Old 09-09-2013, 01:42 PM   #1351
trick25's Avatar
Trader Rating: 27 (100%+)
which spur gears can you get from US that will fit zero with vertical mount in around 65t range 48p for 21.5?
edit. mine is a sakura zero s. i realize im going to have to get a vertical mount.
17.5 2wd-XB2 17 CE , 2wd mod truck-xt2
4wd SC-SCT410,13.5 4wd -D413
trick25 is offline   Reply With Quote
Old 11-03-2013, 01:23 PM   #1352
GP40X's Avatar
I have a Sakura Zero version 2 Vertical mount and a pair of 96 tooth sour gears for sale.
Sakura Zero S Turnigy TD10 parts
With the vertical mount you can go as high a a 51 tooth pinion with the 96 tooth spur gear.
Bill
"I used to be disgusted, now I'm just amused."
Team Qik
CustomWorks Outlaw Sprint Car
Xray T3 2012 USVTA
GP40X is offline   Reply With Quote
Old 02-03-2014, 07:11 AM   #1353
can someone recomend me a spur gear, prefered from Canadian / us source for quick shipping. I am using 4000 kv motor and running at a parking lot.
Another question is I am using a high voltage 7.2v servo, and receiver, but ESC only output 6v BEC. how can I wire them to 7.2v, If I wire through battery directly, it would direct electronic noise to receiver and servo.
modelerbj is offline   Reply With Quote
Old 02-14-2014, 08:21 AM   #1354
where is the rubber o-ring goes? between spring and the ride-height adjuster?
Old 02-14-2014, 08:25 AM   #1355
SteveM's Avatar
Trader Rating: 142 (100%+)
The rubber O-ring sits inside the threaded shock collar. It is used to provide some friction so that this collar does not loosen on its own.
SteveM is online now   Reply With Quote
Old 02-14-2014, 05:14 PM   #1356
are you talking the small one?
I am asking about the big black one.
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
