Old 12-20-2009, 11:51 PM   #1
The Hawaiian's Avatar
Trader Rating: 94 (100%+)
Talking spring rate ????
aloha all...is there a trick to find out what the spring rate is on different springs in lbs. I have a bunch of springs but don't know there rate (if thats the right term)
Justin "haole boy" Perry USCG (CGC Firebush)
NewRed Hobbies & Indoor Facility, da BEST clay off-road track in Florida.
!!Treat me the way you want to be Treated!!Race me the way you want to be Raced!!
The Hawaiian is offline   Reply With Quote
Old 12-21-2009, 12:34 AM   #2
zangonli's Avatar
Here is how I did it using a vernier digital caliper and a cooking/food weight scale which I had lying around. You need a steady hand to do this but
Set the caliper to the free length of the spring (its length without any load on it.) Place the spring vertically on the weight scale's measuring surface and then lower the caliper with its depth probe end first (with the caliper set to the spring's free legth) into the spring until the depth probe tip just touches the measuring surface. Then push down on the caliper a quarter inch (or some other suitable compression distance), which results in the spring being compressed by the same distance - read the weight scale at that compression setting. The spring rate is given by dividing the weight reading by the compression distance.
Perhaps someone has a more clever or easier way to find the spring rate (e.g. using known and precise weights to compress the spring while making a distance measurement.)
zangonli is offline   Reply With Quote
Old 12-21-2009, 01:18 AM   #3
Uga
Uga's Avatar
Thanks zanglonli, your method works like a charm, measured a 17.5lbs spring as 18.0lbs, which is pretty close considering that it's quite hard to keep the pressure even to get a good reading from weights.
I imagine that it could be a bit more precise to use a fixed weight balast which you can put on top of the spring and have an opening in the middle where the caliper depth probe goes in. That way you also wouldn't need the weights each time once you know the weight of your balast piece.
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 12-21-2009, 04:06 AM   #4
you can also rig up a G-clamp to compress your spring+scale into a bench and slowly wind it down measuring the heights and weights as you go.
gameover is offline   Reply With Quote
Old 12-21-2009, 07:42 AM   #5
can I use a bathroom scale???it sounds like some weird math to me
Old 12-21-2009, 08:14 AM   #6
stiltskin's Avatar
Trader Rating: 102 (100%+)
Yeah, but make sure that you subtract 10 pounds. Those things always make me fat.
Tony Rumple
Team EAM // Gravity RC
stiltskin is offline   Reply With Quote
Old 12-21-2009, 09:24 AM   #7
Trader Rating: 24 (100%+)
Do you know what manufacturer makes them? I have a bunch of sheets that I've collected specifying spring rates for various makes.
Evoracer is offline   Reply With Quote
Old 12-21-2009, 09:53 AM   #8
wiscnitro's Avatar
Trader Rating: 22 (100%+)
If you have a local speed shop near by take the springs to them, They have spring rate compressors for checking the rates of valve springs though im not sure if it will measure something that light. give it a try they would probly try it for free
Hold my beer and watch this! :)
wiscnitro is offline   Reply With Quote
Old 12-21-2009, 10:10 AM   #9
me too...but I don't know the manufacturer, thats the problem
Hara Spring Rate Chart? Skiddins Electric On-Road 9 10-21-2007 05:28 AM
