Old 09-09-2010, 10:56 PM   #751
fleetmaster's Avatar
Trader Rating: 16 (100%+)
I don't really like alloy C-hubs , as Besercoe said, they tend to bend and stay bent .
I like the alloy steering blocks , though i'm still running plastic ones on my Sakura.
I have changed the C-hubs to Xray plastic ones, as I believe their composite to be superior to that of 3racing.
fleetmaster is offline   Reply With Quote
Old 09-09-2010, 11:23 PM   #752
Originally Posted by kowkl View Post
Besercoe,
Why is that ???
I never really though of it like that. Now I'm have a different perspective on plastic part. Good One !!
It is not only the crash = unknown bending, it is also about the ability for the car to generate grip, plastic parts flex aiding in the generation of grip.
Check out all the pictures of the pro's cars, you will rarely find ANY top level driver with alloy suspension parts on the car.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 09-10-2010, 08:12 AM   #753
Fleetmaster, what about alloy steering blocks for Sakura ?
Where can I find it ? Can I also use the Xray ones ?
Paulo
PAULTRIC is offline   Reply With Quote
Old 09-10-2010, 12:29 PM   #754
RC MARKET's Avatar
Narrow Chassis back instock !
RC MARKET is offline   Reply With Quote
Old 09-10-2010, 10:10 PM   #755
Besercoe,
What about the harden parts manufactured by sakura, are they any better or worse than the alu parts ?
Now I know not to buy any blink blinks for the car as I've spent a lot since getting my TA05. I fully agree with you on the cars own by pro that win races don't have blink blink.
Thanks for explaining.
kowkl is offline   Reply With Quote
Old 09-11-2010, 05:59 AM   #756
crabboy's Avatar
Trader Rating: 58 (98%+)
Hey Bradd,
Got a 3 racing gear diff, built it up as per the instruction sheet and it a bit tight to turn, the out drives are free in the outter housings, i have also tried it with less shims in and it still feels the same, can you please post a few build tips please.
Rhys
Rhys Marshall.
crabboy is offline   Reply With Quote
Old 09-11-2010, 06:10 AM   #757
Originally Posted by crabboy View Post
Hey Bradd,
Rhys
I have actually been a bit lazy, and have not really messed around with the diffs too much, i just slapped them together and run.
I also found that the action is tight and a little gearish when turning, what i found as a quick fix is to simply undo each of the 4 screws by perhaps a quarter of a turn, put it in car, run it in for a minute or two, and it should be like butter.
If i were messing around with shimming etc, i would attempt to remove one of the 2 large shims on ons side of the outdrive.
Probably the biggest thing to check is that you have REALLY pressed the conical gears hard down onto the pins, it may beel like they are fully mounted, but give em a big push and it will move a fraction further on.
Let me know how you go.
BTW - Has anyone seen anywhere what the kit oil is? I thought i would try something lighter, i whacked 1000 mugen in there, which looked a lot thinner, but the diff action feels comparable.
I have some Venom brand 300k in a diff for the front, feels very good on the track.
Old 09-11-2010, 08:15 AM   #758
12scale's Avatar
Hey Bradd,
Rhys
Rhys, have found the same as you also tried less shims and the same, on the track it sounds like the gears are not meshing at all well. Maybe an extra gasket would help.
Stuart McMillan
Xray T4 2015
Hobbywing/Sanwa/Pro Amps
Adelaide RC Team Mechanic
www.adelaiderc.com.au
12scale is offline   Reply With Quote
Old 09-11-2010, 02:57 PM   #759
cherry2blost's Avatar
I am going to be trying Kyosho 500,000 weight in the front for mine make it like a slipper spool, hoping it will ease the steering response somewhat..... Any advice......
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 09-11-2010, 05:18 PM   #760
I also stole some kyosho 500k from a friend, but i have yet to try it, it is MEGA thick. Only advice is just make sure you dont fill it up too much. All the Nitro guys keep telling me the gear diffs just work better with less oil in them, i guess it allows the oil to aerate during use.
The heavy oil front diff will make the car feel much like a spool, but it will give you extra steering going into a corner, perhaps a touch less pull out of the corner, but overall just smoother.
Let us know when you give it a go.
Old 09-12-2010, 01:47 AM   #761
davenz's Avatar
Default nz drivers series
good result for the 'sakura zero' at New Zealand club HRCCC 3 day winter race meeting, finishing 3rd over all after 12 races in the 13.5 superstock class on a slippery concrete surface.
First 3 cars running tekin 13.5/ rs pro systems.
there was only 1 problem all weekend, 1 of the front heavy duty swingshaft parting company with the outer shaft ( pin and grub screw still together in the swingshaft), causing the car to spin while cornering .
davenz is offline   Reply With Quote
Old 09-12-2010, 07:51 PM   #762
Default Alloy Steering Block
Bersecoe,
You told me that some Xray parts are also interchangeable with Sakura !
Do it include the steering blocks ?
Is it here any person driving the Sakura with a 10,5T motor ?
How is it ?
The Brazilian Stock Championship will be placed in November and motor selected for it are the 10,5T , trade and manufactures are open !!!!!
rgds
Paulo
Paulo Trichtl
São Paulo
Brazil
Old 09-13-2010, 03:29 AM   #763
Originally Posted by PAULTRIC View Post
Bersecoe,
How is it ?
rgds
Paulo
Yes, they are compatible, but only have two ackermann holes.
Besercoe runs 10.5
Old 09-13-2010, 04:38 AM   #764
12scale's Avatar
[QUOTE=PAULTRIC;
How is it ?
rgds
I also run the Sakura in 10.5 on a outdoor asphalt track and the car goes well, optional parts i run are the 3 deg narrow rear block, the narrow chassis, 4mm hexes in the rear and 0.5 front roll center shims.
Stuart McMillan
Xray T4 2015
Old 09-13-2010, 07:14 AM   #765
I also run the Sakura in 10.5 on a outdoor asphalt track and the car goes well, optional parts i run are the 3 deg narrow rear block, the narrow chassis, 4mm hexes in the rear and 0.5 front roll center shims.[/QUOTE]
What are the benefits of this set up you are using when comparing to the normal ones that comes with the kit ?
What are the advantages of the narrow chassis ?
thanks
Paulo Trichtl
São Paulo
Brazil
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
