Old 12-28-2009, 12:14 PM   #1
cheehtae's Avatar
Trader Rating: 15 (100%+)
Default thick or thin chassis
Thick or thin chassis for carpet (rubber and some foam) 3.6 on the thick one and 2mm on thin one, both carbon fiber. Which one should I go to? any help is appreciated.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 12-28-2009, 12:17 PM   #2
05tuonojoe's Avatar
The thinner one is for rubber. You can make either chassis work for either tires but your going to have to change the setup. Decide which your going to run most and get that chassis.
Joe Walllace
Associated RC8B, RC8T
Houston engine service Novarossi +4
05tuonojoe is offline   Reply With Quote
Old 12-28-2009, 03:16 PM   #3
decibels's Avatar
i would say thick with getting an optional thin upper deck if available as flex for foam is not wanted and for rubber carpet it is still in pretty much the same boat. maybe a slighlty flexier top deck would give a tad more overall steering if needed for rubber!! but for peice of mind my brother runs a jrxs type r on rubber and it is as stiff as they get!! but also we have modified his top deck to give a little flex for better overall handling charecteristics but it is always fast on rubber.
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 12-28-2009, 03:26 PM   #4
Foxxrocket's Avatar
Chassis flex is vary important in handling. Carpet chassis are going to be much more ridgid, and will flex less. Chassis set up for asphalt are going to flex more. So if you're going to race carpet, you want a thicker chassis with a foam tire setup. And a thinner chassis for asphalt, with a rubber tire setup. But either tire can work for both surfaces.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 12-28-2009, 10:07 PM   #5
Toh WL's Avatar
In carpet you use softer tires for better grip. Asphalt you need harder tires.
Toh WL is offline   Reply With Quote
Old 12-29-2009, 04:00 AM   #6
tc3team's Avatar
If the track you race at is very small and twisty, I have preferred a stiffer chassis when using foam tyres.
the car seems to feel like it has more rotation, which to me feels like it is aided by the thicker chassis, although tyre choice and car setup is very important too. The track I race at is 10x15m and is high grip.
hope that helps
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 12-29-2009, 04:58 AM   #7
cheehtae's Avatar
racing will be mostly carpet rubber , with a chance of foam carpet.
Old 12-29-2009, 05:17 AM   #8
trerc's Avatar
Trader Rating: 89 (100%+)
Thin chassis, possibly a thin and thick upper deck, if that's an option.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Titanium chassis? captain america Nitro Off-Road 14 07-11-2009 11:14 AM
Thick Vs thinner chassis? tc3team Electric On-Road 12 03-05-2008 04:35 AM
