Old 12-28-2009, 09:46 PM   #16
TfnG's Avatar
Trader Rating: 26 (100%+)
Originally Posted by TimV View Post
I always run my battery shimmed out to the side of the top deck. Helps balance the car, and keeps you from have to raise the top deck. Seems to work out fine. All of the top drivers around here do it that way instead of raising the top deck.
exactly the way its done where im from. learned that from a factory xray driver.
GRAVECLOTHING.COM PROLEVELRC.COM
TfnG is offline   Reply With Quote
Old 12-29-2009, 04:24 AM   #17
bluephi1914's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Nilks View Post
Does it have to be 50C? If yes, why? You can draw almost the same amount of amps from a 28C 5300mah than you can from a 50C 3200mah.
I use the LRP 5300mah 28C and it fits in my Xray T2 '009 without the LiPo pads with the bumps on the battery turning upwards.
The problem is ALMOST. Almost is only acceptable when playing horse shoes. . JK... but seriously, I notice more punch with my 50C batteries than I did my IP 3800 w/28c . Its the "almost" that makes the higher C rated batteries a little faster. That "almost" could mean the between 10.3 and 10.9 lap times. and over the course of a race.... could mean alot more than that.
Plus it just sounds better too. ... 50c
Mr. 17.5 's Rides ----> T3 EU / T2 008 EU (Vintage)
** NEXUSRACING.COM **
** Team Xray - Team Novak - Proline - Sorex - KO Propo - Team Trinity **
bluephi1914 is offline   Reply With Quote
Old 12-29-2009, 05:19 AM   #18
trerc's Avatar
Trader Rating: 89 (100%+)
Originally Posted by bluephi1914 View Post
.Plus it just sounds better too. ... 50c
Man, That does sound fast...
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 12-29-2009, 06:23 AM   #19
Benzaah's Avatar
Trader Rating: 21 (96%+)
IMO If your using a soft flex setting you need the lipo pads. Even with some Ip3800 35c packs the deck was fouling my lipos and causing uneven tweak. I now have the lipo pads and the xray weights with some SMC 40c packs and they work great. I don't think moving the top deck up the amount the pads do will affect the handling like you think it will.
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
