Old 03-22-2011, 01:24 AM   #1051
Pro10noob's Avatar
Shame you don't speak or read dutch.
There is a very good build report on a dutch forum with all the pro's and little troubles when building this car.
The owner is running it in 17.5 class without timing or boost and it is running sweet.
regards Roy
Originally Posted by ian scott View Post
Hello have bought one of the cheaper sukaru zero with the normal diffs.Has any one found any trouble with this kit.Didnt know there was 2 different kits.
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 03-22-2011, 01:34 AM   #1052
ian scott's Avatar
Trader Rating: 14 (100%+)
Yes thanks pro10noob never really had that much trouble assembling it.Have put a 13.5 t ezrun with 35 amp esc with a 24 pinion with the standard 80 tooth spur.Very happy with it.It runs a concrete with 32 sorex tyres
ian scott is offline   Reply With Quote
Old 03-22-2011, 01:39 AM   #1053
cannon's Avatar
Trader Rating: 35 (100%+)
Do you mean you bought the Zero S?
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 03-22-2011, 01:44 AM   #1054
Pro10noob's Avatar
I forgot to say,yes i believe there are 2 types of gear diffs for the sakura.
The stock as in the Sakura S and the one you buy seperate and that has hard outdrives in the diff.
What seems to be the problem on your car/build?
regards Roy
l===/o\===l
Old 03-22-2011, 01:46 AM   #1055
ian scott's Avatar
yes cannon sukura zero s
Old 03-22-2011, 01:50 AM   #1056
ian scott's Avatar
Never really had much trouble pro10moob with assembly.Is there any advantage of the ball diff
Old 03-22-2011, 07:38 AM   #1057
chubbspeterson's Avatar
you get a bit more adjustment, basicly in a gear diff you would open it up to change the weight of the fluid, a diff you can adjust externaly.
ball diff requires rebuilds, a gear diff lasts longer between rebuilds.
Mike Demone
7-Eleven, National Accounts Manager
Ridgemont, CA, 90026
"I vowed to never let this happen.."
chubbspeterson is offline   Reply With Quote
Old 03-22-2011, 08:51 AM   #1058
Pro10noob's Avatar
What he said
I found out that a gear diff on a outside tarmac track gives you a bit more traction.
But this is what i think.
regards Roy
l===/o\===l
Old 03-22-2011, 04:19 PM   #1059
Speaking of gear diffs.
I just put my Solid front axle in my car. First full throttle on the straight, and shredded my rear gear diff internals.
I have a spare set, but was wondering what are my options moving forward?
I want to keep the locked front, so what should i go in the rear? Std gear diff, ball diff, one way? I am a bit of a noob with how these different set ups will affect handling? I understand locking the rear as well as the front is not a good idea.
I am running 5.5t EZRun with 20t pinion and std 80t spur.
greens14 is offline   Reply With Quote
Old 03-22-2011, 04:32 PM   #1060
Pro10noob's Avatar
How did you build the gear diff?
As the manual said?
Did you use both spacer rings behind the big satelite gears?
I am running a gear diff rear with a solid axle front.
13.5 motor timed boosted and so on.
Not yet broken a gear diff tho.
regards Roy
l===/o\===l
Old 03-22-2011, 04:45 PM   #1061
Yea all assembled as per instructions. A bit strange, but maybe just one of those things?
So what do you recommend i get for the rear? Std gear diff?
Old 03-22-2011, 05:03 PM   #1062
Pro10noob's Avatar
I say try a new set of gears.
Sand the rear of the gears smooth with 400 waterproof.
put some 600WT shock oil in the gear and see how it reacts.
One thing i did to mine is to shim out the play on the out drives.
I put shims between the outdrives and the diff housing to eleminate almost any play there.
Got it down to 0.05mm.
If you do this you can't push the gears to the inside when running a lot of camber and or when you get hit on the wheels.
This will keep the gears in better shape and they run a lot smoother.
I don't run the stock Sakura Zero S gear diff with the black outdrives but the one sold seperately with the steel outdrives.
I don't know if they are different but heard from another guy who was running a Zero S that he stripped the stock diff and rebuild it with the steel outdrives and now he hasn't got any problems any more.
regards Roy
Ps stock gear diff, new gear diff
Sakura Zero - New Touring Car!-user1011_pic53859_1293562528.jpg   Sakura Zero - New Touring Car!-new-geardiff.jpg
l===/o\===l
Old 03-22-2011, 10:03 PM   #1063
Whats the part # for the replacement?
Old 03-22-2011, 11:49 PM   #1064
spring71's Avatar
Smile
We have indoor rc race track&shop in Chino, CA.
More Sakura parts and hopups are arrived from 3racing.
Click Here to check out the sakura parts.
Click Here for the new arrivals.
You can buy online or at the shop. For more information please visit www.tqrcracing.com
Shipping to US within 1~2 days.
Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
[email protected]
spring71 is offline   Reply With Quote
Old 03-23-2011, 01:19 AM   #1065
Pro10noob's Avatar
Depends on what you want to replace.
Just the gears or a whole new diff?
Complete diff is part number SAK-65.
Steel outdrives is SAK-65A.
Gears are SAK-65F.
regards Roy
l===/o\===l
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
