Nemesis 17.5 motor thread >
Old 12-19-2009, 01:42 PM
  #16
Trader Rating: 22 (100%+)
Gearing Help on the 17.5...
It's going in a T2 008 and has a SPX set on profile 7.
Right now I am using FDR 4.17 with a Novak 17.5, where should I be at with this motor?
GTSSTANG is offline
Old 12-19-2009, 03:17 PM
  #17
thisguy2849's Avatar
You want to start at around 4.05 fdr
thisguy2849 is offline
Old 12-19-2009, 03:31 PM
  #18
Originally Posted by thisguy2849 View Post
As the guy who set the timing on the motors I will tell you that the timing looks like 10 degrees BUT since 0 on the end bell is closer to -10 its pretty much 0 degrees when set between the 10 nd 20 markings at the long line between the numbers
Awesome! Now this is what I call service! Thanks a lot for answering all of my questions so quick.
windsor is offline
Old 12-19-2009, 06:35 PM
  #19
Johnny Wishbone's Avatar
Originally Posted by windsor View Post
I am running a tekin rs. When you say you were 5 teeth off do you mean higher or lower?
5 teeth less on the pinion, usually a 43 now on a 38.
Johnny Wishbone is offline
Old 12-19-2009, 06:57 PM
  #20
Wow. So your rollout is much lower with this motor then. Thanks for your input! Anyone running it in stock 1/12 yet and seeing the same thing?
windsor is offline
Old 12-20-2009, 09:43 AM
  #21
gashuffer's Avatar
Trader Rating: 48 (100%+)
I ordered one on Friday and it will be going into my TA05 with a SPX on the infamous profile 7. I was running a black can stock motor 96/39 with a final drive of 5.04. Where should I be with this motor on a medium to large track?
gashuffer is offline
Old 12-20-2009, 10:43 AM
  #22
I think you run at my track too.... I asked basically the same question.. Look up a few posts....
It was recomended to start with 4.05...
GTSSTANG is offline
Old 12-20-2009, 11:17 AM
  #23
gashuffer's Avatar
Yeah your right, but for me to get to 4.06 I would have to run a 48t pinion that can't be right?? My trans ratio is 2.055
Old 12-20-2009, 11:23 AM
  #24
Trader Rating: 36 (100%+)
So, your saying that if I reset this to the 0 point on the can, it's really in negatives? If this is the case, why didn't they just label it correctly?
EVILGRAFX is offline
Old 12-20-2009, 12:11 PM
  #25
Its just the way the sensor was designed
Old 12-20-2009, 03:00 PM
  #26
Okay, if the sensor is designed that way, why not label it the same way the sensor is set? That way, when I (or anyone) set it to 10 degrees, it's actually 10 degrees and not negative two to five somewhere.
Old 12-20-2009, 03:07 PM
  #27
gashuffer's Avatar
C'mon dude it is what it is. No reason to start a flame war
Old 12-20-2009, 03:26 PM
  #28
I'm not starting a flame war. It's a simple question.
It is what it is? That's just stupid dude. C'mon.
Old 12-20-2009, 03:32 PM
  #29
Okay, so we know that twelve to fifteen degrees on the can is really closer to zero degrees actually.
What about people who don't read RCTech? How are they supposed to know that when they set their motor to ten degrees that it's actually negative two to negative five degrees?
I understand that they can't be exact but, why not label it close to the way it is?
Why label it different?
Is it to keep people who aren't in the know from easily over-setting the timing?
That's all I'm asking.
Old 12-20-2009, 03:45 PM
  #30
gashuffer's Avatar
What's stupid about that. They told you how to read the timing but thats not good enough. This information is found other places than RCtech and if you don't race then it doesn't matter
