Old 09-13-2010, 07:51 AM   #766
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by PAULTRIC View Post
I also run the Sakura in 10.5 on a outdoor asphalt track and the car goes well, optional parts i run are the 3 deg narrow rear block, the narrow chassis, 4mm hexes in the rear and 0.5 front roll center shims.
What are the benefits of this set up you are using when comparing to the normal ones that comes with the kit ?
What are the advantages of the narrow chassis ?
thanks[/QUOTE]
+ YouTube Video
+ YouTube Video
testing sakura
Give the best while u can !
kschu is offline   Reply With Quote
Old 09-13-2010, 08:32 AM   #767
12scale's Avatar
thanks[/QUOTE]
The narrow chassis made the car rotate in the rear off power (i think its because the chassis flexes a bit more than the kit one) so adding the 0.5 shims in the front made me able to throw the car in to corners without spinning the narrow block and the 4mm hexes and the shorter upper rear linkage made the rear stick a bit better.
Stuart McMillan
Xray T4 2015
Hobbywing/Sanwa/Pro Amps
Adelaide RC Team Mechanic
www.adelaiderc.com.au
12scale is offline   Reply With Quote
Old 09-14-2010, 05:36 PM   #768
The Teacher's Avatar
Trader Rating: 49 (100%+)
Have any of you guys used the narrow blocks in the rear with the gear diff? Did you have any issues with the CVD being too long? Do I have something wrong...?
The Teacher is offline   Reply With Quote
Old 09-14-2010, 08:50 PM   #769
By the way Teacher, my plans are also to use the gear diff......
What are the original pieces that I need to replace for it ?
What are extra pieces I also need to buy when purchasing my kit ?
thanks
Paulo Trichtl
So Paulo
Brazil
PAULTRIC is offline   Reply With Quote
Old 09-14-2010, 09:36 PM   #770
Hiya, i have used Gear Diff with standard axles. Make sure you are using the new wider blades, i think they are not as deep in profile as the original ones.
If you are having issues, you can replace the universal bone with a 44mm Tamiya one.
With the normal 1-2 degree of camber i have not had a problem with the kit 46mm bones.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 09-14-2010, 09:40 PM   #771
thanks
Must haves are narrow blocks, and 4mm hex for the rear.
You dont need to get anything extra when installing the 3r gear diff, its a stright drop in. Though i would suggest using the supplied 37t pulley, as it allows you to set the belt tension much better IMO (you would need to use a 37 pulley in front also)
Old 09-14-2010, 10:39 PM   #772
I'll be ordering mine next month and a customer's one tomorrow...what part numbers do I need for the narrow rear blocks with 3* rear toe?
Old 09-17-2010, 03:53 AM   #773
RC MARKET's Avatar
New motor mount released !
Sakura Zero - New Touring Car!-1008241327164c01952cd9580c.jpg   Sakura Zero - New Touring Car!-3r-sak-66pk.jpg
RC MARKET is offline   Reply With Quote
Old 09-17-2010, 05:30 AM   #774
Very nice!!!
lucapatrizio is offline   Reply With Quote
Old 09-17-2010, 05:53 PM   #775
Cemgsirj's Avatar
Default Another Hi, from brazil...
Hi guys, My name is Luciano and i also have one sakura in Rio de Janeiro, but im running with a 4.5t motor... My perspective about the car is simple, its very strong and competitive chassis, with a lot of upgrades and amazing price of extra parts. With a good setup its better them others chassis od his class, here in Rio, we have a lot of t2 and t3 of xray. But im realy very satisfied with the 3racing car. Any others tips, folks, let us know.
Regards, Luciano.
Cemgsirj is offline   Reply With Quote
Old 09-17-2010, 08:27 PM   #776
Regards, Luciano.
Luciano,
let me have your msn !
I'm from Sao Paulo and will buy a Sakura very soon !
Lets talk !
thanks
Paulo Trichtl
So Paulo
Brazil
Old 09-17-2010, 08:38 PM   #777
RCknight's Avatar
Default Nice designed part.
Most creative I've seen yet and better screw mounts!
RCknight is offline   Reply With Quote
Old 09-17-2010, 10:31 PM   #778
kschu's Avatar
Luciano,
Lets talk !
thanks
add me dude
[email protected]
Old 09-18-2010, 02:07 PM   #779
Default Damper quality
Just wana know if sakura's dampers are good as Tamiya or HPi/Hot Bodies.
Can you share expirience? Are shock shaft and pistons same as Tamiya/HPi-HB?
tomislav is offline   Reply With Quote
Old 09-18-2010, 06:10 PM   #780
kschu's Avatar
i would suggest u to change to tamiya shock body, tamiya piston and tamiya shock shaft....then it'll smooth like butter but u need to change the shock tower to the taller one too...
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
