Old 03-15-2011, 03:09 AM   #1036
HI GUYS,
Just bought the solid front axle for my Sakura Dose the standard diff gear fit these? Or d i need to buy a specific gear?
greens14 is offline   Reply With Quote
Old 03-15-2011, 09:06 AM   #1037
Send a message via Skype™ to asalk
Originally Posted by greens14 View Post
HI GUYS,
Yes it fits fine.
asalk is offline   Reply With Quote
Old 03-15-2011, 10:08 AM   #1038
chubbspeterson's Avatar
Default Sakura Rubber Tire/Carpet Setup
Here is the current setup I am running on the Sakura, for me it is more than solid, I have been reading the thread, and there seems to be little to no information on carpet setups. Here you go, any questions feel free to ask.
On setup sheet the inner Front and Rear links should be noted as
4mm front
5mm rear
Mike Demone
7-Eleven, National Accounts Manager
Ridgemont, CA, 90026
"I vowed to never let this happen.."
chubbspeterson is offline   Reply With Quote
Old 03-17-2011, 01:51 AM   #1039
CHRIS CHAVEZ's Avatar
4mm front
5mm rear
Thanks for sharing. But I'm having a little difficulty reading the gear diff oil. Let me see if I have this right.
Front gear diff= 500,000
Rear gear diff= 3,000
Also which?
motor and turn
gearing
Shock springs
Thanks again.
"Dirt is for growing Potatoes"
TQ RC Racing
CHRIS CHAVEZ is offline   Reply With Quote
Old 03-17-2011, 04:55 AM   #1040
Also which?
motor and turn
gearing
Shock springs
Thanks again.
Front gear diff is 500,000 wt from kyosho
Rear gear diff is 30 wt associated shock oil
17.5 motor
3.8-4.2 FDR
Front spring is tamiya white
Rear spring is tamiya blue
Thanks,
Mike Demone
Old 03-17-2011, 01:55 PM   #1041
over gear's Avatar
Trader Rating: 15 (100%+)
17.5 motor
3.8-4.2 FDR
Thanks,
30wt oil? does it leak badly?
over gear is offline   Reply With Quote
Old 03-17-2011, 03:20 PM   #1042
Not at all, with the o-rings, and the main gasket nothing comes out. super smooth too! I have built 3-4 others and the first one came out the best, so I never touched it again.
Mike Demone
Old 03-17-2011, 10:20 PM   #1043
Also those who buy the Solid axle will need to buy the matching 38t pulley, as the standard diff pulley doesnt fit. The part # required for this upgrade are: SAK-02 (38t Pulley)
SAK-08/PK (Solid Axle)
SAK-09 (Solid Axle outer Joint)
Old 03-18-2011, 01:44 AM   #1044
17.5 motor
3.8-4.2 FDR
Thanks,
Thank you
I've normally used 1000wt oil in the rear diff and it usually leaks all over the place. I wonder how Chubs made the 30wt not leak?
TQ RC Racing
Old 03-18-2011, 01:51 AM   #1045
use heavy automotive grease, they're sticky and don't leak. Did this with an old TA02 waaaaaaaaay back in 1999.
cheapskate.brok is offline   Reply With Quote
Old 03-21-2011, 06:33 AM   #1046
Thank you
It's how you assemble the peices. there are 2 o-rings, and a gasket..if there leaking you have done something wrong...
I have now seen rear diffs with no oil at all, just a light coating of grease, and they work just fine, gear diffs are very difrent that a ball diff, there is no slipping, so the less bound, and free the rear gears are the better that unit will work.
Mike Demone
Old 03-21-2011, 08:37 AM   #1047
Pro10noob's Avatar
I use 1000CPS oil at the moment in the rear dif and no leakage at all.
Smooth as butter
regards Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 03-21-2011, 02:03 PM   #1048
RC MARKET's Avatar
3 Racing Sakura Belts was back in stock !
RC MARKET is offline   Reply With Quote
Old 03-22-2011, 12:43 AM   #1049
Hi Guys,
Does anyone know what is the part number for tamiya 416 rear belt that will fit on Sakura?
There are too many version of tamiya rear belts, donno which one will fit.
pulley combination is 20/38, pitch I believe 3.0.
DanDan is offline   Reply With Quote
Old 03-22-2011, 01:11 AM   #1050
ian scott's Avatar
Trader Rating: 14 (100%+)
Hello have bought one of the cheaper sukaru zero with the normal diffs.Has any one found any trouble with this kit.Didnt know there was 2 different kits.
ian scott is offline   Reply With Quote
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
