Old 06-13-2010, 01:18 PM   #586
RC MARKET's Avatar
Sakura Zero belt tension set released !
RC MARKET is offline   Reply With Quote
Old 06-18-2010, 06:35 PM   #587
fleetmaster's Avatar
Trader Rating: 16 (100%+)
Ran my Sakura in our controlled motor/ speedy 21.5 class last night.
First proper race night for this setup and it went well.
I ran soft rubber earlier , but once my warmers were going , I switched to T.O.P 36 No Mark premounts. This stopped the traction rolling altogether.
The car has awesome steering, but similar issues as mentioned by others, with the rear being a little loose in one tighter turn. I plan on trying the roll centre shims next and reducing front camber a touch.
I tailed the lead car in the final lap after lap, forcing a mistake. To then lose it back with a minor error two laps from the end. He win by a second, with me gaining ground back.
I set a new lap record with this chassis. I will go faster with Sorex next time and more tuning.
Fwiw, I was duelling with two Xray '09s comfortably . I will beat them next time....
fleetmaster is offline   Reply With Quote
Old 06-18-2010, 06:51 PM   #588
kschu's Avatar
Send a message via MSN to kschu
add 6mm shim under the front inner camber link...
add 1mm shim for bump steer..
this both reduce the front steering and make it's more comfortable to drive ..
Give the best while u can !
kschu is offline   Reply With Quote
Old 06-19-2010, 04:09 PM   #589
is 6mm correct for the inner camber link seems a lot
martynp is offline   Reply With Quote
Old 06-20-2010, 01:30 PM   #590
I have tested my car on tarmac for the first time today and it was very pointy but after moving the rear shocks up a hole too the second one in it was a lot better and more driveable
Old 06-20-2010, 07:59 PM   #591
Guys with loose rear ends, try some 4mm hexes to see if it improves.
IMO the car is too wide, especially in the rear end, which makes it floaty on low grip surfaces.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 06-20-2010, 11:15 PM   #592
What camber settings are you using ATM ??
I've got 2* allround and was going to try 1.5* on the front.....
Do you have shims under the lower arm holders ??
If i'm going to race Bobby again, I want to be charging hard the WHOLE track . I had to be careful at turn 2-3 . But it was awesome everywhere else.
Old 06-25-2010, 04:24 PM   #593
Any news yet on when the shock spring set and the gear diff are due for release
Old 06-25-2010, 06:16 PM   #594
RC MARKET's Avatar
not ready wait moment !
Old 06-25-2010, 07:03 PM   #595
kschu's Avatar
Xenon New Spur gear anyone ??
Old 06-27-2010, 09:45 AM   #596
dameetz's Avatar
Has anybody tried HB DCJ type universal on this car? Or will 3 racing make 'em soon?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 06-27-2010, 01:59 PM   #597
I am running a 74t Xenon just had to make an extra hole for tightening the motor
Old 06-28-2010, 07:40 AM   #598
RC MARKET's Avatar
MUCH MORE
PINK COLOR STRAPPING TAPE
3 RACING
Narrow Suspension Mount
Sakura Zero - New Touring Car!-mm-cs-tn.jpg   Sakura Zero - New Touring Car!-3r-sak-60pk.jpg   Sakura Zero - New Touring Car!-3r-sak-62pk.jpg
Old 07-03-2010, 10:52 AM   #599
Luppi Stefano's Avatar
at the WC2010, someone with Sakura Zero?
Luppi Stefano is offline   Reply With Quote
Old 07-03-2010, 06:36 PM   #600
The Teacher's Avatar
Trader Rating: 49 (100%+)
Does 3 racing even have a team...?
The Teacher is offline   Reply With Quote
Adelaide Electric Radio Control Car Club Inc penmark67 Australian Racing 6824 07-10-2014 05:51 AM
