If you real precise setup get 4 digital scales...ebay has em for cheap usually..make sure it is the ones that go down to .1 gram...you car will really be setup nice
Re: Who makes the best tweak station?
Originally posted by popsracer Guys; I have the Integy Laser tweak station and it does a excellent job. My only complaint would be of the Bubble Vial for leveling. Even with the newest version it is almost impossible to find center. I've been using a separate machinist level to set-up the tweak station before placing my Car(s) on it. Blake |
My 5 year old Niftech does the trick!
Re: Re: Who makes the best tweak station?
Originally posted by dr_hfuhuhurr That's the beauty of the laser tweak station...you don't need to level it before checking tweak. Using the laser method eliminates the need. Blake Take a sharp Pencil and try to stand it vertically on the tip/point. Probably almost impossible. If you have the Tweak Station leaning at an angle (even slightly), I believe that the setting will be off. For this reason I go to great pains to level mine before checking a Car. |
Yes that is therotically true but it is close enough if the surface is generally level. I have used the integy tweak station for more than a year now and it is very good. The best part is you can also use it to equalise your droop as well.
The only problem with the penny deal is it tells you when your suspension travel tops out & starts to pick up the tire that has topped out when you lift it up & not equilizing the weights on each wheel loaded. Seems the penny works if you know each sides suspension hits the end of its up travel at exactly the same time. On a touring car it would be affected by the accuracy of the droop screws on each side matching. I would think a loaded chassis on a good tweak board is better. R.W.
The real issue for 12th scale is the sensitivity of the tweak bord your using. ANY tweak board will work sufficiently for a TC because a TC has such a wide footprint and so much mass. A 12thscale car requires a FAR greater sensitivity. Most commercially available stations won't notice a 1/16th of a turn on 12th scale tweak screws, but a 16th of a turn can be noticeable on the track. If you don't have a compressed spring on one side of your 12th scaler, then the coin trick is ALWAYS more accurate.
If you've got a compressed spring on one side of your front-end you really won't be able to set tweak either way. The car will have unregulated suspension travel on the side with the compressed spring, and that leads to all sorts of handling irregularities that can feel like the tweak is off, or even a radio hit. |
I always level mine also. My Integy instructions never mentioned balancing out the laser end of the station. After you install the battery, that end is no where close to being level. I really started to dislike it when I tweaked my touring car on it and the adj's I made didnt seem to show up on the tweak station as fast as on my old MIP one. I went back and forth between the two and found that, for some reason, the MIP was much more sensitive than the Integy to changes in the shock collars. It looks cooler but just didnt perform as well as the cheap old MIP.
Laser Tweak Station
Guys;
Even being able to adjust the battery position for balance, I myself find it about impossible for the Laser Arm to find level. As I am writing this I just got an idea. Instead of balancing using the teeter/totter method. I am going to try balancing like you would an Airplane propeller. Might make for a slightly more accurate set-up. |
I know this is an old thread, but would like to get more opinions on newer or updated tweak stations for a 1/10 pan. So please contribute and help a newbie get up and running with the proper equiptment.
Originally Posted by ottoman
(Post 765390)
Unity is the BEST hands down
Scales is the other option |
kinda un related but i just got a mip tweak station but no directions so i am not positive how to use it or what i am really using it for. Anybody know where i can find directions for it?
Originally Posted by rocketron
(Post 4423031)
Scales is the other option 2 votes for Unity http://www.unitytool.com/Unity_Tools...ek_boards.html works with all scales |
(Post 4423031)
