Old 05-27-2011, 04:30 PM   #1141
Pro10noob's Avatar
If i am not mistaken the rear arms are as long or short as the TRF416/417.
Seen some one driving it and it looks nice and planted.
Dunno if it was Sakura arms tho.
regards Roy
Originally Posted by over gear View Post
40mm shaft?? that's short! how much shorter are the new a-arms ??
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 05-31-2011, 04:20 PM   #1142
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
ran across a few images of the car that was run at the titc a few months back. perhaps a clearer glimpse into some of the features x1 will employ. fairly unexciting, save for the intensity of the electronics installation ..
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 05-31-2011, 04:54 PM   #1143
The Teacher's Avatar
Trader Rating: 49 (100%+)
I hope the new car doesn't come with the lower shock towers......I've tried everything with them and just can't get them to work... I wonder if the new car will come with a Seaballs tuning guide...
The Teacher is offline   Reply With Quote
Old 05-31-2011, 05:33 PM   #1144
Trader Rating: 77 (100%+)
Default quick question
new car looks interesting ....i have the zero and was wondering gearing recomendations for 21.5 motor with a 48p 80 tooth pinion
artoftatt2 is offline   Reply With Quote
Old 05-31-2011, 07:53 PM   #1145
JimmyMac's Avatar
Aside from the big mess of electronics, not bad. Wonder if they'll have a conversion kit for it? I just want the double arm steering. I did notice narrow front blocks and short arms, plus a few other things.
Anyways, so far my Zero is doing pretty good. Cannot wait to use the short arms. Just need to figure out which bones to use?? 40? 42? 44?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 05-31-2011, 09:27 PM   #1146
Lots of small changes, looks impressive.
I love the belt tensioner setup, looks like its externally adjustable.
Centre bulkheads allow screws to top deck.
Dual steering
Short arms
Narrow front blocks
Overall, if it had a decent electronics install, it would be a fine looking car.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 05-31-2011, 09:28 PM   #1147
Madulla's Avatar
From the looks of the pics. NFF new narrow front blocks, but in the rear not narrow blocks RR30 hmmm...
Hobbywing North America Team Driver
hobbywingdirect.com
Madulla is offline   Reply With Quote
Old 05-31-2011, 09:31 PM   #1148
cannon's Avatar
Trader Rating: 35 (100%+)
Dont know if this helps or not ...........
I was given a set of short arms to run at TITC on my Zero
I am using 46mm front with spool and 44mm rear with gear diff.
I am using standard front blocks but narrow rears
This was in a fast conversion before racing. I most probably could drop 2mm out of both shafts as I am well inside the drive cups
HTH
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 05-31-2011, 10:02 PM   #1149
JimmyMac's Avatar
HTH
Thanks Cannon, I figure maybe one pair of each set will get me going. I'm surprised that 46mm still fits in the front. Must be real deep in the cups.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 05-31-2011, 10:05 PM   #1150
seaball's Avatar
HTH
additionally, i've measured all the pivot blocks. here are a few random facts:
  • the narrow rear sets are 2mm narrower overall than standard pivot blocks of the same degree.
  • the rr blocks move in 1.5mm increments overall width, per degree
  • the standard front blocks are just about the same width as the rr2.0
Old 05-31-2011, 10:10 PM   #1151
cannon's Avatar
Well I am not going to break the outside of the plastic cup off
Old 05-31-2011, 11:42 PM   #1152
Mark Flores's Avatar
Trader Rating: 28 (100%+)
A bit late in the game, but I just finished building my Sakura Zero.
I am impressed by the quality and innovations in the car. Can't wait to run it!
Mark Flores is offline   Reply With Quote
Old 06-01-2011, 12:50 AM   #1153
Pro10noob's Avatar
I believe that the rear arms are shorter so the use of the narrow suspensionblocks isn,t needed anymore.
At the front i see indeed narrow suspension blocks.
Perhaps this is to narrow the track wide without using short arms?
regards Roy
l===/o\===l
Old 06-01-2011, 01:22 AM   #1154
from what I know a little bit more...
-screws to secure diff bearing housing
-motor mount move forward for longer rear belt
the front narrow blocks from the photos are just the same as Sakura FF. The new narrow front/rear arms replace that.
DanDan is offline   Reply With Quote
Old 06-01-2011, 01:53 AM   #1155
cannon's Avatar
Those pics show narrow front blocks but the car in the pictures is also equipped with the short arms
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
