Old 03-09-2004, 08:31 AM   #1
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
Default Foams on Carpet
I have only ever run on carpet once and i didnt know what i was doing, and since there are alot of carpet tracks in America, i was hoping someone could answer my question.
What foam tire compounds work best on carpet?
and
Should i use traction compound?
Thanks for any help
dontfeelcold is offline   Reply With Quote
Old 03-09-2004, 08:45 AM   #2
Regional Moderator
R/C Tech Charter Subscriber
Default Re: Foams on Carpet
and
Thanks for any help
I have been using purples (rear) and plaids (front) and pargon for traction
Ko Racer is offline   Reply With Quote
Old 03-09-2004, 08:59 AM   #3
EricF's Avatar
Which shore rating you use depends on how much traction is available. If traction is low I would suggest using a soft shore tire like cyan front and tan rear (TRC tires) the Cyan is a 37/45 and the tan is 37.
As traction goes up move up to a harder tire. Like plaids and purples 40/45 and 40.
Also glue the outside edge of the foam on the front if the car turns in too hard and wants to traction roll.
Just my opinion.
E
AE 12R5.2 & R6(x2) - TC7.1 convert, F6 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 03-09-2004, 02:26 PM   #4
fatdoggy's Avatar
Orange Purple(plaid) and Purple or Orange d.pink and d. pink.
Definately use compound, paragon works well. I used some corally tc3 compound on the weekend and it seems to work well to.
fatdoggy is offline   Reply With Quote
Old 03-09-2004, 02:36 PM   #5
R/C Tech Founder
Definitely try plaids in the front and purples in the rear as a starting point. Sauce the rear tires fully with a traction compound like Corally's Jack the Gripper, Paragon, or TQ Blue or TQ Orange. Sauce the inside 1/3 of the front tires as well. Let it sit for about 10 minutes and then wipe the tires off before you hit the track.
If the car is still too loose, you can try going to a softer rear tire, like the aforementioned tan. If you want to stay equal on both ends for more bite, try cyan fronts and tan rears.
Foam tires are set by a shore rating, where, for example:
Orange: 45
Purple: 40
Tan: 37
When you look at a "Plaid" tire, it has the outer 1/3 edge of the tire in a harder foam (orange) and the inner 2/3 in a softer foam (purple). Same for Cyans. This stops the outer edge of the tire from biting in too hard in the corners.
If your car is traction rolling, you may also try putting a bead of CA glue along the very outer edge of your foam tires -- this practice is pretty standard at high bite tracks.
You may also pick up the latest issue of Xtreme R/C (#101) for my article on foam tire versus rubber tire setups, which covers some other basic things to try when running a foam car.
Good luck!
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 03-09-2004, 06:24 PM   #6
Nova F1 Racer's Avatar
First what kind of car 10 scale-12 scale 2 /4 wheel drive etc..
Motor 27 vs 10 turn.
What kind of carpet?
On www.rc4less.com they have this explaining foams...
Hope this helps...
Green 30+/-
Medium compound recommended on medium traction carpet tracks.
Blue 50+/-
Medium/harder compound, recommended on extremely high traction carpet tracks and on asphalt tracks.
White 30+/-
Soft compound, recommended for rear tires on low traction carpet tracks. Works well in modified racing on the rear.
Gray 35-40
Medium compound recommended on medium traction carpet / abrasive asphalt tracks. Low wear / longer lasting.
Pink 30
Soft compound recommended on low traction asphalt tracks and as the inside front or rear on low bite carpet tracks.
Double Pink 35
Slightly firmer pink, recommended on low traction asphalt tracks and more abrasive tracks.
Purple 40
Medium/hard compound recommended on high traction asphalt or carpet tracks. Low wear / longer lasting.
Double Purple 45
Hard compound recommended on high traction asphalt or carpet tracks. Low wear / longer lasting.
Red 50
Hardest compound recommended on high traction asphalt tracks. Good for right front. Lowest wear / longest lasting.
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
GQ Carpet Foams... TigeRyan Electric On-Road 144 02-17-2007 05:23 AM
What foams for carpet floodo1 Electric On-Road 34 09-07-2006 05:27 PM
Carpet foams TOEBSTER2 R/C Items: For Sale/Trade 2 05-05-2006 02:41 PM
Carpet with foams??? SPC Racer Electric Off-Road 3 05-23-2005 11:18 AM
Different Carpet Foams Paul_TC4 Electric On-Road 66 11-11-2004 04:04 PM
