Old 12-03-2010, 05:18 AM   #961
Jezp's Avatar
tnx kid TT-01 & dameetz for the reply.
actually running rubber sorex 40sh is perfect but the members in my group want to keep it cheap so to attract more newbies since we only have 6 members. we use to run touring rubber but i just wanted to try foams and cant get the right setup with it. i am using 26mm front and rear nitro foams. some of the newbies are hesitant to come back due to cost of sorex rubber tires here (they run on rails). anyway tnx for ur sugesstion and i will try it out.
which ones are the narrow rear blocks? you mean this SAK-63/PK = Narrow Suspension Mount RR+30 (RR3 Degree) Sakura Zero?
Jezp is offline   Reply With Quote
Old 12-03-2010, 10:52 AM   #962
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
Could someone tell me the exact dimensions of the down stops on this car thanks
Justin & Matt Lyons
Awesomatix USA, EA motorsports, Sanwa, Protoform, Avid, Gravity Rc , TSR!
a800s sanwa m12s
jlfx car audio is offline   Reply With Quote
Old 12-03-2010, 11:10 AM   #963
dameetz's Avatar
You need these 2 to convert the rear into narrow and still maintain the same toe in angle.
SAK 60 PK Narrow for the RF
and this SAK 63 PK Narrow for the RR
You may need to use 44mm rear universal shaft to pair with the narrow conversion. Check if its binding against the Gear Diff outdrive cup. If this won't solve it, you can narrow it some more by using the optional 4mm thick wheel hex.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 12-03-2010, 11:12 AM   #964
dameetz's Avatar
What do you mean by down stop dimension? You mean the screws?
Old 12-03-2010, 01:45 PM   #965
No... the actual size of the tungstion plates in the chassis
Justin & Matt Lyons
a800s sanwa m12s
Old 12-03-2010, 05:37 PM   #966
CuLeX's Avatar
Bro so how about the 46mm shaft. Its not gonna work on the narrow suspensions?
CuLeX is offline   Reply With Quote
Old 12-03-2010, 05:46 PM   #967
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Anyone have a good trick for measuring or getting the proper tension set on the front and rear belts?
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 12-03-2010, 08:21 PM   #968
Jezp's Avatar
tnx again dameetz for the reply. will do that today and i will also turn over the front and rear diff so i can access the pinion without removing the motor (the front belt gets in the way with the grub screw of the pinion
Old 12-03-2010, 08:32 PM   #969
dameetz's Avatar
It will do fine. Just check if there is any binding(no gap or little bit gap between the universal shaft cushion and the inside end of the gear diff outdrive) For me I ran mine using 46mm intially(without problem) and changed it to 44mm now since its already available from 3racing.
Old 12-04-2010, 05:44 AM   #970
CuLeX's Avatar
Just bought the NRF 0 just now..lucky its the last piece i think.
Have u check at GHL hobbies?
Old 12-06-2010, 11:49 AM   #971
seaball's Avatar
Send a message via Yahoo to seaball
http://os.3racing.hk/products.php?products_key=4665
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 12-06-2010, 11:56 AM   #972
squarehead's Avatar
Thanks, someday mine will get here on the slow boat from China. Never again will I order from Dinball...
About how much give do you want in the front belt? What's too tight and what's too loose for normal running? I have never had a car with such strange belt tension from the get-go, so I never paid attention to it at all before.
Everything depends.
Nothing is always.
Old 12-06-2010, 03:11 PM   #973
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Kit settings the belt is fairly tight, it will loosen up after a few runs.
Alex Ilievski
*INFINITY * R1 WURKS * PLAIG BEARINGS* SPEEDY RC
A Ilievski is online now   Reply With Quote
Old 12-10-2010, 08:02 PM   #974
The Teacher's Avatar
Trader Rating: 49 (100%+)
Has anyone tried the narrow chassis yet? Just got one and thinking about trying it out. I'm thinking this will give me more overall grip but would like to hear what others think...
The Teacher is offline   Reply With Quote
Old 12-10-2010, 08:36 PM   #975
It give you a lot more steering as the chassis flex more. As we run mod class (I am running 4.5T and some guys even use 3.5T... ) I don't really like it as it make the rear end quite loose.... I think it should work better if you run it in the stock class.
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
