Old 06-22-2011, 08:50 AM   #1186
Pro10noob's Avatar
I believe the release date is august?
regards Roy
Originally Posted by DanDan View Post
Thanks for all the update and pics.
Hope it will be release soon.
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 06-22-2011, 08:23 PM   #1187
JimmyMac's Avatar
Are you girls still using the Narrow rear blocks with the short arms?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 06-22-2011, 09:11 PM   #1188
cannon's Avatar
Trader Rating: 35 (100%+)
i currently use the narrow block with the new narrow arms and my car is good like this
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 06-22-2011, 09:55 PM   #1189
Mark Flores's Avatar
Trader Rating: 28 (100%+)
What are the part numbers for the short arms? Thanks!
Mark Flores is offline   Reply With Quote
Old 06-22-2011, 09:56 PM   #1190
regards Roy
The 3racing site says Mid July!
Old 06-22-2011, 10:10 PM   #1191
cannon's Avatar
Why are people so lazy they cant look the part numbers up themselves?
SAK-X01
SAK-X02
Old 06-22-2011, 11:59 PM   #1192
SAK-X01
SAK-X02
Thanks Cannon. Just wasn't sure those were the right ones. 3racing site does not mark them as narrow.
Old 06-23-2011, 12:09 AM   #1193
Pro10noob's Avatar
If you look at the HK shops it says that these are the shorter arms
That was how i found them and ordered them.
regards Roy
l===/o\===l
Old 06-23-2011, 03:32 AM   #1194
I am running standard width blocks front/rear.
DanDan is offline   Reply With Quote
Old 06-23-2011, 04:32 PM   #1195
JimmyMac's Avatar
I ran my short arms last with standard blocks in 17.5, but I wanna try my narrow blocks with short arms. I only have 2 standard rear toe block. I'm switching my Zero to mod... so I need at least 3 rear toe for that. My TA05 will take over my 17.5 duties. If the weather holds out, I may get to try it. We'll see.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 06-24-2011, 12:45 AM   #1196
let us know how that goes Jimmy, was wondering myself whether to use the narrow blocks and arms together or just use one way to narrow the rear (plus the 4mm hexes)
Old 06-26-2011, 12:02 AM   #1197
JimmyMac's Avatar
No luck on the Zero this weekend. My servo saver went out on me, so I never got a good run in mod. Car was impossible to drive. I'll have to go direct mount next time. I ended up using my TA05, which is dialed. Always good to have a backup car. Not sure when I'll bring the Zero back out to play. Depends how much and what is broken on it...
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 06-27-2011, 03:27 PM   #1198
The Teacher's Avatar
Trader Rating: 48 (100%+)
Do any of you guys know if they move the motor mount forward on the new Sakura?
The Teacher is offline   Reply With Quote
Old 06-27-2011, 03:34 PM   #1199
Pro10noob's Avatar
I believe on the new Sakura you have some more space between the rear diff and the spur gear as you now can use the 84T spurgear without touching the diff.
So yeah there must be some more room in there somewhere
regards Roy
l===/o\===l
Old 06-27-2011, 03:49 PM   #1200
Here is a link for the spec of the new X1 on the 3racing site http://os.3racing.hk/carkits_web.php?carkits_web_key=11. According to this the motor mount has been moved 3mm forward and 1mm into the centre of the car
HTH
Team Powers UK Ltd
RGT Uk
martynp is offline   Reply With Quote
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
