Xxx-s?
Old 03-11-2004, 02:16 PM
Default Xxx-s?
what are the the top 10 things that need to be fixed on the XXX-S or what modification would you like to see on the chassis.
SPC Racing is offline
Old 03-11-2004, 02:18 PM
is it a graphiteplus?
True R/C Racing is offline
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Ask in the XXXS thread...
Randy Caster is offline
Old 03-11-2004, 02:19 PM
that works too
Old 03-11-2004, 02:20 PM
R/C Tech Founder
There's not really that much that needs to be "fixed" other than an easy droop screw system.
futureal is offline
Old 03-11-2004, 02:55 PM
It would be nice if foam tires didnt rub so bad on the front shock ends.
donny is offline
Old 03-11-2004, 03:20 PM
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I built a Tamiya for Reedy Race practice, I forgot how wonderful it is to setup a car with droop screws that actually work!
Jon Kerr is offline
Old 03-12-2004, 12:23 AM
Trader Rating: 16 (100%+)
Default Re: Xxx-s?
1) I would have the left side of the chassis a little wider to make it easier to balance the weight of the car from side to side.
2) Some form of protection for the endbell of the motor would be helpful.
3) A fifth body mount post (see MF's car) in front of the windshield.
4) A drag link with different attachment points for the link to the servo.
5) Figure out a fix for stripped screws in the graphite chassis.
Regardless of the comments above...It is a great touring car.
Still Bill is offline
