Old 11-09-2001, 09:46 AM   #181
Company Representative
Danny/SMC's Avatar
In theory the extra shrink will heat up the cells a bit more. I can do a test and post the results later. I don't think it really hurts anything to put shrink on the cells especially if you use thin shrink.
I would set the peak detect at .01-.02 for the micro packs. Maybe the pack had charge in it. It should take close to an hour at 1 amp to charge if they are real 1100's.
Danny/SMC is offline   Reply With Quote
Old 11-09-2001, 10:08 PM   #182
Danny:
Hi, I have question for you about the SMH cells. A team driver at our track has some that he runs Mod with. he uses a older Novak charger (DigiPeak I think) to charge them. last Sunday he would charge a pack up on the Turbo 30 and I would always check the mah's when they were done. in pack would have a really high mah number then a lower one the 2nd time I charged it and then a higher number the last time I charged it. is it normal for SMH cells to vary from charge to charge????? ( I think there was a 500mah difference between the 1st and 2nd numbers)
Thanks for your time
Fakk2
Fakk2 is offline   Reply With Quote
Old 11-10-2001, 04:02 AM   #183
Send a message via ICQ to MattW
Sounds like they weren't discharged fully.
Should finally get to try my HV's this weekend.
MattW is offline   Reply With Quote
Old 11-10-2001, 08:01 AM   #184
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Originally posted by Danny/SMC
mike webb: It's hard to judge mAh by what the charger is telling you.
If you take to packs with 360 seconds @ 30 amps which equals 3000 mAh. The pack with the lower internal resistance in milliohms will take less time to charge so your charger will give a lower mAh reading. The only true way to get a mAh reading is to do a constant load discharge.
This is why I never pay attention to what my Pitbull is giving for mAh.
Fakk2 - Danny posted that a little while ago. That should answer your question.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 11-10-2001, 08:47 AM   #185
Troy:
Thanks,
I kinda posted after working 14 hr day and never really took the time to reread all the posts. DOH................. and BTW, thanks for running a great forum. I will be around more often.
Fakk2
Old 11-10-2001, 09:49 AM   #186
Danny/SMC's Avatar
The IR of the pack has something to do with how easily it will charge. Another thing to note is that different chargers will charge at different rates even if they are set equally. I have 2 matchers that charge 75-100 seconds faster than my other ones and they are all set at the same amp rate.
Racers are reporting that NiMH's pack are stronger on the track the second run. This has to equate to lower Actual IR and an increase in voltage. If this is the case the pack will take less time to charge because of the lower IR.
Yesterday I cycled a pack that I used last week. The first cyle the pack had an Actual IR of 24.6 and 3 hours later it cycled out to a 23.9 with .02 more voltage. I didn't pay attention to charge time but I'm pretty sure it would of been less than the first cycle.
Old 11-10-2001, 10:46 AM   #187
RCTech Member #2
TSR6's Avatar
Originally posted by Fakk2
Troy:
Thanks,
Fakk2
No problem.
Shane ( futureal ) is the one who runs everything, and he does a great job.
Glad you like it though
Troy
RCTech Member #2
Old 11-10-2001, 01:12 PM   #188
Troy:
I saw that after I posted..... I really think I should sleep before I post..... but then I'd never post. I really do like this place. I'l try to log on from my cell phone from work to see if I can get here more often.
Fakk2
Old 11-13-2001, 11:23 AM   #189
ottoman's Avatar
R/C Tech Charter Subscriber
Danny- What discharge tray do you recommend for the 300HV's?
ottoman is offline   Reply With Quote
Old 11-13-2001, 11:41 AM   #190
Danny/SMC's Avatar
So far it seems like a tray with diodes does the best job if you don't plan on deadshorting. It seems like the runtime doesn't drop as much. If you plan on deadshorting I would use a tray that brings down each cell in the millivolts.
Old 11-13-2001, 01:05 PM   #191
Regional Moderator
mr4-malta's Avatar
Danny,
i sent you a private messages a few dyas ago....dit you get it?..
please check your PM inbox
thanks!
mr4-malta is offline   Reply With Quote
Old 11-13-2001, 01:33 PM   #192
Fred Hubbard's Avatar
Default S3000HV vs. P3000SMH
Danny,
What do you think about using the "IR" as a determing factor for
investing in either the S3000HV or P3000SMH cells for stock TC racing? From what I have seen the "IR" on the P3000SMH cells tends to be lower. Thanks...
Fred Hubbard is offline   Reply With Quote
Old 11-13-2001, 01:40 PM   #193
Danny/SMC's Avatar
Are you talking about Relative Ir or Actual IR ? The relative IR is higher on the HV's because of it's cell construction it peaks at a higher voltage than SMH's.
The Actual IR is similar to the SMH's which is what really counts plus our tests have shown that the HV's are slightly faster on the track where it really counts. Remember machines are good tools to give us info but the track is the ultimate test.
Old 11-13-2001, 01:46 PM   #194
I am referring to the actual ir, I agree with you, the track is the ultimate test. Thanks...
Goodwine Racing - RC America - XRAY - HUDY - Sanwa - Motiv - GravityRC - BN Racing
Old 11-13-2001, 01:53 PM   #195
Danny/SMC's Avatar
SMH's range from 3.2-3.8 and HV's range from 3.3-4.0 so they are very similar. Also when you build a pack of HV's the A-IR will be closer to the label than a pack of SMH. Example a 3.2 SMH will cycle out at 13.9 per pack in a 4 cell configuartion which is 3.48 per cell. A 3.4 HV will cycle out at 13.9. This is in part because of the cell construction of the HV and the way we match.
sanyo 3000HV ruftnik Rookie Zone 2 11-09-2003 06:05 PM
New Sanyo 3000HV PMR packs rayhuang R/C Items: For Sale/Trade 0 02-25-2003 11:18 AM
Sanyo 3000HV lilshortyc3 Electric On-Road 4 12-20-2002 02:34 PM
1 New Integy Sanyo 3000HV hohen711 R/C Items: For Sale/Trade 1 09-11-2002 01:31 PM
