Old 11-02-2011, 12:42 PM   #1306
Gustavo p's Avatar
Default hello
Hi what's is the different between Sakura zero and Sakura zero s"????
Guravorac1ng
TEAM LMR
Sweep racing tires
EDWIN DESIGN
Gustavo p is offline   Reply With Quote
Old 11-02-2011, 12:49 PM   #1307
Pro10noob's Avatar
Sakura Zero S is:No carbon and almost no Alloy.
Sakura Zero is: All carbon and alloy.
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 11-02-2011, 12:51 PM   #1308
FauxMako's Avatar
The Zero S is the "entry level" version of the Zero. It's got FRP instead of graphite/CF and plastic instead of aluminum for some of the parts. You could convert a Zero S to a Zero by getting all of the parts individually if you wanted to. Other than that they are the same chassis. You can download the manuals for both from 3racing's site if you want to compare them piece by piece.
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Old 11-02-2011, 04:24 PM   #1309
Gustavo p's Avatar
Talking
Guravorac1ng
TEAM LMR
Sweep racing tires
EDWIN DESIGN
Old 11-06-2011, 11:36 PM   #1310
regards Roy
I just got the 'S' . Only as I wanted a cheap RC car for a 2nd fun car.
Surprising just how much of the 'S' is actually plastic.
Only significant alloy chassis part is the Motor mount.
Shock towers are FRP.
FRP chassis isnt that bad, much more rigid than my Xray T3R FRP chassis
Shocks are UNTHREADED plastic, uses shims . A bit disappointing (but I knew in advance)
'S' has fr & rear gear diffs. A big bonus point.
Also has wheels .
Cheers
1101 is offline   Reply With Quote
Old 12-01-2011, 08:24 PM   #1311
My daughter's Sakura Zero... the girly pinky rc car...
Sakura Zero rc car - more photos, setup, review.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 02-18-2012, 10:21 AM   #1312
haha i love the pit mat.
www.serpent.com
www.comedycomposite.com
http://www.rc-ride.co.jp/
Titanium is forever...?
Operator27 is offline   Reply With Quote
Old 02-18-2012, 10:30 AM   #1313
does anyone know of a set of spec r cv shafts that will fit the sakura. i think i wana try drifting my extra chassis.
www.serpent.com
Old 02-18-2012, 10:44 AM   #1314
Pro10noob's Avatar
I used Tamiya axles on my Sakura as i didn't have any spare 3Racing when one broke
So the spec-r for Tamiya would fit also correct me if i am wrong.
regards Roy
l===/o\===l
Old 02-18-2012, 10:47 AM   #1315
nice. thanks man ill give it a try.
how well does the it fit into the diff housing. is it looser or tighter.
www.serpent.com
Old 02-18-2012, 10:58 AM   #1316
Pro10noob's Avatar
Used them up front in a spool.
No problems at all as Tamiya and Sakura spoolcups are the same.
I guess that you need the 3racing blades on the spec-r axles to let them fit.
regards Roy
l===/o\===l
Old 02-18-2012, 11:01 AM   #1317
so how similar are the sakura and the 416(nobody i know has a 416). do they share any other parts. i like sakura but i like tamiyas quality alot more than 3racing
www.serpent.com
Old 02-18-2012, 11:10 AM   #1318
Pro10noob's Avatar
Have had them both.
Sakura Zero with the Tamiya 416 rear mod and still own a 416X lipo.
Diff's,pulleys and springs you can use when you have the plus4 shocktower up front and the rear mod done.
Some use the C-hubs from the sakura on there 416 but i didn't.
Never had any quality issues
regards Roy
Sakura Zero - New Touring Car!-dsc00172.jpg   Sakura Zero - New Touring Car!-sakura-rear.jpg
l===/o\===l
Old 02-18-2012, 11:15 AM   #1319
thats awesome, i appreciate your help man thanks for the pics.
www.serpent.com
Old 02-18-2012, 11:21 AM   #1320
Pro10noob's Avatar
Your welcome.
Use the Sakura X1 rear lower arms and then use the normall suspensionblocks.
You get a smaller rear but more rear end grip.
Mine had the same and was awsome.
I needed to alter the front setup to get more steering.
It was a very neutral car after that.
Used the same setup on the TRF as on the Sakura.
Lap times where just 2 tenth apart but that was due to a different motor in the Sakura(Speedpassion in Sakura and LRP in the TRF).
regards Roy
l===/o\===l
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
