Old 06-01-2011, 06:09 AM   #1156
Pro10noob's Avatar
If this is the production version it changed a bit as the previous pic's i have seen the rear damper stay is like the TRF416/TRF417 and in these pic's(see above) it is again on the back like the old car
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 06-01-2011, 12:00 PM   #1157
Luppi Stefano's Avatar
hello guys!
can you tell me standard rear arms length? hole to hole.
thanks!
Team Capricorn Italy
Lab F1-01
Luppi Stefano is offline   Reply With Quote
Old 06-01-2011, 05:42 PM   #1158
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
~ 56.25mm
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 06-01-2011, 06:16 PM   #1159
Originally Posted by seaball View Post
~ 56.25mm
thanks!
Lab F1-01
Old 06-01-2011, 08:55 PM   #1160
JimmyMac's Avatar
regards Roy
Just curious, but does the 416/417 rear shock tower fit on the front bulkhead caps without modification/hole alignment?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 06-06-2011, 10:29 PM   #1161
JimmyMac's Avatar
Is the Zero top-deck and Zero S top-deck interchangeable?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 06-07-2011, 12:08 AM   #1162
davenz's Avatar
Default zero s top deck
Jimmy mac...... I have tried the 's' top deck on the zero bulkheads, it does fit yes, but, u will snap the 's' top deck as it needs the mounting screws to be fitted as on the 's' motor mount.
where the mounting screw holes for the motor mount on the 's', is the weak point.
I broke mine in the 1st couple laps of the 1st practice using the 's' top deck
I have reverted back to the zero top deck.
Dave
davenz is offline   Reply With Quote
Old 06-07-2011, 01:19 AM   #1163
Pro10noob's Avatar
Done the mod allready.
It makes setting up the car almost the same as a 416.
Yes it will fit if you open the holes a bit up.
Just a little tho
I have done it with the 416 shocktower.
Don't know if the 417 will fit
New rear arms are on it's way to me and i am waiting on the new dual steering setup.
When that arrives i almost got a "new" Sakura
Check the pics
regards Roy
Sakura Zero - New Touring Car!-sakura-trf416.jpg   Sakura Zero - New Touring Car!-trf416-sakura.jpg
l===/o\===l
Old 06-07-2011, 01:42 AM   #1164
cannon's Avatar
Trader Rating: 35 (100%+)
You have to marginally enlarge the holes on the shock tower as the spacing is not exactly the same ...it is close but out by a fraction
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 06-07-2011, 01:47 AM   #1165
Pro10noob's Avatar
l===/o\===l
Old 06-07-2011, 05:22 AM   #1166
smilekt's Avatar
~ 56.25mm
Originally Posted by Luppi Stefano View Post
thanks!
why luppi ? is it fix with photon?
Kuala Terengganu Rc Club Facebook
http://www.facebook.com/group.php?v=wall&gid=357083332025
smilekt is offline   Reply With Quote
Old 06-07-2011, 08:24 PM   #1167
JimmyMac's Avatar
Thanks guys for the info on the topdeck and shock towers. I'm just tinkering around with my Zero until my short arms come in. I was asking about the top deck just wondering if the cheap S model topdeck would be super flexible. But right now, I'm doing pretty good with the "hard" topdeck. I sold my "soft" topdeck to my friend because his was cracked.
As far as shock towers, I was asking because I was wondering if the front bulkheads fit in the rear. This would offer different flex characteristics for the chassis.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 06-08-2011, 01:37 AM   #1168
Default Info Set-up Sakura Zero
Does good morning, possess a Sakura Zero and I would want to know some indication on as to use the model on asphalt with rubbers Sorex 36, have we found some problem of insertion in tightened curves the model it has the tendency to plant him in curve as we can resolve the problem, does someone have some set-up for asphalt to be been able to try?
I confide in some answer, meanwhile I thank for the infos Regards...
N.O.X. is offline   Reply With Quote
Old 06-08-2011, 01:59 AM   #1169
spring71's Avatar
Smile
New items are arrived from 3racing, Integy and Speed Passion.
Click Here to see the part store for Sakura
Click Here to see the new arrivals.
Click Here to see the re-stocked items.
For more information, please visit www.tqrcracing.com
Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
[email protected]
spring71 is offline   Reply With Quote
Old 06-08-2011, 02:24 AM   #1170
cannon's Avatar
Not completely sure what you are asking. Looks like you used Google translate.
With the Sakura it helps to run narrow blocks on the rear . It gives extra rear grip
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
