rccarracer is offline   Reply With Quote
Old 01-27-2002, 11:19 PM   #334
Fire's Avatar
as it's name says, false peak is when the charger "thinks" that the pack is peaked but actually it's not. a pack that is false peaked is not fully charged so you can't get full run time out of it. hope this is correct~~
Fire is offline   Reply With Quote
Old 01-27-2002, 11:56 PM   #335
rccarracer's Avatar
So when do batteries typically false peak? At the start or near the end of a charge?
Old 01-28-2002, 01:38 AM   #336
hi, wondering if there is much difference between the lowest priced matched HVs than the highest priced for any brand? Thanks
ME-student is offline   Reply With Quote
Old 01-28-2002, 02:48 AM   #337
sosidge's Avatar
The false peaks tend to happen in the first half of the charge - so you can tell a packs false peaked if it's still cool.
Old 01-28-2002, 08:11 AM   #338
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Troy, what were you using as a lockout on your charger?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-28-2002, 11:16 AM   #339
RCTech Member #2
TSR6's Avatar
BigDogRacing - They were trayed, but only till the lights went out. I did charge them at higher amps though, I was charging at 7a, when before i charged them at 6 to 6.5a.
Kraig - I wasn't using long lockout. For threshold i think i was using .05, .06 or somewhere on there. I don't remember for sure.
Troy
RCTech Member #2
Old 01-28-2002, 11:36 AM   #340
R/C Tech Founder
I have been cycling and charging my SMC HV packs at 7A with a .07 cutoff and have never experienced a false peak.
My SMH's I charge at 5A with a .03 cutoff, and no false peaks there either.
After use, dump at 30A and store, no trays. That's my method; seems to work for me. My HV's have all gained .05-.10 volts (that's per pack, not per cell) since I first cycled them. Probably about 7-9 cycles through them now.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 02-05-2002, 06:01 PM   #341
Send a message via AIM to ZER01
Anyone know what I should set my Turbo35 peak detection to when charging 1800mAH NiMH's(AA's)?
ZER01 is offline   Reply With Quote
Old 02-05-2002, 06:42 PM   #342
rcruv's Avatar
Voltage of NiMH cells do increase after charge, discharge.
It doesn't neccessarily mean a good sign, it could mean that internal resistance increased and efficiency decreased.
You should try it on the track or dyno with enough load to see if cells have improved in good way.
Just my 2 cents
rcruv is offline   Reply With Quote
Old 02-05-2002, 08:36 PM   #343
Fire's Avatar
I used 30mV to charge 4 cells AAA packs, seems pretty good, but my charger is no where near Turbo35.
Old 02-05-2002, 08:55 PM   #344
Thanks Fire! I'm using .02, they false peaked on me 30 sec. after charge with .01. So far so good!
Old 02-05-2002, 10:38 PM   #345
wacky's Avatar
Default Help !!!
One of my HV Cells has this venting and some corrosion on the connection between the battery bars ... I only used this for about 5 runs and I noticed this venting on one of my hv cells. And also the voltage reading is alittle bit higher by 0.05v compare to the rest. Is this very alarming. Or is the cell already near its dead state.
My other cells doesn't have any signs of this venting.
Need you help guys ........
wacky is offline   Reply With Quote
sanyo 3000HV ruftnik Rookie Zone 2 11-09-2003 06:05 PM
New Sanyo 3000HV PMR packs rayhuang R/C Items: For Sale/Trade 0 02-25-2003 11:18 AM
Sanyo 3000HV lilshortyc3 Electric On-Road 4 12-20-2002 02:34 PM
1 New Integy Sanyo 3000HV hohen711 R/C Items: For Sale/Trade 1 09-11-2002 01:31 PM
