Old 12-18-2009, 07:00 PM   #1
mytto1's Avatar
Questions?? need help with lipo charge settings
hi everyone,
i am new to lipo batteries. just bought two 2s 25c 5000 turnigy batteries for my tto1. i also have the onyx 230 ac/dc charger, but i didnt touch any of the charge settings and still charged it. im pretty sure the default charge set up is kinda crappy. what amps should i use from 0.1amps-7.0amps? and also there is some kind of self timer thing im not sure what that is but there is a settng from 0 minutes to 300 minutes or off.what should i do for that. and i want the best possible charge for a good run time and with the mosty power.
thanks evryone for ur help
mytto1 is offline   Reply With Quote
Old 12-18-2009, 07:39 PM   #2
PDX-Spike's Avatar
Originally Posted by mytto1 View Post
hi everyone,
Set the battery type to Lipo and charge it at 7.4 volts and 5.0 amps (or 5000 milliamps). You do not have to set a charging time.
After it has charged for awhile, the amps charge value should begin to decrease until the battery is fully charged. It will probably take over an hour to complete the charge. When done charging, you should not re-peak it. Just use it as is.
READ THE MANUAL. If you don't have one, here is a link to it.
Onyx 230 Manual
Roger Christal - Team Timezone (Hooligans), Rose City Scale Racing, ROAR Member until 9/16/2012
Support the locals: Timezone Raceway, Timezone II, R/C Plus, Portland RC Raceway
McKune Design, Slapmaster Tools, Houston's Engine Service
PDX-Spike is offline   Reply With Quote
Old 12-18-2009, 08:00 PM   #3
SPC
Registered User
hi everyone,
I have to ask; didn't the packs come with any instructions?
I agree with PDX-Spike, the charger instructions will probably help to get things going.
SPC is offline   Reply With Quote
Old 12-18-2009, 08:07 PM   #4
Toh WL's Avatar
They usually came with one piece of small paper with some warnings telling you to charge at 1C.
Toh WL is offline   Reply With Quote
Old 12-18-2009, 09:10 PM   #5
mytto1's Avatar
is it normal for it to only charge up to about 2500 mah when its a 5000 mah?
Old 12-18-2009, 09:17 PM   #6
Regional Moderator
CarbonJoe's Avatar
Yes, most mfgs ship LiPo packs charged between 50% and 75%.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-18-2009, 09:18 PM   #7
Toh WL's Avatar
Just charge it at 5A with balancer till full charge. Please do not charge lesser or more unless stated.
LRP Pulsar 3 - Need help bigemike Electric On-Road 19 10-11-2007 03:09 AM
need help which lead?????? teammidget lilB Micro and Mini Scales 10 12-24-2006 10:12 AM
